Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
A better alarm clock
Want to change the alarm clock application in order to be able to configure it for working days only, without having to turn it on and off manually.
Any ideas, cause its really annoying?
  • JooJ Apr 05, 2008
    Don't want a solution through my SP, thanks.
  • Anonymous May 11, 2010
    Who is your SP?
  • 127 Answers
I was asking as far as the SP so I knew what software you were dealing with. Software is specific to SP as it tells what the application is so that I can tell you exactly how to do what it is you are wanting to do. You can use the datebook but some SP's Alarm clocks ie VZW has it were you can go into the Alarms detail and set it for M-F and not the weekends. ( My husband does this with his phone for the same reason as you) Let me know if I can help in any other way. Also some SP allow for Java Applications so that you are "allow" to put on another Alarm clock onto your phone to better suit your needs. SP are good for 2 things, telling me what it is I am dealing with and ummm.. ;)
Posted on Apr 06, 2008
Use the datebook and you can make an alarm repeat any days you want.
Posted on Apr 04, 2008
SOURCE:
My Mother-in-Law recently purchased a ZTE Majesty Pro [Z799VL] telephone from a Dollar General store. It has an alarm that goes off every 15 minutes. How do I disconnect from this service?
Read the manual. Turn the alarm off and the repeat function. It probably has an alarm set and the 15 minutes reminder is to say it hasn't been cancelled.
Page 89
Clock
Press the
Home Key
Clock
. The Clock app allows you to check local time in places
around the world, set alarms, and use timers.
Setting a New Alarm
1.
Open the Clock app and tap
2.
Tap a default alarm to configure it, or tap
at the bottom of the screen to create a
new alarm.
3.
Set up the alarm options, such as time, alarm days, snooze, and alarm ringtone.
4. Tap
SAVE
to save and exit.
NOTES:
To enable or disable existing alarms directly, tap
On
or
Off
on the right side
of each alarm.
• Tap
to configure alarm settings, including ringtone volume, vibration, alarm
duration, volume crescendo, and alarm in silent mode.
Manual is here
http://zte-iqorsupport.custhelp.com/ci/fattach/get/3730/0/session/L2F2LzEvdGltZS8xNTExMjI1NjY2L3NpZC9mVUl0Ykhoc3lwNW9rVWZ3WU0ycGlPbllqOEdkS1lzTFB3ZkJheHNGdXdFUEtweVpzZWUzZ05BaWhiTmFMJTdFdVBoU09TUVJzcExxYUpXUFBndldkUmVCNl8xNldsTE1RRWlHQ1J1dDhBYkNHa2xFRHNheHVSJTdFZE9nJTIxJTIx/filename/ZTE_Majesty_Pro_LTE_GSM_Z798BL_UM_EN_Approved.pdf
Specs and link to manual at the bottom of the page.
How do get the User Guide for the ZTE Majesty Pro LTE Z798BL GSM
Nov 21, 2017 | ZTE Cell Phones
Why is my alarm always onn
Alarms are designed to reset every day after you stop them so they'll wake you the next day without you having to do anything. Look for a setting on your clock radio that lets you turn the alarm completely off. You'll be able to tell when you've succeeded, because the indicator on the front panel that shows whether an alarm has been set will disappear. Don't forget to reverse the procedure and turn the alarm on when you want to awakened the next day.
Oct 08, 2014 | Audio Players & Recorders
Need instructions for Discovery Kids Projection Daisy Bloom Alarm Clock
1.set time: hold down "clock" button for five seconds, then use up and down arrows to change, and press "clock" button once to toggle between month/day/year/hour/minute. Try it a few times b/c sometimes it just goes to the alarm setting (i don't know why, i think it's a glitch).
2.set alarm: hold down "alarm" button for 5 seconds, use up and down arrows to change, press "alarm" button once to toggle between hour/minute. press "clock" button to return to clock
3.turn on/off alarm: press "alarm" button once, press up to turn alarm on and press up again to turn alarm off. press "clock" button to return to clock
4.to project the images: push the buttons that look like video cameras. to focus the image, rotate the cylinder around the lens that projects the image. on the daisy clock, there's a button on top that you can use to flip the projected image of the time upside down. use the dial next to the lens-cylinders to select a different image (you may need to point the cylinders in a different direction to reach the dial)
Aug 19, 2013 | Bon-Ton Kids Discovery Kids Projection...
Setting time on wincraft desk clock
Directions for Desk Clock - Without the C?/F? button
To change the Temperature:
Press the "S" button once (this will change from Fahrenheit to Celsius)
To change the Time and Date:
Press the "M" button once to change time to or from military time
Press the "S" button once to change the hour
Press the "S" button again to change the minute
Press the "S" button again to change the year
Changing the year will also change the day of the week
Press the "S" again to change the month
Press the "S" again to change the date
To set the Alarm:
Press the button with an alarm clock on it
A flashing 12:00 should appear
Press the arrows to set the hour
Press the "S" button again to set the minutes
Press the "S" button again to change the "ring" of the alarm
There will ne a number below the time the alarm is set for
Use the arrows to advance through the options
To turn the alarm functions completely off:
Press the button with the alarm clock on it
Press the "S" button five times
When three dashes appear where the time would be, it is off.
Press the "M" button three times to get back to the main clock function
To clear the secondary clock:
You can set two different times on the clock, so if you travel frequently you can have a home time with alarm and a travel time with alarm saved and ready to go. There is a primary time, the one you normally see on the clock with an alarm clock function after it. There is also a secondary time with an alarm function after it.
Clearing the secondary clock will make it easier to know when you get back to the primary clock function.
Press the "S" button seven times
Press the "M" button two more times
And you are Done!
Jan 02, 2012 | Wincraft FLORIDA GATORS OFFICIAL THE SWAMP...
I need help setting the alarm on my radio controlled digital clock.
1- Turn over your Seth Thomas digital clock. Use your finger to remove the cover to the unit's battery compartment. Insert two AA-size alkaline batteries into the battery compartment and replace the cover. Certain Seth Thomas digital clock units will also have an optional alternate power source in the form of a standard AC power cable that plugs into a wall outlet in your home.
  • 2 Place your Seth Thomas solar-powered digital clock in front of a light source, such as on a window sill or beneath a lamp. The black strip on the top of the unit is the solar sensor, so as long as light is shining down on that strip, your clock will be powered on and ready to use. The sensor stores energy throughout the day so that it can work at night with no direct light contact on the sensor.
  • 3 Press the time zone button that indicates your current time zone. These buttons are located on the back of the unit. For example, if you are in the eastern time zone select the "EST" button. Turn the unit back over. It will now be displaying the correct time on its digital screen.
  • 4 Use the "Alarm" switch (if applicable) to enable and disable the clock's alarm. Press the "Alarm" button, followed by the "Hour" and "Minute" buttons, to set the appropriate alarm time based on your needs. Use the "Alarm HI LO" switch to set the volume for the alarm.
  • 5 Press the "Weather" button to tune your Seth Thomas digital clock to its built-in local weather radio station (if applicable). Certain Seth Thomas clocks have this radio weather functionality built in, while others don't. If yours does, the aforementioned "Weather" button will be located on the front of the unit.
  • May 28, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    How to change the time on the Timex auto set clock radio.. the DST hasn't switched back to EST.
    Timex T309TT Clock Radio.
    Setting the time:
    Unlike another review that says it automatically sets the time, I did not find that to be the case, I believe the model with the cd player does that, but this one had to be set. I'm not one to usually read the manual as I like to figure things out on my own, and was able to set the time without the use of it. It was as simple as holding the time set button and using the reverse and forward buttons to advance the time. Unlike some clocks, you do not have the option to change just the hour or just the minutes, you have to forward or reverse through all the hours/minutes.
    Calendar:
    The alarm can be set to go off 7 days a week, 5 days (Monday-Friday), or 2 days (Saturday & Sunday). Again, easy to do with pushing the date button and using the forward and reverse buttons to scroll through the dates.
    Adjustable display: There are 3 levels of lighted display, pressing the snooze/dimmer button allows you to change between the three. Nice touch!
    Radio Operation:
    After pressing the Radio on the display will show the word "on" before returning to the clock display. The bottom display shows the radio frequency.
    There are 18 programmable radio station settings with the buttons to access them right on the front of the clock labeled 1-6. Programming is easy with just finding a station you like and pressing and holding one of the preset buttons until it beeps to confirm it was accepted.
    I find the radio to get fairly good reception and for the times it doesn't , after moving the attached wire antennae it would pick up a better reception.
    So far my experience with the sound quality has been good.
    The radio also has a last station memory, so after being turned off and then back on, will recall the last station you were listening too.
    Alarm:
    Setting the alarm is fairly simple. To set , simply press the alarm button until the time on the screen starts to flash. Then you can click the button to choose through 3 settings which are every day, weekends, or Mon-Fri. This radio also comes with nature sounds. I have not used this feature at this time. You have the choice of
    * Ocean surf
    * Forest spring
    * Rushing brook
    * Summer wind
    Hope this helps :)
    May 03, 2011 | Timex T309TT Clock Radio
    I have a clock that will only come up as pacific time zone time. I am in central time zone in the usa. How can I correct this as it does not allow me to input any time changes manually? I have tried...
    1. press "MODE" (it will show the alarm time)
    2. press "ADJUST" (this will switch the time zones)
    3. when it is on the desired time zone, press "MODE" to return to the clock.
    Mar 15, 2011 | Audio Players & Recorders
    HOW DO YOU SET AN ALARM? CAN YOU SET MULTIPLE ALARMS?
    Hi, To turn on the alarm function in the Clock application on the BlackBerry smartphone, complete the following steps: In the Clock application, press the Menu key. Click Set Alarm. Set the alarm time by highlighting the hour, minute, and 12-hour notation fields and rolling the trackball. Highlight the text beside the alarm time. Roll the trackball and select either ON (everyday) or WEEKDAYS (weekdays only). Press the Escape key. An alarm indicator appears in the bottom left corner of the Clock application. To set alarm notification options To set the alarm notification options, complete the following steps: In the Clock application, press the Menu key. Click Options. In the Alarm section, choose an option for the Alert Type, Alarm Tune, Volume, Snooze Time, and Number of Vibrations fields. Press the Menu key. Click Save.
    I Hope it helped you.
    Thank you for using ' Fixya ' and have a nice day!!
    Nov 11, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
    Help setting alarms
    To set an alarm for an event: 1. Create a new event or double-click an existing event. 2. In the New/Edit Event dialog box, select the Alarm check box. 3. Click the time interval selector and select Minutes, Hours, or Days. 4. Type a number between 0 and 99 in the Time Measurement box. 5. Click OK. To set a default alarm for all new events: 1. From the Tools menu, choose Options. 2. In the Options dialog box, click the Date Book tab. 3. Select the Alarm Preset check box. 4. Click the time interval selector and select Minutes, Hours, or Days. 5. Type a number between 0 and 99 in the Time Measurement box. 6. Click OK. Setting Alarm Options You can configure the Alarm Manager settings for the Desktop application in the Alarm tab of the Options dialog box. To set Alarm options: 1. From the Tools menu, choose Options. 2. In the Options dialog box, click the Alarms tab and click one of the following actions: * Always available: Click this option if you want alarm notifications to appear regardless of whether the Desktop application is running. * Available only when Palm Desktop is running: Click this option if you want alarm notifications to appear only when the Desktop application is running. * Disabled: Click this option if you do not want alarm notifications to appear on your computer. 3. If you want an alarm tone to sound when the alarm notification message appears, click Play audible notification with alarm dialog. 4. Click OK.
    Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
    Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
    107 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    D. E. Hev
    vince
    Lawrence Oravetz
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
