Question about GE Spacemaker JVM1640SJ Microwave Oven
Do not heat any longer, lights, clock and fan work
Do not heat any longer.
Lights, clock and fan work fine, but no heat
    Brigadier General:
  • 4,090 Answers
In situtions such as these it can be considered that the Magnatron has passed on. Co0t of repair often exceeds the value of replacement.
No fuse controls the magnatron separately from the rest of the unit so deem it dead
With the availability of good second hand models on the market via pawn shops like Cash Converters etc one can find a very good unit with 30 day warranty for $50-100 and its already been checked over for defects
Please rate my help++++Thanks for using FIXYA
Posted on May 08, 2010
My 10 year old GE Spacemaker XL1400 microwave has stopped heating the microwave's contents.
probably a magnatron failure
take it to an appliance repair shop for a proper diagnosis and get a quote as repairs can be more expensive than new unit
Nov 24, 2015 | GE SpaceMaker Microwave Ovens
Light stays on and won't start
emerson mecrowave mw81195bm clock works but I can heat anything it doesn.t work inside
Oct 22, 2012 | AEG MCD3534EM Stainless Steel 900 Watts...
I have a GE JES831WB 001 microwave that I'd love to fix. The light, clock & timer are working, but that's all - no fan nor heating. Any suggestions?
The door switches are often a problem, one or two are probably defective which would cause the symptoms that you are describing.
Apr 05, 2012 | Microwave Ovens
My microwave top oven won't heat and there's a smoke smell. the fan, lights and clock works fine.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
f9uy
Apr 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Everything on our microwave still works( Clock,lights, fan) except it will no longer heat anything you put in it
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Oct 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Will not heat. Fuse and diode check good. Fan, lights, horn, etc all work fine.
The magnetron has failed, simply replace this component and this will fix your heating issue.
Jun 02, 2009 | Microwave Ovens
No heat in microwave
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Oct 07, 2008 | Roper MHE14XKB Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
254 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
