Question about Philips DVP5140 DVD Player
I am hooking up a dvd player with the black and white wires
Maybe because I technically challenged but when I just took out my vcr and now replaced it with this dvd player I can't get it to work. The meaning, is that I can't understand how the cables for the box can't be hooked up to the dvd player. In my opinion, it just doesn't make sense. Any help once again would be great fully helpful.
    Problem Solver:
  • 9 Answers
The most basic hook up you can do is use a composite AV cable(yello/red/white). This cable should have come with your player. Check your TV it has those available inputs. They are also color coded. On the back of your player, there is only one yellow colored jack so there should be no problem in identifying where to plug the composite video cable(yellow). Put the composite audio cables (red and white) to the DVD player Audio Out jacks (red and white). Then plug the other end of those cables on the back of your TV. Just make sure they are INPUTS on the TV and colored the same - yello/red/white.
Then find your TV's correct viewing channel. It is not channle 3 or 4. Depending on the TV brand, it may be called AV, INPUT, VIDEO, GAME, SOURCE, AUX, EXT., etc. To find that channel, you may need to check the instructions on your TV manual. Most of the time, there are buttons on the TV remote control or on the TV itself. Sometimes, you need to go into the TV Menu.
Posted on May 18, 2008
Replacement remote won't work VCR
The trouble is that vcr's are quickly becoming outdated and losing against the digital market. the only thing I can suggest is go to www.panasonic.com and contact customer support and the technical department to see if they can offer a resolution to the problem.
Jun 23, 2012 | Panasonic DMR-E75V DVD Player/VCR
Panasonic VCR/DVD combo - stopped recording sound
Seek tech support. This is not a self repairable work. Need technical skill.
Jun 02, 2012 | Panasonic DMR-E75V DVD Player/VCR
The eject function on the DVD works only occasionally. The VCR function works perfectly. What is wrong? Thanks. Keith
Usually this means that the DVD tray has dust and dirt build up on the underside of the tray or the belt maybe slipping.
Copy and paste this link in your web browser for a detailed approach of how to fix it yourself.
http://www.fixitclub.com/Electronics/DVD_Player.shtml?page=3
Feb 05, 2010 | Sanyo DVW-5000 DVD Player/VCR
My Sony DVD/VCR combo will play cds but not dvds. I took the top of the player off and I can see that the dvd spins but it won't play. It used to play everything very well but just stopped working...
Please clean laser lens with good quality cotton bud gently and check dvd disc playback, if still does not play, replace optical lens block.
Let me know model number of your Sony DVD-VCR combo to provide you optical laser block part number info.
Thanks.
Nov 15, 2009 | Zenith DVP615 Portable DVD Player
Unable to operate recorder at all.
When you are turning the recorder on it is blocking the signal for cable going to the TV. Your TV will need to be on channel 3 or 4 depending on what the dvd/vcr player channel output is set to. This is why your tv is asking you to re-scan. It is losing the video signal because the dvd/vcr is taking over. The reason why the vcr with the button on the remote is because the vcr button is changing the function of the buttons on the remote to vcr. Even though the dvd/vcr is one unit they still will act like two seperate components independent of each other. They have seperate power buttons and the dvd player part may need to be hooked up seperately with rca cables to work.
Sep 26, 2009 | Daewoo DVRS05 DVD Recorder/VCR
Technically challenged...need DVD to show on TV screen
hey 1st of all you gotta make sure that your son made tha right connections with the av cable (this is the cable with three different coloured pins) from your DVD to your tv. if this doesnt solve your problem then make sure you are using the correct av channel on your tv set that will allow you 2 play your DVD player because sometimes you cant play your DVD on thhe same av cannel you watch normal tv
Jan 01, 2009 | Pioneer DVR-520H DVD Recorder
DVD won't eject
I started loosing the screws and it started working after I shook it. No real technical explanation as to why it happened. Maybe a bad dvd rental?
Jul 27, 2008 | Samsung DVD-V3500 DVD Player/VCR
How to Hook Up Sanyo DVW 5000
TRY A DIFFERENT TYPE OF VIDEO OUTPUTS LIKE S-VIDEO, OR COXIAL
Jul 21, 2008 | Sanyo DVW-5000 DVD Player/VCR
Philips DVP5140 DVD Player Logo
64 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
