INSTALL A 2 MB RAM FOR MEDIAN PC MODEL 8030..
UP GRADE FROM 516. TO 2 GB RAM.. I WANT TO DO IT MY SELF.. HELP........ ALSO UP GRADE TO 500 GB HARD DRIVE... HELP...
  • 31 Answers
Most RAM today, is plug and play, would you know the specs of your motherboard?
Installing RAM, is something you should get someone at least semi experienced with Hardware to do, if you are then open your case, and you will notice 3/4 slots, one or more of these slots will be filled with RAM already, Providing you have enough empty slots for your new RAM, you can leave the existing ram installed or remove it - your call.
There are many helpful images here
It is basically inserting the RAM, the correct way around and clip it in. In the case of Installing another hard-drive or replacing your old HD, you will have several cables, The main ones are the power, and data pathing cable. Illustration here
Be careful not to disrupt any other devices/cables inside the machine and it should be good to go.
Posted on Mar 27, 2008
SOURCE:
Amount of ram Hp designjet 500 plus 24 inch and amount of ram support for Hp designjet 500 plus 24 inch.
According to the service manuals there is no memory upgrade for the 500 and standard memory is 16mb.. The 800 and 510 only have upgrade capability.
Apr 05, 2015 | HP Office Equipment & Supplies
Install or download the NBA 2k11 to my loptop
Hi xselenegonza!
Check your system specs and look if you pass the minimum requirements to run the game.
Minimum System Requirements:
CPU: Pentium 4 2.4 Ghz Single Core processor or equivalent (2.8 Ghz for Vista)
RAM: 512 MB or more (1 GB for Vista)
Disc Drive: 8x or faster DVD drive
Hard Drive: 10.5 GB or more free space
Video: DirectX 9.0c compatible (see below)
Sound: DirectX 9.0c compatible
Input: Keyboard or dual-analog gamepad
Video card with 128 MB or more memory and one of the following chipsets is required:
ATI x1300 or greater;
NVIDIA 6600 or greater;
DirectX 9.0c compatible card with Shader Model 3.0 support.
Important Note: Game requires Internet connection for activation
Recommended System Requirements:
CPU: 3 GHz Dual Core processor or equivalent
RAM: 2 GB
Video: Shader Model 3.0 support with 512 Ram (Nvidia(R) Geforce(R) 7900 GT or better)
Sound: 100% DirectX 9.0c compatible sound card
Input: Dual-analog gamepad
DirectX 9.0c or DirectX 10
For more info (Click here)
Sep 19, 2011 | Computers & Internet
HI, i was thinking about upgrading my laptops ram module for faster use, i am not all to computer savvy, i just play games and use the inernet. i was wondering how i would install the module and use it...
In laptops, (and some desktops) how much RAM you can use is dictated by how many slots exist to plug ram into. Also, by how many Gigabytes are supported by the motherboard chipsets.
For you... You probably have 2 slots for RAM. IF you have 1 GB of ram, it may be in 2 sticks of 1/2 a gig (500 MB each) plugged into the 2 slots. Or if you have 500 MB, 2 sticks of 250MB This is very common.
If you want to upgrade to 2 Gig, for example, (and may be the max for you) you must purchase 2 sticks of the correct type to install, and remove the existing sticks. You may be able to sell the old ones on ebay.. but hardly worth it for few dollars.
Most important is to reseach exactly what your laptop supports maximum and the correct type.
For more help, post a new problem with specific laptop info. Manufacturer, Model number etc.
Aug 10, 2011 | Computers & Internet
My printmaster 2011 gold won't install. what should I do
Installing printmaster 2011 gold on PC.
Windows XP (Home & Pro) SP3/Windows Vista SP2/Windows 7*
Pentium IV 1.6 GHz or better (2 GHz recommended) or comparable AMD Processor
1 GB RAM available (2 GB RAM or more recommended, 2 GB required for Windows Vista and Windows 7 users)
Available Hard Disk Space: Installation disc requires approximately 2.7 GB; downloadable content can require up to 36 GB of hard drive space
Internet connection required to access content 16 MB Video RAM (64 MB video RAM recommended)
DVD-ROM drive, keyboard and mouse
Monitor resolution:1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (Available at www.quicktime.com)
Java version 6 or higher required (available at www.java.com)
Recommended Additional Equipment:
Printer, Digital Camera
Macintosh OS X 10.4.8 or greater* (with the latest Java update)
PowerPC G4 500 MHz or faster (G5, PowerPC or Intel Mac--1 GHz processor or better recommended)
Available Hard Disk Space: Install disc requires approximately 3.0 GB; downloadable content can require up to 36 GB of hard drive space
1 GB RAM (2 GB RAM or more recommended)
8 MB Video RAM (64 MB video RAM recommended)
22 GB (hard disc space)
Monitor resolution 1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (available at www.quicktime.com)
*Administrator privileges are required to properly install the program on Windows XP, Windows Vista, Windows 7 and Mac OS X
Do your system meets the above requirement?
Nov 15, 2010 | Broderbund PrintMaster Platinum for PC
We have just purchased 18 wheels of steel bigbcity rigs. The cd installs but we cannot bring up any of the three games nor does it show an icon. The package states it is a pc dvd-rom. We are running...
Is Big City Rigs: Bus Driver by ValuSoft you are refering?
OS: Windows® XP/Vista
Minimum Requirements:
•Pentium® 1.7 GHz or similar processor
•512 MB RAM
•DirectX® Compatible Video Card
•128 MB Video RAM
•DirectX® 9.0c
•2 GB Hard Drive Space
•Mouse
Recommended Requirements:
•Pentium® IV 2 GHz or similar processor
•512 MB RAM
•3D Video Card with at least 256 MB Video RAM
•DirectX® 9.0c
•Mouse
Do your PC hardware specification (Recommened requirement) fit the above requirement needed to run the program?
If so, "Right click the setup and install the program as "Administrator"
Update your Direct X 9, to the latest version.
Hope it helps.
Jul 02, 2010 | Computers & Internet
Big city rigs
first check if your computer answers the following requirements:
Windows® XP/Vista
  • Pentium® 1.7 GHz or similar processor
  • 512 MB RAM
  • DirectX® Compatible Video Card
  • 128 MB Video RAM
  • DirectX® 9.0c
  • 2 GB Hard Drive Space
  • Mouse
  • Pentium® IV 2 GHz or similar processor
  • 512 MB RAM
  • 3D Video Card with at least 256 MB Video RAM
  • DirectX® 9.0c
  • Mouse
if you do, please tell me exactly what happens when you try to install the game
Jan 25, 2010 | ValuSoft 18 Wheels of Steel: American Long...
Using windows xp but want install windows 2007
the message might be either about your hard disk or mostly about your RAM size. for windows 2007 these are the basic requirements
  • 1 GHz 32-bit (x86) or 64-bit (x64) processor
  • 512 MB of system memory
  • 20 GB hard drive with at least 15 GB of available space
  • Support for DirectX 9 graphics and 32 MB of graphics memory
    if your system does'nt meet the req then upgrade it and then install the operating system
Aug 29, 2009 | Microsoft Windows XP Home Edition
Trekstor 500 gb. external hard drive keeps asking me to insert disk?
CHECK OUT THE RAM, IT WONT SUPPORT IF THAT IS BELOW 1 GB, ITS MOST LIKELY UR PC WILL HANG AND WILL NOT SUPPORT THE 500 GB EXTERNAL DRIVE.
Apr 05, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
80 people viewed this question
Ekse
Alun Cox
