Question about Garden
Need manual(s) for Jonsereds 49 SP chainsaw - Garden
3 Suggested Answers
  • 4088 Answers
SOURCE: how to adjust chain and bar oiler flow
The chain should be adjusted so that the chain can be pulled by hand fairly easily, but doesn't droop from the bar underneath. Oil flow should be set so that a running engine (chain moving fairly fast) will send a thin line of oil off of the tip of the bar (onto a piece of cardboard) with a few moments of running. Hope this helps!
Posted on Feb 27, 2010
Testimonial: "Thanks for advice about oil flow !adjustment needed I think !!"
dontbother10
  • 2220 Answers
Operators manual for a 2149 follows:
http://weborder.husqvarna.com/order_static/doc/JOEN/JOEN2002/JOEN2002_1018836-26.pdf
Oil adjustment is within.
If older than this it is not available without contacting Husqvarna (parent company) here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/customer-support/
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Testimonial: "Thanks for the web site addresses very helpful"
Jonsereds 361 chainsaw appears to have fuel feed issue. When I add fuel to carburetor will run till fuel is depleted, but will not feed from tank. Fuel line clear and fuel tank is full. What is next s
1st. make sure the gas oil ratio is correct
always shack saw and gas can before starting, this mixes the gas & oil to prevent clogging and helps starting. hope this helps
Oct 22, 2016 | Garden
Jonsered 2149 turbo , does any one know the factory settings fornthe carb ? Iv turned the H L in all the way waiting instructions , what about the idle ? Thanx
Yes I do. Do not over tighten the H and L needles you will ruin the needle seats (clockwise closes the needle jet, counter clockwise opens the needle jet) There is no air mixture needle on a chainsaw carb (2 cycle engine) all are gas mixture needles H - high speed operation, L - low speed operation. [The saw carburetor operates like a 4 barrel carb on a 350 chevy, runs on 2 but kicks in all 4 when you hammer it.] Turn the H needle to 1(one) full turn open (counter clockwise). Turn the L needle to 1 1/4 (one and one quarter) turn open (counter clockwise). NEVER EVER close the H needle to less than 3/4 open or the L needle to less than 1 turn open. If you do you will burn the saw up from lack of oil lubrication. [I have several Jonsereds saws a 52E, 451EV, 49SP, 520SP, 621 race saw, 630, 70E, 70E race saw, 80E and last but not least a 90E. I worked many years for the importer and distributor of Jonsereds as a Territorial Rep. All my saws run like a top. My newest saw is a 1984. I chainsaw carve and cut firewood with all of them year round. In short I like-em, they're the best.] I find that all my saws run the best and strongest with the carb set at around 7/8 turn open on the H needle and just above 1 turn open on the L needle. The idle screw I set last after the saw responds correctly to the carb settings. I quick throttle the saw to make sure the saw picks up RPM and doesn't fade out, put in a log to make sure it maintain tourque under load and not bogg down (tweak the H & L if needed, remembering the 7/8 - 1 1/4 rule I adjust the idle screw to where the saw sound smooth and un-labored at idle. I never let it idle to where the chain moves when it idles. For safety reasons. Hope this helps. EdN
Dec 06, 2015 | Jonsered Tecomec Chainsaw Chain Sharpner...
Carb adjustment on 670 champ jonsereds chainsaw
Initial setting is one full turn out CCW on both Low and High Side.
Mar 01, 2015 | Garden
What is the gas to oil mixture for a jonsereds 00
www.jonsered.com
download a manual for above link.
Sep 21, 2014 | Garden
My Jonsereds 70E doesn't seem to be feeding oil onto the bar, all holes are clear and has fresh oil
Check that you have not put the blade or blade guide in upside down.
The oil feed is a normally a gravity feed, If the machins is assembled correctly and all the passiges are poen it must feed. (even onto the floor when not in use.)
Jul 20, 2014 | Garden
Carbi settings on jonsered 49 sp
Bse settings will be L one and a quarter turns out and H one turn out, you will have to fine tune from there, they are both fuel screws so the more you turn them out the richer it will run, idle speed 3000 to 3200, max rpm 12000.
Jul 03, 2011 | Garden
How to adjust chain and bar oiler flow on a jonsered 49 sp chainsaw
Feb 27, 2010 | Garden
Garden Logo
610 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
