Question about Sony VAIO VGN-S150 Notebook
NO AUDIO DEVICE
MY AUDIO DEVICE NOT PERFORM ITS SHOWN NO AUDIO DEVICE. WHAT IS THE PROBLEM ??
  • 242 Answers
You need to install the drivers for the audio device.
Go here, download and install the driver.
Then it should work.
Suc6
Posted on Mar 28, 2008
How to hook up a denon avr -1706 receiver to a lg smart tv
When connecting your AVR-1706 to your LG TV, you will most likely be limited by the connections on your AVR-1706 as it does not have any HDMI capability.
In this case, depending on your LG TV, you would get the best video performance by using the component video connections from your TV to the Receiver. These are the one labeled Y, Pb, and Pr. These are special cables and you will need 2 sets if you want to run video out of your TV (perhaps you are using the internal tuner). Refer to page 6 of your AVR manual for the TV video inputs. Please note you will only use one type of input such as Component, S Video or Composite (descending order of performance). You must connect the Video Out from your AVR to the back of the TV's Video In as shown on page 6 as a minimum to get signals from devices other than the TV.
On page 12 of your AVR manual you can see the connections for TV outputs including the audio connections to the AVR. In the case of audio, you can either use Optical Digital (Toslink) out from the TV or coaxial (RCA) cables: Again in descending order of performance.
If you don't have the AVR-1706 manual handy, you can see it at the following link: http://a248.e.akamai.net/pix.crutchfield.com/Manuals/033/033AV1706B.PDF
Mar 02, 2015 | Denon Audio Players & Recorders
Intel R core tm2duo@E7500,2.93ghz 896mb of ram cpu
Check Audio Driver ?
- Control Panel --> System --> Hardware
- Device Manager
if the display is as above then the audio driver is not installed.
Dec 31, 2014 | Computers & Internet
Can't install audio output device
If you install the correct drivers and the audio device is shown as working, it should, unless it is faulty, work.
Try removing the audio device driver, installing the lates from the manufacturers web site and try again. It may be corrupt.
Feb 16, 2011 | Computers & Internet
After installing audio driver it is not shown in computer except add/remove programs
see in device manager,there was something missing.uninstall audio driver from there and then restart your system.after restart again you will go to device manager and from there you have to manually install audio driver...
Apr 27, 2010 | Intel DG31PR Motherboard
My Phone does not switch on.
Perform a hard-reset.
At the expense of your data-loss,
atleast you get your device working back.
To perform a hard-reset on your O2 Xda Atom,
Keep pressed the POWER key, and then perform soft reset. After the device this leave everything and confirm that you want to hard-reset as shown on the screen.
Please rate...
Sep 12, 2009 | O2 Xda Atom Exec Smartphone
No sound after installing Windows XP
install your original sound driver. don't install buetooth. sound driver first, bluetooth causing audio failure.
Jun 02, 2009 | Computers & Internet
My problem is my sound on my laptop toshiba satellite l40 18z does not work the icon show it is on but no sound is coming out
go to your control panel then to your sound options to see if the volume has been muted or is turned right down, also click on the audio tab, if its all greyed out then you device isnt installed.to get to your control panel go to your start menu then setting.
let me know me know how you get on
Sep 11, 2008 | Toshiba Computers & Internet
Acer 3003LC
in control panel - sounds, audio devices - and again in sonds and audio dev - audio .-default device , is there any device shown ? if not reinstall the audio drivers
Jan 23, 2008 | Acer Aspire 3000 Notebook
Mic
First, be sure to have the latest software from logitech's website, and the latest MSN.
Then perform the following:
Execute the audio and video setup procedure within MSN Messenger 7.5. This procedure will allow you to assign an audio input and audio output device, as well as assign the video device of your choice to work with MSN Messenger.
1. Launch MSN Messenger and select the “Audio and Vide Setup” option from the “Tools” menu.
Figure 1
2. Click “Next to begin the setup process
Figure 2
3. In the “Speaker Setup” window, select the output device you would like to use with MSN Messenger. This step is specific to speakers or headphones. If your speakers or headphone device is connected to your computer, select the device by using the drop down menu provided. You can also set the desired volume level and click “Play Sound” for an audio sample. Once you are comfortable with the your selected options, Click “Next”
Figure 3
4. In the “Microphone Setup” window, select your desired input device from the drop down menu provided. This selection will be specific to a microphone connected to your computer. If your Logitech video camera has a built-in microphone, this option will be presented as “Logitech Mic” with your camera model name in parentheses as shown below. If you have an external headset device connected to your computer which hosts a microphone, select the devices name or model number in the drop down menu. Once your device is selected, adjust the microphone volume level to your preference and click next.
Note: the microphone volume level may need to be tested in order to find a comfortable listening level for you contacts. As a starting point, try setting the level midway and adjust when necessary by re-executing this procedure.
Figure 4
5. In the “Webcam Setup” window, select the video device you would like to use with MSN Messenger. Once selected you should see a display sample in the window provided. You can also click the “Options” button to make camera specific adjustments. Once completed, click the “Finish” button to apply your changes.
Figure 5
6. Once you have completed this process, MSN Messenger should now know the audio input (microphone) audio output (speakers or headphones) and video device (webcam) to use when engaging in an audio and or video conversation.
Jan 07, 2008 | Logitech QuickCam Express Web Camera
Sony VAIO VGN-S150 Notebook Logo
178 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
