Question about Barracuda Networks Spam Firewall 300 (BSF300A3)
After updating , i cannot get into the firewall 300 with the name and password.
  • 88 Answers
usually after updating password should reset to the default. For your model it should be:
IP address: 192.168.200.200
Login: root
Password: ngf1r3wall
Cheers,
Mike
Leave rate if I helped you, thanks!
Posted on May 08, 2010
HOW TO CHANGE PASSWORD
Access your router by entering your IP address into the IP address tool bar at the top of the page. The linksys address is 192.168.1.1.You will be prompted to enter the user name & password. Enter admin for user name and admin for the password. It will probably update firmware automatically and you will now have unrestricted access to the system's utility software including change of password.
Jun 27, 2015 | Linksys RV082 10/100 8-Port VPN Router...
What is error code 011
That is usually a wireless router error , if you turn off the Firewall in the router it should update.
Dec 26, 2014 | Roku 2 XD Streaming Player 1080p (3050R
Is there a way to manually update barracuda 300 firmware
Download the latest firmware to your laptop.
Use an Ethernet cable to connect the laptop to one of the "wired" ports on the router.
Connect to the router's web-server interface.
Click into "settings" to find the screen that lets you update the firmware.
Select the downloaded file, and do the update.
Reboot the router.
May 07, 2014 | Barracuda Networks Barracuda Web Filter...
Cant connect to any web..
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver you might see a yellow question mark? This means you need to update the driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Jul 12, 2011 | Computers & Internet
Just bought new linksey wrt120n followed instructions to when you plug in. no lights come on at all tried different socket still no lights.
also
hope this helps
Jun 29, 2011 | Computers & Internet
Internet is not working .system is lenovo 8280 desktop
also
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
hope this helps
May 20, 2011 | Intel D865GBF Motherboard
Tell me how to turn on my wireless net.
also
hope this helps
May 04, 2011 | IBM Thinkpad 535X R51e-1843 R51e-1844...
Wil not get on the internet
also
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
hope this helps
May 01, 2011 | Computers & Internet
I forgot the password and cannot access the web interface of snom 300, version of firm ware is 7.3.23, I have tried to reset it but it again asks for password. I have tried user name as 'admin' and...
Your phone has two passwords, administrative and http. If you lose http but still have administrative you can fix this through the web interface as your are trying. If both are lost then you will have to reset the phone to factory defaults by using TFTP to update the frimware. Note that this will result in you starting from scratch with your configuration.
Here is the SNOM wiki article containing directions for doing this:
http://kb.snom.com/kb/index.php?View=entry&CategoryID=44&EntryID=32
Jul 02, 2009 | Snom 300 IP Phone
DynDns update fails
I have given a ref. configuration for you. If you could provide me the debug results it would be great to help you.
set dns ddns
set dns ddns id 1 server-type dyndns clear-text
set dns ddns id 1 username USERNAME password PASSWORD
set dns ddns id 1 src-interface untrust host-name HOSTNAME.dyndns.org
set dns ddns enable
Then try exec dns ddns id 1
Oct 09, 2008 | Juniper Networks NetScreen-5GT Plus...
Barracuda Networks Spam Firewall 300 (BSF300A3) Logo
536 people viewed this question
Top Barracuda Networks Computers & Internet Experts
David Payne
David Payne
Are you a Barracuda Networks Computer and Internet Expert? Answer questions, earn points and help others
