Question about Maytag Neptune FAV6800AW Top Load Washer
Beeps and beeps
The washer just beeps and beeps. Occassionally I have to play around with the buttons to get it to work, but it beeps during a cycle, powers on sometimes and starts beeping, beeps in the middle of the night. is this the control board? is this easy to replace if I order one?
  • mark_mirkovi May 12, 2010
    Thanks Rick. The warranty is not an option as I picked this up at an estate sale for $150. I will try to disassemble and check out the fittings, but I'm not sure if I will go through with the repurchase of the control board. After I posted this, I ended up on the consumer reports website and discovered that this model is quite problematic!! I may cut my losses and just look for another brand. I've used it for 6 months running 4-5 loads per week for a family of 4 and it keeps running... (although the beeping drives me crazy sometimes). I'll let you know how it turns out.
    btw... great detailed description of the work ahead of me. At first, I thought I was reading a text book, but after reading it a second time, I can imagine that the description was a bit challenging to describe.
    thanks again!
  • 526 Answers
Mark I’m an owner like you and I would try to DIY the fix. The Control board has a warranty period of 5 years. I buy all my parts such as this from e-bay. I have two with the LED FAV6800A consoles that work. You could call Maytag Customer service talk them to sending you a Control Board if you Control board is still under warranty. They did for me.
The Service Manual for reference. Sears Parts Direct for reference.
The Control Board is where I would start. I would inspect and reseat the Console Keypad connector to the Control Board and all the connectors on the Control Board. Follow the Service Manual for Console removal. Remove the 120VACwasher power cord from the service outlet
To ease removing the console from the machine I would remove the three number 15 Torx screws at the top of the console and the 5/16” sheet metal screws holding the back metal access panel. This would allow a bit more ease to unseat the console from the washer top then let it roll forward toward the front of the machine resting on the washer top.
See last Pic
Follow the Service Manual for Console removal. A lot of folks break off part of the retaining arms that slide fit to secure the Console to the washer top. With the sheet metal back off you can see these retaining tabs a bit more clearly and maybe not break them off. Standing at the back of the machine press in the left side of the console facing you (right side of the console if you are facing the front of the machine) to unseat while pushing to your right you may have to tap with the palm of your left hand the left side of the console to unseat from the slide fit retaining tabs. When the Console tabs release from the washer top roll the Console toward the front of the machine resting on the washer top. Sounds worse than it is, it’s just hard for me to describe.
See the broken slide fit tabs at the top of this pic to the left and middle tab. This was a e-bay buy and the owner had no clue how to remove.
To unseat/remove the Console ribbon cable from the washer Control board socket; be very careful here so you don’t damage the ribbon cable as you unseat. There is a retaining tab you have to unseat first and slide up the ribbon cable first. Press in the tabs on this ribbon cable retainer with your thumb and index finger release and slide up the cable as I show in the picks. Once the retainer is slide up the cable as shown gently pull the ribbon cable from the socket to unseat. This ribbon cable is single sided the black contacts look to be carbon deposit don’t scrape. But I would look for any corrosion on the contacts and socket that may bridge the contacts.
If the ribbon cable contacts and Control board look good reseat and power up the washer with the Console still resting on the washer top.
If still a no go then I would replace the Control board p/n 25001217 See Sears Parts Direct for look up
Try e-bay I have had good luck with all parts purchased.
http://cgi.ebay.com/MAYTAG-WASHER-CONTROL-BOARD-PART-25001217-/360249635600?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item53e08d3310
Your looking at $180 from most vendors but do what you feel is best for you.
Good luck and post back if you have questions........Rich
Posted on May 09, 2010
  • FAV6800A FAV9800A
    FAV6800A FAV9800A May 13, 2010
    Hey Mark,
    I understand if you were near the 19344 area I would hook up with you with a known good Control Board and give it a try. I get them off e-bay from owners parting them out. I have three working Control Boards plus three working FAV6800A’s in the house. A series 17, 16(my original), and 10. I repair for resale and I know the machine fairly well.
    I just did Outer Tub Bearing replacement and Spinner Assembly bearing replacement on the series 10 machine. If you get a quote for what I did you are looking at $450 to $800 on a 1$K machine.
    Bearings Tub Seal and Tranny O-Ring came to around $60 in internet purchases. The quote may not include Spinner Assembly bearing replacement. I really doubt any repair company or tech would do that but I’ll let them chime in for that response.
    The big killer for this machine is the Clutch and Left Hand Lid lock. Both are an easy fix if you have basic mech. skill sets and a desire to extend the service life of these $1K machines. Most owners don't dive in for the repair/maintenance. See the Clutch link post above for the dC/uC error problem which I bet most of the consumer report issues were referenced too.
    Anyway this machine is very easy to work on and repair if you have very basic mech. skills and I can pass on my hands on experience with the machine.... it's a hobby I'm just an owner. My skill sets are as an electronic technician.
    I also post under my new nick name FAV6800AWDIY I did the dh1200s response in error.
    Good luck…………..Rich
  • FAV6800A FAV9800A
    Sorry I diod post under FAV6800AWDIY to many irons in the fire...:)
Machine wont stop beeping
Press the beep button if you can see one. It would say loud, medium or off.
Apr 01, 2013 | Frigidaire FEX831CS Top Load Stacked...
Kenmore Oasis no error code keeps beeping low -loud
If its the main board that you are having an issue with, honestly i will suggest to get a new one instead, might cost you as much as buying a new one if you are going to have it repaired.
May 14, 2008 | Kenmore Oasis HE 27082 Top Load Washer
The washer stops and beeps at the rinse cycle. Clothes are not off balance. If I bypass the rinse it did spin until this week. Now it does not even turn on. Is there something wrong with the cold water...
If it is not turning on at all now when you press the power button then the main computer board has blown..OR The pump has blown..some models the power must pass through the pump before it will power the main computer board,if the pump is dead then no power will pass through it to the control board.Just to confuse you a bit more,the pump may have been on it's way out & thats why it worked occassionally but now i fear the pump has taken out the the main board with it.There may have been a slight burning spell leading up to the machine stopping altogether,that would have been the pump cooking.New pump & computer board around $400 aus dollars,done by technician.parts around $200-$250
May 22, 2010 | Fisher and Paykel GWL11 Top Load Washer
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
3 quick beeps during cycle if you can get it to stay in a cycle
MY KENMORE OASIS HE IS DRIVING ME CRAZY! THE CYCLE SIGNAL CONTINUES TO BEEP AT LEAST 25 TIMES, STOPS FOR MAYBE 20 SECONDS, THEN BEEPS AGAIN ABOUT 25 TIMES. THE WASHER WORKS GREAT, BUT IT WILL NOT STOP BEEPING! HELP!!!!!
Sep 13, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
GWL11 Machine adds water during spin cycle and leaks on floor
diverter valve is not switching to pump the water out. instead it is resurculating back into the tub.
Oct 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
346 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
