Question about Whirlpool LHW0050PQ Front Load Washer
My Electrolux "Kelly Ripa" washer just completed a load, but did not unlock the door. How can I get the door open? The manual was no help.
  • 530 Answers
Check inside your pump filter first see if there is anything in there....this might be causeing your door to stay locked
Posted on May 15, 2010
Electrolux front load washer door won't unlock. How do I get the door open? Model number: EIFLW55HIW0......unplugging didn't work
Disconnect power supply. Remove top panel.
Now is door lock accessible. Open door, remove door gasket from housing (not from tub), remove two screws and replace door lock.
Dado
Mar 02, 2017 | Electrolux Washing Machines
My Electrolux front load washer door will not unlock
Unplug the unit wait a minute than replug ,should open
Apr 04, 2016 | Electrolux AWF 1435 Front Load Washer
The timer on my electrolux front load wont go to zero and allow the door to unlock
Good Morning friend, thanks for your inquiry!
Based off the information you have provided your Electrolux frontload washer the door will not open and the timer is stuck. I would recommend performing a reset on your washer and you can do that by unplugging the power cord or flipping the household circuit off for ten minutes. If that does not help to resolve your issue I would suggest consulting with a professional technician for an accurate diagnosis. It could be a potential problem with your control panel or door latch assembly. I hope this information is helpful. -Matt
Oct 21, 2014 | Electrolux Washing Machines
Electrolux front loading washer door will not open
Good Morning Nancy,
I understand that the door will not open on your Electrolux washer, model# EWFLS70JSS0. I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and the door should unlock. Try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Electrolux Washing Machines
Electrolux EIFLW55HMB Front-Load Washer With IQ-Touch controls won't open
Try unpluging for a few minutes . wake the washer up by turning knob then at the same time press and hold start cancel error will display . take off top and you will find a tech sheet on left side and that should help. you can manually unlock the door after taking top off and reach down to door lock you will feel a plastic switch to pull
Feb 17, 2013 | Electrolux EIFLW55HMB Front-Load Washer...
My kenmore elite he3t front load washer door will not unlock
If there is water in the tub, it will not unlock. There is a pump filter that becomes plugged that you can access from the front by removing the lower panel. It unscrews and allows to be cleaned out. If still no luck, there is a release at the bottom of the door lock to open the door manually.
Kelly
Mar 24, 2011 | Washing Machines
2009 Frontloading Electrolux washer door will not open!
When this happened in our home, we unplugged the machine, waited then plugged it in again. This reset the machine and the door immediately unlocked
Feb 18, 2010 | Electrolux EW1000i Front Load Washer
My front load washer has the door lock stuck and the door is open
When this happened to our front loader washing machine, we had to unplug the appliance, wait, then replug it to reset and unlock the door.
Feb 10, 2010 | Electrolux EW1000i Front Load Washer
1 month old electrolux FL IQ cuts off and won't restart
If it is only one month old then you should be covered by the warranty ??
To unlock the door place the drain hose in a bowl until the water comes out, if it wont then try blowing down the hose.
If you hear bubbles inside the machine then dump the hose back in the bowl
Once the water has all ran out switch the machine programmer to "off" and then try the door
May 31, 2009 | Electrolux EIFLW55HIW Front Load Washer...
Electrolux front loading washer - door is locked, won't unlock
I have an Electrolux front loading washer. I just got done washing a load of laundry and the door will not unlock. I tried washing it for a second time thinking maybe it would open again. No luck.
Nov 09, 2008 | Washing Machines
Whirlpool LHW0050PQ Front Load Washer Logo
200 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
