Question about Goodman CLJ24AR32 Air Conditioner
Fan started running backwards
I aquired a mobile home and the previous owner said the AC was going backwards. Is there a particular part which would cause this problem?
  • Goodman Master
  • 8,220 Answers
If the motor is a replacement one then it has small wires that can be switched or a plug you flip to reverse the direction.
Posted on May 08, 2010
The hood fans seem to be running backwards. how is that possible on an ac motor?
any ac motor can go in reverse. The direction is chosen by the direction of the start winding. reverse the polarity of the start winding where you see the 2 extra crimp connectors where you wired the motor just swap them
Nov 27, 2013 | Kenmore Kitchen Ranges
Why do we run ceiling fans backwards in winter with a heatpump
That question cannot be answered as stated. What direction is backwards and what is the pitch of the blades.
The theory now mostly dis-proven is you pull the hot air off the cealing in the winter to help warm the home. The opposit is valid in the summer. The amount of energy used is normally more then what is saved in the AC bill.
Oct 24, 2013 | Hampton Bay 24002 Ceiling Fan
Where is the oil filter located on my 1999 buick lesabre
go to your local mall seek out this buick and aquire it go home pillage through the previous owners belongings groceries lingerie ect.. then focus on replacing the vin metal tag with a rivet gun bought at your local; autozone sold to you by some know it all over grown pair of bug nuts that on any other day you would not trust this s.o.b. to change a bandaide on a baboons ass.enjoy your newly repaired do it yourself project.Enjoy your ride
Dec 01, 2012 | 1999 Buick LeSabre
My condenser fan is running backward
An abrupt cycle of power can cause a motor to run backwards. If you turn the power off again and wait 10 seconds or so (enough for blade to stop spinning) it should run the right way. Put the capacitor back the other way and try again.
Apr 23, 2017 | Heating & Cooling
The mobile home furnace back drafts when exhaust fans are running.
It almost sounds like the blower motors, have somehow reverse polarity and are running backwards. Strange as it may seem, it's possible. Also, check for and remove any obstruction in the flue pipe.
Apr 21, 2011 | Heating & Cooling
Car turns on ok gets overheated quickly only the motor fans spins the ac fan does not the water pump looks to be working fine theres coolant in lines and they not collapsed i replaced relays and thermostat...
you know the water pump for that particular car is on the other side? is driven by the cam... either your water pump is not working,(to remove water pump you need special tool) did you change the termostat? temp. sensor?
Mar 28, 2011 | 1998 Cadillac DeVille
AC fan running backwards
Check to see if it has some wires for reversing the direction. Some have four wires you can switch around to change the direction. If not make sure the capacitor is connected to the start connection and not the run connection. The wires for reversing the direction should be orange and yellow or purple and yellow and will be shorter than the rest. Hope this helps. Let me know what you find.
May 20, 2010 | Goodman GPC1342H21A Air Conditioner
Ourside AC unit fan runs backwards after repair
call them back the tech should have seen the fan was running backwards talk to the owner. an electrical surge can hurt the motor, don't be surprised if this is the case. Charges are in range. We are professional mechanics.
Aug 05, 2009 | Heating & Cooling
Duo-Therm AC does not work
fan motor is possiblely bad but start with the capistors in the run box on the roof remove cover you will see where all the wires go onto a metal or plastic box depending on age of unit remove acess cover peek inside and see if you see a exploded capistor ie: i see smoke comming out of my ac capsitor are easy to change but they can kill you they store a lot of energy and are dangerous if you are not careful with them
Jul 18, 2009 | Dometic Rooftop RV Air Conditioner
Goodman CLJ24AR32 Air Conditioner Logo
65 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
