Question about HP Pavilion dv9005us Notebook
There was a flicker in power-- the laptop was on but would not connect so I shut it off 5 min later I tryed to bring it up-- but nothing shows on the screen tryed several times (the dash lights come on no LOGO on screen HP DV9005us Is the mother board burned out?????? Vnzarka@verizon.net
Try the battery removal/re-install approach. remove battery, hold power sw down for 40 seconds with power cord connected; replace battery. Works for me.
refurbman
Posted on May 09, 2010
Dell Studio 1558 - No post/boot
maybe is the hard disk... u must try to log in with a live usb linux (or windows or hirens boot cd ) and watch if it logs.. if u want to check fan if its covered of dust ill let u a link of how to open it http://www.youtube.com/watch?v=Hn_RX56oGqI
Feb 28, 2013 | Dell Studio 1558 Notebook
HP Pavillon dv62030ez No more start up. Fan and lights get power for a second, then nothing. Think thr BGA doesn't fit any more, due to overheating.
Hi
This may be a problem with the bios. Try to reset the bios. follow the below procedure
1. remove the main battery
2. remove any USB cables etc., if connected
3. hold the power button for 15 secs.
4. reconnect the power adapter (Do not install the battery yet)
Later if the system starts well then shut down the Laptop and install back the battery and connect the charger and start the Laptop again
If the above will not solve the problem then follow the next step
1. Remove the power adapter and the battery
2. Open the back side cover where the Memory is installed.
3. remove the BIOS battery
4. leave the laptop for a while may be 10 mins.
5. Now connect the BIOS battery back
6. System will automatically start do not press the power button
7. set the date and time
8. Shut down the Laptop
9. Start normally back on.
DO RATE MY SOLUTION
Saleem
Jun 30, 2011 | HP Pavilion dv6000z Notebook
I have a dell latitude laptop my problem is, it takes over 5 minutes to power off. I click shut down screen goes to desktop screen no icons about 5 minutes later it says its shutting down screen goes black...
There may be nothing running in task manager that you can see but there is still something running,My advice is to take it to your local Geek Squad or preferred computer tech you most likely have a virus that is slowing down your computer process.
Sep 24, 2010 | Dell Latitude D531 Laptop Computer PC...
Suddenly my wireless will not stay connected. I get online and in less then five mins. , as I try to go to a different website, nothing happens. Using firefox, will show loading then go to server timed...
Go into your "router" configuration under wireless, change the channel it operates on. It is possible some new electronic in your house or neighbor is causing signal interference on that channel causing you to drop your connection periodically.
Feb 03, 2010 | Gateway MX3560 Notebook
HP G6000 laptop wont start
Extract your battery from your laptop for 12 min, then start your computer using your power cable (don't use your battery), if not try pressing F2 rapidly when opening, after you open your operating system try changing your graphics card drivers.
Jan 31, 2010 | HP Pavilion dv6000z Notebook
Laptop wont power up
This is what I would do before chalking this thing up as a hard ware failure try connecting thie to another adpator if that then does not work you indeed got a HW failure with the laptop and the motherboard would likely need to be replaced, Get it evaluated by a technition the geek squad at any best buy wull be able to test this real quick for you do not loose a good laptop over a faulty adaptor trust me this is where the issue could result.
thanks and please do leave postive feedback, ratings for your free naswer today.
Nov 17, 2009 | Advent Netbook
Syncrowave 180 sd. I was welding when it shut
Sounds like a bad thermister on the rectifier or a bad control board.
Aug 12, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
My Dell latitude Cpx laptop just does not power up, just flickers
I had the same problem on my CPx. It turned out to be a bad memory module. With bad (or no) RAM, nothing is going anywhere, so it immediately shuts down. New memory, no problems.
Jan 09, 2009 | Dell Latitude CPX Notebook
Flickers on cold startup after 5 min then goes away in 2-3 min.
I had same problem. Tech's said the power was noisy. I cleaned up the power but the TV still did exactly as you describe. Problem will progressively get worse with longer bouts of flickering. I was under warrenty and sent the TV back. After 3 months I am still waiting for a repalcement.
Jan 12, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
HP Pavilion dv9005us Notebook Logo
93 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
