Question about RCA D52W19 52" Rear Projection Television
RCA 052W15/52IN. REAR PROJECTION TELEVISION AND MY CABLE CONNECT BROKE OFF HOW CAN I FIX THIS PROBLEM....
  • 57 Answers
Solder with solder iron.
Posted on May 09, 2010
Cable connector broke off
You should be able to get a replacement Small signal board from www.tvrepairworld.com
Nov 15, 2011 | RCA HD52W59 HDTV Projection Television
We have a RCA D52w19 rear projection tv. It appears that the HD feature is not working. My Wii does not recognize it as HD and the picture for Wii, satellite and DVD is noticeably grainy. Is there an easy...
The Wii is not a HD output source. It only displays 480p. If you wish to connect an HD source, you must connect through an HDMI cable or a component Cable. HDMI is better.
Feb 28, 2011 | RCA D52W19 52" Rear Projection Television
Our RCA D52W19 TV is playing in standard 480dpi (Satellite, DVD, and Wii). How can we get it to play at 1080dpi, like it used to?
Yea i have a 52 in rear projection hdtv and i went to move it and the cable piece itself broke off and now the tv power light blinks three times and jus shuts off how can i fix that
the cable connector being broke more than likely has damaged the tuner. sometimes the tuner can be rebuilt depending on the damage. since the set is shutting down there may be more damage. if the set stayed on you might be able to bypass it using vcr. the worst case the small signal board might need replaced that cost aroun 300
Oct 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA D52W20 that I connected to my PS3 with an HDMI/DVI Cable. The display is fine in 480i. However, No sound is coming from the TV.
This is normal my friend. A dvi port can't use audio even if it is using a hdmi cable. A easy fix is to connect your A/V cable into your ps3 and connect the red and white cables next to your dvi cable or connect it to your stereo. After that go into your setting, go to audio setting, click on audio output, and select A/V cable. it should work after that.
Mar 26, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
The coax connector broke off on my rca d52w20 how can i fix it
you can take it to a repair shop to fix or the easiest way is to use a different input. try using the rca cable connections (the red, white, and yellow) to run from the cable box to the tv
Oct 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
The coaxle broke where you put the cable line on
The coaxial connects inside the set to the tuner. It needs to be resoldered in to the board & secured on the outside to the tuner. Its a quick fix at any tv repair shop. Unless u tried stick something inside & damaged internals of tuner
Apr 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDTV #D61W20, CHASSIS ITC222, PUSH & TWIST CAP ON HV CABLE
do you have the part number for the flyback ? I need it if you would please. send it to
swampbiker@hotmail.com
thank you
Apr 01, 2009 | RCA D61W20 61" Rear Projection Television
Cable plug broke off
Well first repair the coaxial cable going to your antenna. There is no way you can use RCA cables as a substitution for coaxial cable. They have totally two different properties. You can use the coaxial and feed it to a VCR/DVD player where you can output the signal with RCA/composite cables. Basically, use your VCR/DVD player as a tuner for your TV.
Sep 20, 2008 | RCA D56W20 56" Rear Projection Television
Broken cable connector
the easies and cheapest way is to use the audio video input. pulg the cable into your vcr & use the vcr to change channel. the other way is to replace the tuner, typically tuners sell for around $75.00 to $100.00.
Oct 29, 2006 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W19 52" Rear Projection Television Logo
49 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
