Question about Kenmore 74602 Gas Dryer
Dryer is not heating and vents are all clear.
  • pgmiller55 May 10, 2010
    Thank you so much! It might be the solenoids because the dryer does heat when you first turn it on. Then as it cycles through it doesn't heat again. You can wait awhile, turn it back on and it will heat again, for a short time.
  • Dan Webster
    Dan Webster May 11, 2010
    Do you hear any clicking? If you do then power is getting to the ignitor and the sensor is working, so that leaves the solenoids as suspect. They will work a little then get hot and quit. Then take a long time to cool down and work a little more, making it a hard thing to diagnose. If it clicks you oughta have fire otherwize andless you ain't paid the gas bill. If you DON'T hear any clicking then power ain't getting to the gas assembly and that means a fuse is blown.Kenmore duct fuses look like this on some models but on other models they are behind the filter bladder and look like this
  • Kenmore Master
  • 8,220 Answers
Thanks :D
Posted on May 10, 2010
  • 1,476 Answers
You need to determine if the gas is turning on. If it is not then it will not heat. If you go to http://www.repairclinic.com they have videos which will walk you through the process. First you should make sure that the gas is turned on and present. If it is then either the gas is not being turned on or the igniter is bad. There is also a sensor which makes sure that the gas valve has opened. It would be advisable to check that. Let me know if you need more help. Thanks for using FixYa and for the great rating.
hardrocko
Posted on May 09, 2010
Testimonial: "Thank you so much. I really appreciate your response."
  • 184 Answers
SOURCE: Dryer doesn't heat.
THE FIRST THING TO CHECK IS YOUR POWER. THE OUTLET HAS TWO ANGLED HOLES THAT SHOULD TOTAL 240VOLTS ACROSS THEM. THE L SHAPED HOLE IS THE GROUND AND THERE SHOULD BE 120VOLTS FROM EACH ANGLED HOLE TO THE L SHAPED HOLE. THE DRYER'S MOTOR ONLY RUNS ON 120 VOLTS ( FROM ONE ANLGLED HOLE TO THE L SHAPED HOLE). THE HEATING ELEMENT CIRCUIT RUNS FROM ONE ANGLED HOLE TO THE OTHER(240VOLTS)
THE DRYER WILL RUN BUT NOT HEAT WITH ONE SIDE OF THE CIRCUIT BREAKER TRIPPED.
IF POWER IS O.K., THE NEXT THING TO DO IS PULL THE BACK PANEL OFF OF THE DRYER. THE HEAT ELEMENT IS IN A BOX ON THE RIGHT SIDE WITH TWO RED WIRES GOING DOWN TO THE BOTTOM OF IT. IF YOU HAVE A METER, CHECK FOR 240VOLTS AT THE TWO WIRES ATTACHED TO THE BOTTOM OF THE HEATER. IF YOU HAVE
240VOLTS THERE, THE HEATER IS BAD. IF NOT, THE ROUND ITEM NEAR THE BOTTOM IS A HIGH LIMIT THERMOSTAT. IF YOU HAVE 240VOLTS AT THE TWO TERMINALS ON THE THERMOSTAT, IT IS BAD. PART #
279769 COMES WITH THE HIGH LIMIT THERMOSTAT AND THE THERMAL FUSE FOUND AT THE TOP OF THE HEATER ASSEMBLY. CHECK THE THERMAL FUSE THE SAME WAY.
IF IT IS BAD, YOU WILL SEE 240VOLTS ACROSS IT.
IF ALL THOSE COMPONENTS ARE GOOD, IT COULD BE THE TIMER, TEMP SELECTOR SWITCH, OR THE MOTOR'S CENTRIFUGAL SWITCH. YOU WOULD HAVE TO READ THE WIRING DIAGRAM INSIDE THE CONTROL PANEL TO CHECK THOSE ITEMS.
Posted on Apr 03, 2008
  • 70 Answers
SOURCE: no heat, dryer exhaust vent cleaned, still no heat, gas line is on
I think you have a gas dryer, and a bad ignitor.
Posted on Apr 23, 2009
  • 15 Answers
SOURCE: Dryer air heats up but does not dry the clothes. Just replaced the timer but did not fix the problem. Air vents are cleared.
One of two possiblities:
1. Dryer vent is blocked - check the air coming through the outside vent
2. Blower Fan is clogged - remove the lower front panel and clean out the fan wheel
Posted on Apr 30, 2009
apart4u
  • 213 Answers
SOURCE: dryer not heating
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Posted on Jan 13, 2010
  • 1531 Answers
SOURCE: Not Heating
there could be a problem with one of the thermal fuses located in the cabinet under the drum and along the side of the heating element can. the first one to check is the one furthest back on the can.
you can check them all for continuity and replace the one that is bad also check the heating element last.
Posted on Feb 23, 2010
Kenmore Elite Oasis ST electric dryer does not heat
You need to replace the heating coil that is usually the problem when you get air and and the tumbler is moving but no drying you can also check the lint catcher and clear out your dryer outgoing vent remove the hose check the dryer vent where the vent hose is connected and the vent going outside the house before changing the heating coil .
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
Too long to dry my clothes
HI,
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Jul 01, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryer taking to long to dry cloths, all vents are clear
sometimes a element that heats the dryer breaks giving it only power till were it broke /then will cause no or very little heat these run about 30-34$ depending on what type of brand of dryer you have
Apr 10, 2010 | Maytag PYE2300AY Electric Dryer
Dryer wont heat and check filter light is on but filter in dryer is clean?
This could be caused by a venting restriction. These dryers have sensors built in to check airflow temp differences. Take the vent off the dryer and run it and see if it heats. If it does then you know the problem is with your venting. You will need to either clear the vent or replace it.
Hope this helps _MJ_
Feb 01, 2010 | LG DLG5932W Gas Dryer
Apr 16, 2009 | Asko T701 Electric Dryer
Dryer not heating up
Could be the heating element?
Jan 12, 2009 | Dryers
Dryer not producing heat!
Make sure your vent screen is clear of lint, You should also check the actual vent duct which comes out the back of the dryer. It sounds like there is blockage of dust and lint which is not allowing the dryer to properly heat up.
Dec 18, 2008 | Dryers
Frigidaire dryer heats but clothes not drying
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
Nov 23, 2008 | Frigidaire GLER642A Electric Dryer
Dryer heats slowly
When dryer heats too slow, that means that there is a problem either with the heating element, the thermostat, or the vent.
See the following suggeations from Repairclinic:
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Oct 04, 2008 | Whirlpool Dryers
Whirlpool dryer not enough heat
There may very well be a clog in the vent line. Check the vent to be sure it is clear. Make sure to check the outside vent cover. Some of these vent have screen/louvers that can get clogged.
Jan 02, 2008 | Whirlpool LER5636P Electric Dryer
Kenmore 74602 Gas Dryer Logo
944 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
