Question about Car Audio & Video
Changed speakers in 2003 chevy pickup now door windows wont work
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
Will they move at all or act likes their is no power? If your windows move a lil up and down sound like your new spearker are to deep
Posted on May 09, 2010
2003 chevy impala starts anti theft comes onput in gear dies wont do nothing
My impala did same thing and then would not start. I suspected anti theft problem I then had chevy dealer change ignition switch. It fixed problem second time I wasn't going to pay $ 750 for so I bought $40 dollar switch on ebay. It was an easy job following great video on you tube. When I went to start car it would not go. While doing relearn procedure (hook up battery charger before starting procedure) I got very tired of door chime so I found it was coming from left front door speaker. I removed wire to stop chime. When i went back to relearn procedure car started right up. I have a steady security light on but car has run fine for months. If you cruise and heater fan has also stopped working add wire from switched terminal on ignition switch to power feed wire on heater. It fixed both problems on mine.
Oct 25, 2016 | 2003 Chevrolet Impala
Window wont go up or down on my 1994 chevy pickup 1/2ton passenger window
Check wiring where door flexes. copper wires repeated bending can break.
Overload breaker points stuck - is inside motor.
Burned smell - replace motor.
Bad door switch - my rear window would freeze shut. trying top open would damage switch. Mine was driver door master switch.
Apr 21, 2014 | 1991 Buick Park Avenue
My drivers side front speaker stopped working in my 2003 dodge ram pickup
remove the speaker from drivers side , put that speaker in passengers side , if works in passenger side then speaker is o.k and if not speaker is stuffed if working wiring problem in drivers door or from stereo head unit .
Mar 28, 2014 | Dodge Ram 1500 Cars & Trucks
My automatic windows wont roll down
Click the link below to troubleshoot the problem:--
Power windows not operating?http://whoisbyme.blogspot.in/2012/05/car-window.html
Thanks.
Jun 07, 2012 | Spyder 03-05 Chevy Silverado Vertical...
My 2003 Chevy Trailblazer drivers side door got wet from rain. Now the window switches wont work on driver door but everything else will. How do I fix this?
First check fuse #10 in the rear fuse panel, if fuse is OK, the Driver's Door Module (DDM) is probably bad due to water intrusion. You could try swapping in the module form the passenger side to verify.
Oct 18, 2011 | 2003 Chevrolet Trailblazer Ext
Power windows wont work
2003 chevy tahoe , none of the switches on the driver door works, mirros, door, locks.
Oct 02, 2009 | 2003 Chevrolet Tahoe
Pwr window problem with '91 chevy pickup
look for pinched wires behind the heater box that go from door to door
Jun 27, 2009 | 1999 Chevrolet Silverado 1500
Drivers door panel removal
The book says 1. remove power accesory switch panel by using suitable flat blade tool at front. 2. Disconnet electrical connections.
3. pry door handle plug by using small flat bladed tool
4.remove door trim handle mounting screws
5. remove door trim panel from retainers.Start at rear bottom corner and pry outward.
6. remove door panel.
KD does make a tool that will properly pry the door panel away from reainers. KD 3705 You might get by with a screwdriver.
One other thing you may need to have the window down to get the panel to come off. You will have to lift up on it once it is loose from the fastners.
Hope this helps you out.
Mar 23, 2009 | 2003 Chevrolet Malibu
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
