Question about GE Spacemaker WSLP1100D Top Load Washer
GE SPACEMAKER WSLP1100D0WW WASHER
We have to replace the Drain Pump Assembly on our GE Spacemaker Washer. Is this fairly simple to where my husband can do this?
Thank You!
3 Suggested Answers
SOURCE: hi, my GE Spacemaker WSLP1100D0WW Top Load Washer
I've just had this same problem and successfully fixed such problem. I had to set the washer on blocks and crawl underneath while the wife was turning the washer on spin cycle for a few seconds. After following the leak I discovered the drain pump assembly was cracked. Some epoxy and a day of curing / drying cut the leak out like a charm. I also went ahead and ordered a new drain motor while I was at it and installed.Good luck!Davejr021@yahoo. Com
Posted on Feb 10, 2011
This is the second time the exact same thing happened.
It's caused by a coin getting into the drain, and after the motor continuously slams it into the inside of the drain assembly, it wears thin and finally cracked. Exact same 1/4mm spot both times.
I replaced the entire part last time. This time I'm going to repair it with 2 part epoxy as well.
Posted on Jul 08, 2013
My GE spacemaker top loading washer GUD27ESSJ0WW won't drain.
Most likely the drain pump is plugged with a soak or other small item.
Jun 19, 2017 | GE Washing Machines
GE spacemaker Washer Dryer Combo don't drain properly?
Check the drain hose for obstructions. Is it being pinched where it goes over the top of the drain pipe behind the washer?
The pump may be going bad...
Jul 29, 2014 | GE WSM2700W Unitized Spacemaker Washer and...
GE Spacemaker Washer Tan does not spin or drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | GE Spacemaker Washer and Dryer Electric...
Hi, my GE Spacemaker WSLP1100D0WW Top Load Washer is leaking from the bottom during the drain/spin .. Any ideas how to fix this? Thanks
Jan 15, 2011 | GE Spacemaker WSLP1100D Top Load Washer
My spacemaker will not drain or function in spin cycle
Hello & Welcome to FixYa
When the unit is unable to drain it will not even work in spin cycle, the problem is with blocked drain/drain pump filter which should be cleaned. If after cleaning the problem comes back then the drain pump needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 03, 2011 | GE Spacemaker Washer and Dryer Electric...
Washer won't spin and empty the water out of the
Shirley, it may be the drain pump is obstructed or possibly the lid switch is broken. If you washed bath mats or rubber backed rugs recently i would go for the pump. If you washed a semi bulky item with a tendency to float I would go for the switch.
Get me a model number and I can help you with dis-assembly if you'd like further help!
Jun 11, 2010 | GE Spacemaker Washer and Dryer Electric...
Spacemaker spin cycle problem
you may have something stuck in the drain pump......
first try using a wet/dry vacuum attach it to the drain hose and try to **** out what ever you have stuck in there... if that works you are good... if not you will have to get open the cabinet to get to the drain pump
Dec 23, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Washer will not drain
I just repaired one that had a needle stuck in the pump. Take the front cover off and the pump is in the lower left corner. Remove hoses and pull pump out then dis assemble pump and clean out.
If that does not do it you have to replace the pump.
Jul 23, 2008 | GE WSM2700W Unitized Spacemaker Washer and...
Washer does not drain water
Make sure the drain hose is not kinked
Dec 27, 2007 | GE Spacemaker WSLP1100D Top Load Washer
GE Spacemaker WSLP1100D Top Load Washer Logo
611 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
