Question about Oreck Super-Deluxe BB870AD Bagged Canister Vacuum
Keeps overheating My vacuum keeps overheating and shutting off.
Where is the fuse located on a dirt buster vacuum cleaner?
Black & Decker Dirtbuster Vacuum Cleaner
no fuses in these ....double insulated
the motor has a thermal protection shut off when overheating
will start again when cooled down
empty bag often
if unit keeps shutting down replace vacuum
2477301-black-and-decker-dirtbuster-vacuum-cleaner-0-bwbjq1d2inqbxh534mfqkm1n-3-0.jpg
Apr 29, 2017 | Vacuums
Possible problem with thermal indicator?
Remove all filters and the dust bin and leave the vacuum motor run for a while. If it does not shut off it may mean your filters are clogged and need replaced. Even washable filters should be replaced frequently because they become clogged and restrict the airflow. You can't always tell if a filter is clogged by looking at it.
Jan 26, 2014 | Hoover U5507900 Elite Rewind Bagless...
Keeping turning off
overheating ? blocked filter ?
Dec 23, 2013 | Dyson DC34 Handheld Vacuum
Hoover uh70035b
If it shuts off after being used for a whirl and won't come back on for a while it is probably overheating. The heat sensor shuts the machine off and won't let it turn back on until it cools down. If this is the issue it could be the filters are clogged and not allowing enough airflow to keep the motor cool. Most bag less vacuum filters should be replaced frequently even if they are cleaned regularly.
Oct 30, 2013 | Vacuums
My dirt devil keeps shutting off randomly
It's overheating. Empty the cup and replace the filters. There's a breaker that opens up and turns it off when it gets too hot. When it cools down it closes back up and it will run again. It'll argue with you til the end of time or until you fix the problem.
Good Luck
Jan 13, 2013 | Dirt Devil M085805 Upright Vacuum
Why does my DC17 Animal vacuum keep shutting off?
Hi Emmeline,
I'm sorry to hear you're having difficulties with your DC17. From what you've described, it sounds as if the thermal cutout feature is shutting the machine down to prevent overheating. If you've already tried washing the filter and are still experiencing the issue, I'd encourage you stop using the cleaner and to contact us directly so we can help. You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Nov 16, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Miele vacuum cleaner keeps overheating and shutting off. It is only possible to use for about fifteen minutes at a time
Hi Lauren, how do you know if it is the circuit board? (the speed control buttons still work).
Mar 13, 2011 | Miele Vacuums
Why does my vacuum cleaner quite working about two minutes into vacuuming? It just shuts off. I have the pet fur picker upper version
Sounds like overheating of motor operating a thermal cut out ..Clean all filters you can run machine with no filters fitted to try if okay first.....
Jan 31, 2011 | Hoover U5753-900 WindTunnel Bagless...
It keeps shutting off every two minutes or so. Its only 7 months old and seldom used.
If this is a bagless vacuum then you might have some filters that need cleaning or you have a clogged airduct in the machine that will not allow it to breath cooler. The motor is overheating and shutting down because it can't breath.
Nov 26, 2009 | Kenmore Vacuums
HOOVER WINDTUNNEL SELF PROPELLED OVERHEATING AND SHUTTING OFF
It sounds like it is overheating because of a blocked flow of air that keeps the motor cool. Check for a blockage from the area of the
roller brush through the hose to where it goes into the bag.
Tom
Oct 22, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Oreck Super-Deluxe BB870AD Bagged Canister Vacuum Logo
53 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
