Question about Jenn-Air 24 in. JDB1090AWS Stainless Steel Built-in Dishwasher
Not cleaning dishes well any more
Our Jenn Air dishwasher is starting not to clean well. Only one year old. It is leaving residue and ground up food on the dishes. The wash used to be very good but it is no longer washing well at all. It is quite nasty, please help
  • Jenn-Air Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
54dyhjh
Posted on Sep 29, 2010
My Jenn- Air dishwasher (2 years old) used to clean great but now it is leaving a white film on the dishes and there is often residue left in the glasses as if it is rinsing with the dirty water. I can't...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 20, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
My Jenn-Air dishwasher, Model #JDB1100AWW, is now not cleaning the dishes well. We have had it for approximately 5 years and up to the last several weeks, it has worked well. Now, however, after the load...
heatman101
Oct 18, 2010 | Jenn-Air 24 in. JDB1100AW Built-in...
Dishwasher is about 8 years old an dishes are just not as clean. Looks like they have a bit of residue on the dishes. Dishes clean in terms of food, but just not squeaky clean look anymore. Way to clean...
heatman101
Aug 21, 2010 | Asko D1876 Dishwasher
Soap (?) residue on dishes; also not getting them clean--food on
heatman101
Jul 26, 2010 | GE Nautilus 24" Built-in Dishwasher
2 year old dishwasher. Dishes not getting clean. More residue
heatman101
Jun 03, 2010 | Jenn-Air JDB1105AW Built-in Dishwasher
I have maytag dishwasher leaves food residue
there is a filter on the inside bottom of the dishwasher check and clean it
May 16, 2010 | Maytag 24 in. MDBH970AWS Built-in...
Dishwasher just started leaving food residue on dishes after washing. We usually don't rinse beforehand but even when we do this it's still happening. Can I run something thru a cycle to give the washer a...
heatman101
Mar 08, 2010 | GE Nautilus 24" Built-in Dishwasher
It is not cleaning dishes, it leaves food residue on dishes and deposits small bits to other dishes especially on glasses.
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Jul 15, 2009 | Jenn-Air 24 in. JDB1080AWS Built-in...
Food residue on all dishes
The filter systems on the Maytag line of dishwashers which includes Jenn Air is very fine. In most causes the pump needs to be torn down and washed in a sink and a shop vac is also a great tool I use to clean the rest of the pump out that will actually stay in the dishwasher. The spray arms also need to be cleaned in the sink. Check your drain line under your sink as well and make sure that the drain line coming from the dishwasher has a high arch or bend that is higher than the base of the sink. This will prevent sink water from backing up in the dishwasher which can be nasty. Also make sure to run your hot water to the sink before starting a cycle to assure hot fills and the water temp. is best if set at 130 degrees on your water heater instead of 120 or 125 degrees. I hope this is helpful. This kind of problem can be agrivating to solve at times. Scott (North Caolina)
Apr 20, 2009 | GE Nautilus 24" Built-in Dishwasher
Jenn-Air 24 in. JDB1090AWS Stainless Steel Built-in Dishwasher Logo
131 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
