Question about Vector VEC 024 400-Watt Power Inverter (VEC 024) 400-Watt Power Supply
I need schematics for a Fraron 1500 w 12v inverter. The inverter is Fraron, not Vector as listed in title. Thanks.
3 Suggested Answers
SOURCE: my vector power inverter needs to be reset
Inverters use high power transistors to create an A/C voltage from a D/C input. These transistors are the common point of failure when the units are not cooled properly or used beyond their rated capacity. (Actually, you should always buy an inverter that’s rating for continuous use is well below what your actual need is). What’s most likely happened is that these have shorted out and need to be replaced. Unfortunately, replacement parts alone will likely cost nearly what a new unit costs.
Sorry to be the bearer of bad news; but you basically have a nice paperweight with some pretty lights and fans on it.
Posted on Aug 15, 2009
nitrospawn
  • 290 Answers
SOURCE: i think my inverter burned.
it depends on what burnt in it, you should check it out to know
Posted on Feb 27, 2010
Where can I get a fuse for a Vector 350?
Hopefully you are actually referring to a Vector VEC060 Power Inverter 175/350 Watt DC/AC as I cannot find a listing for a Vector 350 in the flashlight or spotlight listings.
The external fuse for the Vector VEC060 Power Inverter is a standard 30A spade type fuse available at any auto parts store. If you would prefer to purchase online, here is a link to them on Amazon:
http://www.amazon.com/Automotive-Truck-Plug-Blade-Green/dp/B00CJCS1V2/ref=sr_1_1?ie=UTF8&qid=1432440778&sr=8-1&keywords=30+amp+spade+fuse
May 08, 2015 | Vector Camping, Backpacking & Hiking
11Kw pioneer VF-5000 inverter
please send me the user manual for vf-5000(11Kw)?
Jun 23, 2014 | Black & Decker Vector Cable Kit for 1200...
Inverter
Hi Shirley
In 2006, Black & Decker purchased Vector Products, Inc. the maker of the inverter in question. Please click this link for more information.
I hope this helps & good luck!
Jan 07, 2013 | Vector 2000w Power Inverter
(Vector 400 Watt sst Power inverter) When I plug the Inverter into the Cigarette lighter of my RV, and the TV 26" into the inverter It won't work.
I am assuming that the inverter works with other devices. This being the case, i am thinking that the television start up current is drawing too much power too quick for the inverter to handle and this is what is shutting down the inverter.
Feb 05, 2011 | Vector VEC024B MAXX SST Power Inverter
I have a vector 3000 watt inveter red fault light is on, wont power a 6.5 amp fuel pump
Check that ground is correctly connected. If nuetral is provided, ensure it too is connected. Your total load is 780 watts. Check power in and ground out of the supply side. There may be a fuse in the inverter on the output side also, replace if necessary. If fault light does not go out after these checks, you will need to contact Black and Decker who manufactures the vector series now.
Jan 16, 2010 | Vector Power Inverter - 3000 Watt
Power inverter installation?? (Vector 2500W in Tacoma truck)
Don, There are two ways in which I would have satisfyied the 6 foot guide line. 1. Mounted the VECTOR under the hood. 2. Supplied the VECTOR with additional "bed mounted" battery to be charged via the present wiring with a two pole single throw "knife switch" as as the "connect/disconnect to the vehicle battery/alternator for charging the new battery. In any case, you should make it a twice yearly thing to inspect the 15 feet of wire now installed, for wear and tear faults that could result in sparks, smoke, fire. You may need to visit local electrical supply house to see what they have to offer in the way of small "breaker-boxes" that may be capable of handling such large GAGE wire. I MEAN #2 gage wire IS very thick and expensive per foot!!!! A disconnect box similar to type found mounted to brick-work and next to and connecting a 1.5 to 2 ton central air unit might do the trick. But anyhow, if you are not going to use the VECTOR disconnect the POSITIVE lead at the battery and tape the connector with electrical tape to be safe. Let me know how it works out for you. lmistyrel@ aim.com 12fixlouie
Nov 24, 2009 | Vector VEC056D 2500 Watt Power Inverter...
Vector 2000 Max inverter VEC054D turns on, LED
sounds like my inverter im going to change the mofset or.triod it has 3 prongs.
Jul 23, 2009 | Black & Decker Electronics - Others
My vector power inverter needs to be reset
Feb 03, 2009 | Vector VEC056 MAXX Power Inverter
Vector VEC 024 400-Watt Power Inverter (VEC 024) 400-Watt Power Supply Logo
95 people viewed this question
Top Vector Computers & Internet Experts
Jonathon summesfield
janman
Are you a Vector Computer and Internet Expert? Answer questions, earn points and help others
