Question about Philips Magnavox TP3285C 32" TV
I try to turn the TV on but it just clicks, could it just be a fuse somewhere?
    New Friend:
  • 47 Answers
It can't be the fuse. Clicking indicates that the power supply is entering overcurrent protection due to a fault. Usually it's a flyback transformer or HOT (horizontal output transistor) failure that leads to this behaviour.
Posted on May 08, 2010
The tv will not turn on
Did you try turning it on directly on the TV itself. Your remote may have gone bad. There should be an on/off button somewhere on the TV set.
Jun 22, 2016 | JVC Televison & Video
TV will not turn on.
Sounds like there is a short in the tv somewhere, the clicking is probably a breaker/fuse inside the tv cutting power to prevent damage to the components. Have you tried a different outlet as they can sometimes cause this to occur by surging power to the unit.
Dec 04, 2013 | Sony KDS-60A2020 60" HDTV
Wont turn on just clicks
The click is the manual relay inside the set------you may have a short somewhere (fuse should be good if power relay clicks) or a loss of high voltage.
Dec 03, 2012 | Panasonic CT-32SL14 32" TV
Panasonic PT-45LC12......won't turn on
Its ballast supply issue that need to be replaced/ repaired.
Ballast supply drives Lamp in TV.
Jul 06, 2009 | Panasonic PT-45LC12 45" Rear Projection...
Pioneer 50 inch projection tv won't turn on
I only fine 5 fuse where is the 6 fuse locate? Please help I found the 5 on the power board... is the 6 fuse somewhere else not with the power board?
Mar 15, 2009 | Pioneer SD-P50A3Q 50" Rear Projection...
Toshiba TV problem
No reset button, try unplugging the set for 1 min, the plug back in, otherwise Tv Tech time.
Jul 08, 2007 | Toshiba 36AX61 36" TV
RCA tv makes licking noise when it turns on.
It sounds like you have an arcing solder connection somewhere in the power input to your TV. This is a loose connection somewhere. You might confirm this by jarring the set while it in operation. (Not too hard) If the problem shows up then a loose connection is confirmed. Also a component may be breaking down internally. You need to have a tech check it for you. Stargazer
Mar 14, 2007 | RCA 32V420T 32" TV
Power surge I think
If you do not get any clicking or sound when trying to turn on the TV set, most likely the main fuse went out. This is almost always due to something else blowing out along or making the fuse to blow out. DO NOT SIMPLY REPLCE THE BLOWN FUSE! If there is other shorts inside the set, and you replace the blown fuse, you can cause more damage to the TV set. The best way to test this set if the fuse is blown would be to hook up a 100 to 150 watt light bulb across the blown fuse, and if there is a short in the TV set the light bulb will glow bright and stay bright. If the bulb lights up and goes dim maybe just maybe you got luck so replace the fuse and see what happens. If the light bulkb stays bright, there is a short in the set somewhere and if you do not have a service manual and a good multimeter and a knowledge of how the TV power supply works, you really should call in a pro to assist you in the repair of this TV. there is just too much High Voltage inside these TV sets to be experieenting around inside of it. Good Luck.
Mar 14, 2007 | Toshiba 36A43 36" TV
Tv Wont Turn On
dont be afraid, remove the fuse and have it replaced. but be sure to unplugged the unit before doing so and replace it with the same value. if the fuse get busted again, there is a short somewhere in power supply circuits or the horizontal circuits and its time to bring the unit to a qualified service technician
Jan 03, 2007 | Panasonic CT-32HL43 32" TV
Philips Magnavox TP3285C 32" TV Logo
103 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
