Question about Aprilaire 550 Humidifier
How is the cover to the 550 Humidifier removed to replace the filter? elkandnlk@yahoo.com
  • 82 Answers
The side opposite of the pipe inlet has a finger tip recess 1 1/2" from fron and runs vertical. Pull straight out
Posted on May 10, 2010
Humming sound coming from my 550 humidifier thermostat. the dial to control humidity is not responding and wont turn off
Hello, sounds likemyou have either a bad humidistat or solenoid valve, disconnect the wires from the humidistat if this turns off the humidifier than replace the humidistat. If not the solenid valve will need to be replaced,
Sep 17, 2011 | Aprilaire 550 Humidifier
How to change filter
Lift the cover off the humidifier with the power turned off, then you should be able to pull out the tray that holds the filter in place.
Dec 21, 2010 | Aprilaire 550 Humidifier
Aprilaire 550 makes extremely loud grinding noise when turned on
yes it should be bypass but solenoid could be trying to open but the voltage to it may be to low if you have 24v ac power at the 2 small wires. but to change shut down power to furnace and water to humidifier.you loosen the 2 compression nuts unwire they cant be reversed so dont worry then 2 mounting screws then reverse to install
Dec 17, 2009 | Aprilaire 550 Humidifier
Hissing sound
that is normal if it is too loud the filter inside may be dirty and need replaced they need replaced ever heating season
Oct 21, 2009 | Aprilaire 550 Humidifier
Loud clicking, banging noise
We recently had the same problem. After cleaning both the furnace filter and the humidifier water panel, the clicking noise (electric air filter) and the loud bang went away.
Nov 30, 2008 | Aprilaire 550 Humidifier
Humidifier leaks water when turned on
Humidifier water pad comes w/ a mark in one end, that mark should be on top. Also check your feed tube they tend to crack some times. if if still leaks water change the water pad
Nov 14, 2008 | Aprilaire 550 Humidifier
Aprilaire 550 humidifier
Did you clean the orfice ? It is located on bottom of solenoid. It is plastic with a very small hole.The hole gets plugged and you can clean it or buy a nw one for 50 cents.
rdsvideo2@yahoo.com
Oct 18, 2008 | Aprilaire 550 Humidifier
Water leak
your drain pipe is clogged up, going to drain- Duh
Jan 13, 2008 | Aprilaire 550 Humidifier
You can call 1-800-955-7075 give them the make and model #.The part # should be 4217,10x113/8 frame for $14.56 plus shipping
Nov 20, 2007 | Aprilaire 550 Humidifier
Aprilaire 550 Humidifier Logo
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
