Question about Frigidaire GLET1031 Top Load Stacked Washer / Dryer
Washer started smoking and stopped operating - Frigidaire GLET1031 Top Load Stacked Washer / Dryer
  • 10,865 Answers
Hello. You probably have a frozen pulley wheel in the machine which becomes a problem when the machine starts agitating. This is a difficult and complicated repair so unless you are very handy I recommend leaving this to the pros. That said, if your machine is over 5 years old, it is probably more cost effective to replace it rather than repair it. Joe
Posted on May 08, 2010
Samsung front loading washer started smoking while on spin cycle , new rubber seal an bearing ?
my first though would be to consider if its electrical smoke of friction smoke, chances are if it smokes on spin the motor is over heating and ready to pack in its operation, new brushes may solve the problem before buying a complete new motor.
Sep 21, 2016 | Samsung Washing Machines
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
Washer starts for a few secs then stops like it is waiting for wa
Trust water supply ok ...does it run on pump out only?...Check caps connections are correcct
Apr 08, 2010 | Washing Machines
After five minutes of operation,cleaner starts blowing black smoke and stops,needle and seat seem ok,float seems ok ??????
Check crankcase vent. Possible pressure building up in crankcase causing blow-by across piston.
Jul 08, 2009 | Honda Pressure Washer PSI 3000
You might have overloaded the machine and the belt will smoke;the machine will still work,the items still might be wet due to the fact the machine couldn't spin fast enough.
May 04, 2009 | Kenmore 24032\24036 Top Load Washer
Frigidaire GLWS1339CS Top Loader, Won't Spin
Smoke usually means a major overheating of a belt or agitator transmission, get this checked before trying to run it again,
Jun 25, 2008 | Frigidaire GLWS1339CS Top Load Washer
Smoking washer Amana NAV8800AWW
Ok, that's a different scenario. Generally, when a washer is agitating and develops an overload that stalls or overheats the motor, the problem could be caused by:
1. Too many clothes for the amount of water level selected. If clothes don't have enough water to circulate in properly, it can put excess pressure on the agitator which transfers to the gearcase, drive belt, and finally the motor. The motor is thermally protected and stops running until it cools down, then it will try to restart. In the process the drive belt could burn slightly to completely,so you may want to inspect the drive belt for burned areas.
2. Transmission malfunction, where something inside the transmission breaks due to an overload and jams a gear. End results can be the same as above.
I suspect a clothes overload may have caused the problem and once the overload is alleviated, the washer should operate normlly if the belt didn't burn,
May 27, 2008 | Amana NAV8800E Top Load Washer
Smoke
Your complaint is a bit vague but since it had only been in the cycle for 1 min., it should have been too soon to have enough water to start washing, so it's possible that the fill valve may have shorted out. Unplug the washer and inspect the area where your hot and cold fill hoses connect to the washer. Turn the water off and remove the hoses. If you can gain access to the part that the hoses were connected to, you should be able to visualize where the burning came from. It is possible a small water leak may have dripped onto the coils of the valve and caused it to short out, so that will need to be fixed also.
Hopefully, This is what your problem is.
Burning Smell
no check wiring connector at the motor and the capasitor connectoions, lid switch connections
May 10, 2008 | Washing Machines
Frigidaire GLET1031 Top Load Stacked Washer / Dryer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
