Question about Yamaha DV-C6280 DVD Player
CD stuck in player
We opened up the player and inserted a cd disc into the number 1 slot in the tray. after the tray slid closed nothing happened. now the tray will not open, the player doesn't show a disc in slot 1, nothing is working. All I want to do is get the player open. Until now I have had no problems with the unit. I think maybe the disc was not aligned in the tray properly? Any help would be greatly appreciated.
SOURCE: no tray function
You have to press both the "on" button and the "preset" button to lock-unlock the tray
Posted on Dec 12, 2007
SOURCE: DVR-S120 doesn't play any cd's
I have come across one DVR-S120 that has a shorted spindle motor. This is the motor that spins the disk. Therefor the unit will not play a cd or dvd. Yamaha sale's the complete dvd Assy. for $300 witch is absurd.
Posted on Jan 16, 2008
megatronix
  • 57 Answers
SOURCE: BLOCKED MESSAGE ON YAMAHA DV-S5450 DVD PLAYER
The DV-S5450 may use a belt-loading mechanism. The belt is typically black rubber band with a diameter of approximately 2 cm. It is commonly found in front-loading CDROMs for computers also. Often, as a result of age, usage, humidity, etc the belt snaps, rendering the loading impossible. The loading motor doesn't just pop the tray in or out. It also engages a clutch assembly that raises an inserted disk or lowers a disk to be ejected; this explains why you can't simply force out the tray. Clearly in your case all the electronic signals are there and the loading motor does turn.
Solution: switch off and unplug the unit and then open it up. Do a quick inspection to see if you can locate the broken rubber band. If you can, remove it and take it along with you to the nearest repair shop for exact replacement. If you are finicky around technical work, simply a competent person do it for you. Good luck.
Posted on Jan 18, 2008
SOURCE: yamaha dvr-c300 dvd playeer
on my sreen it say speaker error ,and no sound is coming out on my yamaha dvr-c300
Posted on Feb 18, 2008
  • 236 Answers
SOURCE: CD tray repeatedly opens and closes
is this a yamaha 5 disc changer, table. not the cartridge type...
Posted on Mar 19, 2008
My disc trays will not open. Have followed all instructions in manual - nothing
Did you forget to mention the make & model number of your
CD player? It would be a major help to anyone responding!
Oct 22, 2014 | Audio Players & Recorders
I have a new samsung bd-f5700 player and tray won't open. Tried using the remote to open & the panel on top of player to open. Nothing works.
First, try resetting your player. Unplug it from wall for at least 1 full minute, then plug it back in. If eject function (remote or top panel) still doesn't work:
MOST DVD players (including every one I have ever worked on or owned) have a tiny manual eject pinhole located close to the tray. You may have to gently open the flip door to see it. It is usually to the right of the disc slot, but could be underneath or elsewhere close by (use a flashlight, it can be hard to see). Carefully insert a straightened paper clip in the pinhole to eject the disc. (It shouldn't matter if machine is on, but for safety I usually do this with the machine OFF and unplugged).
see http://www.ehow.com/how_2324439_eject-stuck-dvdcd-drive.html
or
http://www.ehow.com/how_2036594_fix-dvd-player.html
and http://www.ehow.com/how_6330619_retrieve-jammed-cd-dvd-player.html
If above fails, your only recourse is likely the disassembly of the machine (search "dvd disc stuck" on Google or YouTube), or taking your machine to a repair person. Best of luck to you.
Jun 23, 2014 | Samsung BD-F5700 Blu-ray Player
My CD is stuck in my Toshiba Satellite A505D laptop slot, with no hole near the Eject button.
Look on the cover on the tray near the eject button. Should be a tiny hole.
Get something like a straightened out paperclip and insert it in to the hole and push firmly but carefuly. It's an emergency eject for a stuck tray.
Feb 07, 2012 | Computers & Internet
My dvd is not working on my blue ray it saying go to update some software
you will need to download the update from
http://pages.samsung.com/us/bluraysupport/support.html
how to - make an update CD
  1. Download the software update file for your hardware.
  2. If the update is compressed (zip file or rar file), the file should be uncompressed before burning.
  3. You must burn the update file on a blank CD-R/W disc by using "Burn Image" option.
  4. Burn an image file of the software update file (*.iso)
how to - update your player with your CD
  1. Press OPEN/CLOSE to open the disc tray.
  2. Insert the update CD-R disc with the software update, label facing up.
  3. Press OPEN/CLOSE to close the disc tray.
  4. Wait 1-2 minutes until the screen displays "Verifying Firmware version..."
  5. After checking old and new version, select "Yes" or "No" with "?" or "?"
    on the remote control. If you select "No", BD-P1200 will be powered off in a state of tray open.
  6. Press ENTER button on the remote control.
  7. Remove the update CD from the tray.
  8. Screen will display "Firmware Update Now Processing... Please do not turn off the power".
    This process will take 4-5 minutes. When done the screen and power will turn off automatically.
  9. Turn the unit on again with the power button. They tray will close automatically and a
    Menu Language Selection screen will open.
  10. Select the Language you want by pressing the corresponding number button.
  11. Update is complete.
Jan 15, 2011 | Samsung BD-P1500 Blu-Ray Player
When I insert cd, in either 1, 2 or 3 slot and then it says no disc and opens...
Hello
Your JVC CD player has some mechanical trouble. It does not load CDs fully into the tray. Either tray loading motor or its belt iis faulty. Replace the belt first and see it helps you. If not replace the loading motro. For both, you have to open and disassemble your CD player. If you are able to do it, and have confidence, proceed. OK
Happy New Year.
Dec 31, 2010 | JVC XL-MV303 CD Player
Inserted cd disc. play music on cd but will not eject the disc cd is stuck in cd player
Mostly The cd is jammed between the laser sensor and the cd rotator.Try removing the audio player and reseting the whole device if possible.Or if you have sufficient technical know how.Open the player try to manually open the disc tray.and remove thedisc.This can happen even  if the disc is broken inside the player.
Sep 28, 2009 | 2004 Jeep Grand Cherokee
I have a denon 3500 cd player my cd is stuck
Open the top cover of your CD using a screw driver, (usually a star screw driver),. Then, manually turn the driving gear of the CD tray to free the stucked tray and until to the point where you can take the disc from the tray. Be careful so the setting of the tray and the laser eye is not change. Then, close the close the cover and play. You can send your e-mail thru fix ya to let me know.
Sep 25, 2009 | Sony CDP-C910 10-Disc CD Changer
Cd recorder stuck in Dealer Mode
With the unit in Standby mode (off), press and hold the Display button. The trays will then unlock.
Feb 13, 2009 | Philips CDR795 2-Disc CD Recorder
Fisher CD-RW1000 2-Disc CD-dvd stuck in player
hmmmm.... try to take off the cover of your dvd player and observe it.(if you try my advice, try it in your own risk and with caution) then check the tray maybe there is something got stuck in there and also check the gears, if nothing, a belt just came off. check the motor too, I guess It has 2 switches too. clean them up. and then try to power up.
note:
(keep you fingers away at the power supply section)
Jan 29, 2008 | Fisher CD-RW1000 2-Disc CD Recorder
Yamaha DV-C6280 DVD Player Logo
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
