Question about Garden
Hasqvarna LTH140 lawn tractor. Engine won't start.
Have a hasqvarna LTH140 lawn tractor. Engine turns over but it will not start. Seems to be no fuel to carb. Cleaned fuel filter, air filter,new spark plug? There is a solinoid attached to the carb. Could this be defective? What does it do? Can this part be purchased seperate from the carb?
  • 198 Answers
Remove the carb and disassemble---clean parts in solvent--make sure the float valve moves freely in the bowl
Posted on May 10, 2010
I have a hasqvarna 125 b I have put new starting coil on it,new fuel lines, rebuilt carb, new primer pump, new plug. It is getting spark, the plug is wet, but it still won't start.
Check your muffler's spark arrestor screen for clogging. Also test your compression. It needs to be be at least 100 psi for the engine to start.
Apr 24, 2015 | Garden
I just purchased a new Hasqvarna 130BT. Took it out of the box, I believe I followed all the directions. But it won't start. Checked the plug, fuel (Using the Hasqvarna pre mix. 50:1). I need help
We had user @ AnswerArmy that recently purchased a 150 BT that had the choke label put on backwards. Check this as this maybe your problem and you are simply not choking it.
Apr 18, 2015 | Garden
Why can,t I get power to starter on 24 h.p. hasqvarna
starter silinoid bad replace but first jump the starter to make sure its not bad
Sep 10, 2014 | Husqvarna 23 Hp 48" Deck Yard Tractor
Hasqvarna LT1597 ride-on mower will not start
The main fuse holder is behind the dash down thw side of the fuel tank, sounds like it may have blown.
Feb 19, 2013 | Garden
Hasqvarna 440e chainsaw wont start not getting fuel
Check and clean carb, check fuel lines and fuel filter. Check carb gasket between cylinder.
Dec 18, 2012 | Husqvarna Garden
Hasqvarna 435 16"- bar nut loosens excessively
Put a lock washer on it to stop it from backing off.
May 18, 2011 | Husqvarna Garden
I have a husqvarna YTH18542 lawn tractor that wont start! I replaced the spark plug and fuel filter but it just does not seem to be getting any fuel to start it. If you pour gas directly into the carb is...
before you rebuild the pump, I would check the lines to see if fuel is flowing through them, as my Mtd the lines where blocked and I had to buy a rebuilt kit for the carburetor. You can check on eBay or order one off the Hasqvarna site Hope this helps Tim
May 04, 2011 | Garden
Blades are uneven, iam scalping my lawn with the right blade while the left one is just right. I have a loyth20f42t Hasqvarna riding tractor
Either the deck is not attached correctly, or you have a bent blade. If the blade is bent, you will have to replace it.
Sep 16, 2009 | Husqvarna Garden
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
