i have a packard bell easynote r1935. and i cannot turn the wireless switch on . i have tried the fn with f1 buttons and the f1 button and the ctrl button but it does not seem to be working.
i,ve downloaded the drivers from packard bell and my wireless router is working fine. i have tried everything and it is a case that the wireless button is not switched on.
any help would be appreciated
Comments:
Mar 27, 2008
- i have tried to find a volume control and a wireless button (like on my other laptop) and there isnt one .(if there is, then it is invisible or hidden mi5 style)
it appears that the volume control is on the keyboard . you press fn key then f3 and f4. and the same for the internet press fn then press f1 key or both together at same time none of which seem to work.
any more suggestions would still be appreciated
alan
Apr 01, 2008
- hi sorry to take so long to get back
ip address is 192.168.0.3
default gateway is 192.168.0.1
if this helps
Apr 01, 2008
- when i go into network connections it just keeps telling me that wireless is not connected. the status option is always greyed out
i can enable then disable and vice versa
but no joy with connecting.
-   hey there. i format my laptop last night and the WI-FI button its not working :( my computer is a Futzitsu Siemens. i will try what you wote above and i hope i will solve my problem :)
-   papalefteris
Somewhere on the laptop should be a button to switch wifi on and off. Most time near the volume controls... Have you put that one on?
Comments:
Mar 27, 2008
- According to the packard bell website, the Fn+F1 combination switches the wireless. S
You are sure you have the latest driver from packard bell? Just to make sure... ;-) Try to find your wireless card in the device manager under 'Network adapters'. If it is there, check properties if it is working correctly. Then look in Control Panel > Network Connections to findif there is an icon for your wireless card... If it is, what is the status? Also you could go to: Start > Run Type "cmd" and press OK You'll get a black command box. type "ipconfig /all" without the quotation marks and press enter Post the Ip-address and default-gateway if it is shown
