Question about Homelite Mighty Lite Lawn Trimmer
What type of fuel mixture do I use for 20760 Homelite gas trimmer?
    Scholar:
  • 47 Answers
Most likely not the answer you are looking for but here is a shot:
Pick up a bottle of the Echo brand 2-cycle oil. It will say "Extended Life" on the labeling. This is meant to run in Echo products, but it is a very FINE and well engineered oil. Mix it according to label directions for 50:1 ratios. (2.6 Oz. to 1 Gal. Gasoline)
When mixed at this ratio it provides MORE than adequate engine protection for ALL 2-Cycle engines, including those that run in 40, and 30:1 ratios.
I mix one 2-cycle tank to label instructions on the Echo oil for 50:1. It handily runs in my Echo chainsaws, non-echo trimmer, Poulan Pro leaf blower, etc. They all run different ratios, but THRIVE on the Echo mix without as much oily residue and smoke to boot!
CAUTION: I do not know of ANY OTHER MAKE of 2-cycle oil that CAN DO THIS *SAFELY*.
Remember:
Always mix your 2-cycle fuel starting with *fresh* gas.
Mix only that which you can use in 30 days.
Use 89 Octane fuel to make your mix in small piston 2-cycle engines.
Clean and re-oil intake filters @ every 10 hrs. operation time. Check and re-gap your plug when you service your filter!
DRAIN unused fuel from tank back into gas mix container. Restart and let engine idle to run any remaining fuel out of engine and carb. Storing fuel in ANY 2-cycle longer than two weeks is going to gum them up and nothing short of a carb rebuild will get them sputtering back to life again!
Posted on May 09, 2010
Fuel mixture Z830sd Homelite trimmer
Since my research shows this to be an older unit, I recommend a 40:1 mix. That is 3.2 ounces of 2 stroke oil / gallon of gas, or 1.6 ounces of oil in half-a-gallon of gas. Here is a mixture chart.
http://support.mtdproducts.com/app/answers/detail/a_id/347/~/two-cycle-engine-fuel%3Aoil-mixture-chart
Sep 04, 2011 | Garden
What is the correct gas and oil mixture for my Homelite trimmer Model 20583C. I attempted to find the manual for this trimmer on line, but did not have any success
Hi hmarlow...
I am sorry I could not find a user manual for you either..
But as fas as fuel/oil mixture use a 50 to 1 mixture.
1 pint of 2 cycle oil to 6 gallons of gasoline
Please take time to rate me
Aug 23, 2011 | Homelite Mighty Lite Lawn Trimmer
What is the correct fuel oil mix for a homelite whipper snipper
I believe Homelite calls for 40:1 (2.6oz. oil to 1gal gas) mixture, but if you are using a good current brand name two cycle oil, 50:1 (3.2 oz. oil to 1 gal gas) would be safe also.
Feb 08, 2011 | Homelite Mighty Lite Lawn Trimmer
Need a manual for Homelite weed eater, UT 20760. It can be in PDF format. Forward to guitar0589@comcast.net. Thanks
You can download the trimmer PDF for free here - http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/homelite_trimmer_product_list.html
Jun 28, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
GAS OIL MIXTURE
3 oz. 2 cycle oil to 1 gallon fresh fuel and
to keep your fuel fresh add some fuel stabilizer found at walmart for ethanol blended fuel ( it will say marine formula on bottle) and add it to the gas can you fill your trimmer with ,follow directions on bottle for treatment vs. capacity.
May 14, 2010 | Homelite Mighty Lite Lawn Trimmer
Trimmer bogs down and stalls and does not seem to run up to full speed
May need carburetor adjusting or you may have some bad fuel mixture. I would mix up some fresh fuel mixture and try it. I would get my new gas from the gas station and not from the can in the garage.
Good Day.
Nov 02, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
341 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
