Question about Sony Playstation 3 (PS3) Console
After restoring my default settings on my ps3 because i was unable to play a game i turned it back on and its asking me to connect controller to console using usb cable and press ps button but nothing happens when i do this the 4 red lights on the controller just flash!!! please help
  • michaelgreat May 09, 2010
    yes ive tryed reseting the controller and holing the ps button for 5...10secs but still dosent work..thanx anyway
    yes ive tryed reseting the controller and holding the ps button for 5...10secs it hasnt worked tho any other ideas plz
  • Sony Expert
  • 311 Answers
Is the usb cable in the first slot?
and connected to the controller at all times while doing this steps
try clicking the reset button on the controler which is underneeth the controller you need a paper clip to push it
then try
Posted on May 08, 2010
  • fkuk
    fkuk May 09, 2010
    does the USB cable work
    try a differnt cable but still plugs into the ps3 and controller
    does the controller charge when you plug it into the ps3 or computer
Will not play any ps3 games or movies
The PS3 has a special Recovery Menu, which you can access in the following way:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
From the above select option "Rebuild Database". After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu.
Thank you
Jun 04, 2010 | Sony Playstation 3 (PS3) Console
PS3 unable to switch from 720 to 1080 PS3 does not
if u go to system settings down to restore defualt settings you can reconect the controllers and reset the system to ur tv
Feb 16, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont reconize any discs after freezing
The error code 80710102 you are getting due to a possible connectivity issue of your PS3, since you have not specified in your problem how are you trying to connect your PS3 to internet so i am unable to assist you on that front
For the problem related to discs not playing is becuase ps3 files being corrupt.
1) First take a back up of your data on PS3 - Go to system settings> backup and follow the appropriate settings,i suggest use a usb stick or hard drive to back up your data.
2) Under system settings go to restore ps3 and follow instructions. This will erase all the data on your ps3 and restore it to its factory default, this will restore all the original ps3 files.
3) Once the PS3 install has completed then try updating your PS3 to latest firmware available, now try playing your discs
4) If your ps3 now plays games and dvds go back to system setting> backup, select restore previous back up and all your saved data will be imported from the hard disk, please note: you may not be able to restore any copyright stuff which you could have purchased.
5) If the above steps do not work, kindly send your PS3 for repairs to Sony Customer Service
Hope This Helps
Nov 27, 2009 | Sony Playstation 3 (PS3) Console
My ps3 turns on then stays after the "PS3" before u get to the user. i have tried to turn it off and back on but it doesn't help
1- Turn the standby switch off so the red light turns off too, then you turn the system back on
2- Then place your finger on the power button for a total of 4 beeps to access the recovery menu. It might not work on the first attempt but it will on the second.
3- The display will instruct you to connect your controller to the PS3 and press the enter
button. A list of menus will appear on your display. The choices are as follows: Restart
System, Restore Default Settings, Restore File System, Rebuild data base, Restore PS3 system, System update
4- Select Restore Default Settings.
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
Will not play games or dvds- menu screen will not come up the screen just shows the red wavy lines not the blue like it is suppose to
1- Disconnect the PS3 from the internet.
2- Turn the standby switch off so the red light turns off too, then you turn the system back on
3- Then place your finger on the power button for a total of 4 beeps to access the recovery menu. It might not work on the first attempt but it will on the second.
4- The display will instruct you to connect your controller to the PS3 and press the enter button. A list of menus will appear on your display. The choices are as follows: Restart System, Restore Default Settings, Restore File System, Rebuild data base, Restore PS3
5- Select Restore Default Settings.
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
My ps3 won't play discs
this has happen to me!! and i end up buying another ps3 and it end up the same!!! i fix both of them!!! and about over 200 consols with the same problem!!! this is what u do! you connect your control direct to your ps3. and then you hold the power button for 5 seconds!! the system will turn on!!!remove your finger for a second and hold the power button till you hear 2beeps then remove your finger and the system will shut off!! this is a manuel reset!!! the system will turn back on!! asking u to connect your controller!! you already have it connected. then it will give you about 6 options!! you will choose RESTORE FILES!!! your system will check for your system defaults!! then it will tell you that you have corrupted files!! and proceed with it!!! it will fix if you have problems with your controls,if it doesnt play games,blue ray,if it freeze, system shutting off,icon problems,only playing sertting games or movies!!! if you have problems or any question feel free to ask!! i know is fustrating!!!
Nov 04, 2009 | Sony Playstation 3 (PS3) Console
Wont play when i insert disks only the games on there
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu.
I did not have problems with the normal movie DVDs or movie Blu Rays. Those were working fine. Also downloaded games were working ok.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
Select option "Rebuild Database".
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Jun 18, 2009 | Sony Playstation 3 (PS3) Console
Ps3 will not play any games
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
Jun 07, 2009 | Sony PlayStation® 3 (60 GB) Console
Plays films, won't play games
this is what u do! you connect your control direct to your ps3. and then you hold the power button for 5 seconds!! the system will turn on!!!remove your finger for a second and hold the power button till you hear 2beeps then remove your finger and the system will shut off!! this is a manuel reset!!! the system will turn back on!! asking u to connect your controller!! you already have it connected. then it will give you about 6 options!! you will choose RESTORE FILES!!! your system will check for your system defaults!! then it will tell you that you have corrupted files!! and proceed with it!!! it will fix if you have problems with your controls,if it doesnt play games,blue ray,if it freeze, system shutting off,icon problems,only playing sertting games or movies!!! if you have problems or any question feel free to ask!! i know is fustrating!!! i did some research and this is what another expert said to do
Feb 22, 2009 | Sony Playstation 3 (PS3) Console
Error code 80010514
Sony has a few fixes for this.
Visit PLAYSTATION 3 System Software Update to download and install the most recent version.
To check what version of the System Software is currently installed on your PLAYSTATION 3:
  1. From the XMB™ home menu, go to icn_settings.gif(Settings) > icn_syssettings.gif(System Settings) > [System Information].
    The system will display the System Software version number.
OR During certain troubleshooting situations, it may be necessary to restore all of the PLAYSTATION 3 system settings back to their original "default" configuration.
  1. From the XMB™ home menu, go to icn_settings.gif(Settings) > icn_syssettings.gif(System Settings) > [Restore Default Settings].
  2. Once you select [Restore Default Settings], you will see a list of settings that will be restored. Scroll through them and press the icn_btnx_color.gifbutton to restore the settings.
  3. After the operation is complete, you will see the initial setup screen that appeared the first time you turned on the PLAYSTATION 3.
    You will need to go through the initial setup process before you can use the PLAYSTATION 3.
IMPORTANT
The Restore Default Settings feature will erase any previously saved settings and restore all of the following settings to the default:
  • BD/DVD Settings
  • Music Settings
  • Chat Settings
  • System Settings
  • Date and Time Settings
  • Accessory Settings
  • Display Settings
  • Sound Settings
  • Security Settings
  • Network Settings
  • Internet Browser Settings
Also, do not confuse "Restore Default Settings" with the "Restore PS3 System" option (the next option down on the menu). The "Restore PS3 System" will not only restore the default settings, but it will also delete all hard disk content. (You will lose all saved content from your PS3 system's hard drive if you use "Restore PS3 System.)
OR
Power-Cycle All Network Equipment Power-cycle means to turn the networking devices OFF (i.e., unplug it from the power source), and then to turn it back ON after a set period of time. This will allow the network devices to refresh its settings.
Please power-cycle ALL of your network equipment, including any wireless access points, routers, Voice Over IP (VOIP) modems, and broadband modems for two (2) full minutes. After 2 minutes, you can turn on (or plug in) your equipment.
Hope this helps. Good luck and happy gaming!! // //
Sep 29, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
109 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
