Question about GE Security Simon 3 Wireless Home Security System
Where is the battery located in the Simon system?
I am trying to replace the battery in my GE Simon.
  • GE Master
  • 19,396 Answers
Hi.
The battery is located inside the Simon. Use a flat screwdriver to remove the panel.
Here an online manual.See page 23.
Connect the battery BEFORE connecting the power transformer.
Regards.
Posted on May 08, 2010
System says low battery ... how do I open it to replace batteries...very confusing!
There are two tabs (and possibly a screw) on the top of the Simon XT panel. Remove srew (if installed) and press the two tabs, pulling forward. Front part of panel is hinged and will rock forward. Battery is located behind front half. It is a 6 volt 1.2 Amp Hour lead acid battery.
You must completely downpower the Simon XT (wall plug in and battery) then replace with new battery first, then reconnect wall power. Close the front panel and snap it closedand replace the screw (if it was installed).You will need to set the time on the panel, following the instructions in the users manual.
Jan 05, 2011 | GE Security Simon Xt Wireless Control...
How to install backup battery for ge simon 3 home alarm
Open the unit both primary and secondary cover. You will see a plastic cover with 2 screws. Remove the screws and you will find a 6V DC 1.2AH battery. Replace battery (besure to connect red to + and black to -
AlarmProfessor.net
Jul 11, 2010 | GE Security Simon 3 Wireless Home Security...
Need to change a battery for a simon 3 wireless scurity system. any suggestions
It takesa 6VDC 1.2 AH battery. The battery is located in the back case.
AlarmProfessor.net
Jul 08, 2010 | GE Security Simon 3 Wireless Home Security...
Ge simon 2 alarm no longer beeps after battery replaced
Probably knocked off the clip on the piezo. Open the box and make sure all plugs are plugged into the circuit board.
AlarmProfessor.net
May 20, 2010 | GE Security Simon 3 Wireless Home Security...
Module ok simon version 3
You need a new battery. 6VDC 1.2AH. The GSM module runs directly off the battery and it is no longer getting a full charge.
AlarmProfessor.net
Dec 30, 2009 | GE Security Simon 3 Wireless Home Security...
I replaced back-up battery in my GE simon 3 ( 4 hrs ago), however when I perform a system status check I still get the msg "low battery".
You must unplug the transformer to the system before installing the new battery so the system recognizes that the battery is in place. Once you have installed the battery it is safe to plug the transformer back in.
Jul 25, 2009 | GE Security Simon 3 Wireless Home Security...
GE Simon 3 low battery warning: Newer battery has 6.54V?
Read the battery voltage with the system on but with the ac power disconnected. I always suspect the battery from experience. Battery needs to be replaced every few years normally(but can vary).
Jun 23, 2009 | GE Security Simon 3 Wireless Home Security...
How do I replace the battery in my Simon XT security system
Here is a very easy to follow video tutorial that may help you.
You can get a replacement battery from here
Simon XT GE Security Security Alarm Battery 6V 1 2AH
Mar 08, 2009 | GE Home Security
How do I open the system to get to the battery?
The battery is located inside the panel.
Insert a flat blade screwdriver into the slt at the top (front) of the panel and release the catch. The panel will fold down to reveal the PCB panel, the battery and the cabling connections for hardwired sensors, telephone & 9V AC power supply.
The battery has push connectors that can be unpluged for replacement.
Replacement batteries are available from your dealer or via Online security store specializing in GE Simon products.
Jan 14, 2009 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
801 people viewed this question
Top GE Home Security Experts
Michael Galve
Michael Galve
Are you a GE Home Security Expert? Answer questions, earn points and help others
