Question about Pool & Spa
Coleman 500 series SPA 50A circuit breaker trips
Coleman 500 series SPA 50A GFI circuit breaker trips immediately after resetting. Spa motors turn freely by hand. I suspect a faulty circuit breaker, what do you think?
    Problem Solver:
  • 8 Answers
Bad connection follow wires from breaker to to moter theres abreak causing arc find it
Posted on May 09, 2010
I have a spa berry 2 person hot tub. Tried resetting it but as soon as I let go of the reset button it trips the breaker. Can't get it to stay on. Tub is 4 yrs old. Where do we start?
Melisa, Breaker/GFI may be going bad. You may have to get an electrician to check for short or faulty motor/heater, etc. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ehottubsandpools.com/?p=320
Troubleshooting tripping hot tub GFCI breaker
Hot tub GFI keeps tripping
Spa Circuit Breaker Mysteriously Tripping Any Clues Portable Hot Tubs amp...
Jun 27, 2016 | Pool & Spa
Pump does not turn on. there is power to the board but nothing lights up
No power supply to "board" possibly 24vac, or an air type of control, so that the air supply pump is not active. Possibly the power supply to the pump and control board has "popped" the
circuit breaker. Check, the circuit breaker. There may also be a GFI Ground Fault Indicator that acts like a circuit breaker but is more sensitive, especially near water. Look at the receptacle that the motor plugs into. GFI has a test button and a reset button.
Mar 26, 2015 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Qo260gfi not tripping
Question is not fully clear.
2-pole 240Volt gfci circuit breaker requires the white wire be connected to neutral busbar.
Easy solution for 240Volt spa that comes with gfci:
Replace spa gfci with regular non-gfci breaker.
Install 2-pole GFCI breaker in main panel, and connect wire to spa breaker.
http://waterheatertimer.org/How-to-wire-GFCI.html#2-pole-gfci
Having 2 breakers is not a problem.
Having 2 GFCI on same circuit is a problem.
Apr 18, 2013 | Pool & Spa
What's youI just wired in my J-300 Jacuzzi hot tub. The GFI trips every time I reset it. I took the GFI out of the equation and the tub runs fine, does not trip the breaker at the main breaker box
#1. DO NOT GET INTO TUB FULL OF WATER WITH A GROUND FAULT.
2. There is a short. You need to get multimeter and start checking each part for current running to ground wire.
3) Power is ON. Connect power without GFCI.
4) Tape tester leads to wood sticks to keep hands away from power.
5) Do not touch anything directly or you will become the ground rod.
6) Ground wire must be present, and bonded back to main panel box.
7) Do not sit or touch directly on cement or bare ground. Do not touch or lean into anything made of metal.
8) Body and parts must be on sheet of plywood, or similar non-conductive dry surface.
9) Test each part with spa, but also test electric line coming from main box.
10) GFCI will also trip with any fault detected on line. So the wire coming to spa may have the fault.
11) Add a new dedicated line from main box to spa.
http://waterheatertimer.org/See-inside-main-breaker-box.html
Oct 02, 2012 | Electrical Supplies
Can I install a 20a gfi breaker in a 50a 240 gfi spa sub panel?
No. Don't ever do this. You have to install the correct amperage breaker ( magnetic contact ). This will burn your 20a gfi breaker quickly.
Regards
Mar 05, 2011 | Cutler Hammer Gfi Breaker 2 Pole 20 Amp
We have a hayward pump and the motor keeps stopping and tripping the circuit breaker. What could it be?
The motor might be too powerful for the line it's on, (usually a pump should be on a somewhat dedicated line) no Ac's running on same breaker.
An extension cord longer then 6ft is also a suspect in not allowing the pump the draw enough power.
The pump may not be drawing enough water, overheating and tripping the breaker, or the motor might have rust on the inside causing the armature not to spin freely, and shut off. (usually motor will make a high pitch noise) while running)
Jun 29, 2009 | Hayward Pro Series 18" Above Ground Pool...
GFI 'shorted'
load neutral connects to the neutral binding screw on the GFI, do NOT connect the load neutral to the neutral bar.
Mar 05, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Pool & Spa Logo
298 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
