Front usb 2.0 drives not working????
I bought this nice new sony computer with front usb drives and they worked once then stoped when i used a flash drive. Now when i put anything into them nothing happens...
  • gysgt90 Mar 27, 2008
    ty, that worked perfectly :) ty again
    Problem Solver:
  • 12 Answers
What you do is open up your computer case and find the cable that connects from your USB drive that leads to your motherboard. Unconnect it from your motherboard and reconnect it, it should give you the sound of device connected. What you probably safely removed your USB drives instead of your flash drive.
Posted on Mar 27, 2008
I cannot get a SanDisk flashdrive to go into either of the USB ports on my new desktop computer. I am using the USB ports located on top of the computer
To test the functionality of the usb ports in front of the computer
1. Insert another flash drive or another usb device like a usb mouse on front the computer 2. If it detect the usb device that means 2 things flash drive might be bad and the front usb port is working 3. If it does not, It means that the flash drive might be bad or the usb port is not connected to the front panel of the computer 4. Try also inserting the flash drive at the back of the computer see if the usb drive is detected in all ports 5. Check the BIOS for any usb port associativity
Jul 05, 2011 | HP Computers & Internet
My sony flash memory is showing in accessible pls help
There is a way to make it not inaccessible but that would require you to reformat it using the steps below:..
1. To verify that the USB flash drive is actually the cause of the problem by inserting the drive into a USB port on a different computer. Check to see if the drive remains inaccessible on the separate computer drive. Plug the USB flash drive back into the original USB port if it still shows up as inaccessible.
2. Please open the computer's Start menu and then click on the "My Computer" button to bring up a new window with a list of the drives connected to the PC. Find the "Map A Network Drive" button at the top of the new window. Click on the button and wait for another window to pop up on the screen.
3. Now click on the "Drive Letter" drop-down menu at the top left side of the window. Select a drive letter that you want to use for the USB flash drive. Click on the "Browse" button and then locate the USB flash drive. Click on the drive and then click on the "Open" button. Click on the "Finish" button and then restart the computer.
4. Please return to the Start menu and then open the Control Panel. Double-click the icon in the window labeled as "Administrative Tools." Scroll down through the new list of options that will populate the window and then double-click the "Computer Management" link. Click on "Allow" if your computer's operating system asks for your permission to open the Computer Management menu.
5. Find the "Storage" button at the left side of the window and click on it to bring up a new list of options. Click on the option labeled as "Disk Management" and wait for the list of attached disk drives to populate the panel at the middle of the window.
6. Right-click on the drive letter you selected earlier when you mapped the USB flash drive to the computer. Click on the menu option labeled "Format." Make sure that the "File System" heading is set to "NTFS" and then click on "Start" to reformat the drive. Volia.
7. Restart your computer once the reformatting process has completely finished. Attempt to use the USB flash drive again. If still no luck, try purchasing an entirely new flash drive if the computer still will not recognize the drive, as that will indicate it is defective or physically damaged somehow.
Mar 20, 2011 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
I bought new HP p6000 Series Desktop computer where the driver is not reading Cruzer or any flash drive. What to do.
look on the back of your computer for a hi speed usb port, or just use any back usb port. some computers like mine dont have a "bus" to the mother board to the front usbs or because they are piggy backed to the front they dont pass through.
Oct 10, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
My DameElec 2GB is not working on my XP Computer
try installing the flash drive once through add new hardware wizard from control panel. it might fix the problem for you. also plug the device directly into the usb slot present in the backside of the computer.
Jul 17, 2010 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
Sony camera says Switch on [MENU] when i upload pic from USB cord
1) Try uninstalling then re-installing your Sony software.
2) When you connect to the PC and switch on, Click on Start - "My Computer". Your hard drives and disk drives should appear in the window.
Have a good look, is there a new drive, it may be called Sony, or USB mass storage device it may just be called drive E or F.
If so double click on that drive, if there's a folder there, double click on there, with luck you should see your pictures, that new drive is really your camera.
You should be able to move pictures by copy and pasting. Once copied you can deleted them from your camera.
3) You can buy a device called a "Memory card reader" Make sure its good for sony memory sticks.
You take you card from you camera and put it in the card reader. Then, once plugged into a USB port its just like another HDD as described in 2.
4) I should have said this first, try another USB port if you can, it my just be dust in the port making life hard............
Good Luck.
May 08, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
I have sony micro vault 2 GB pen drive but win xp sp3. but i plug pen drive the message is flash ''usb Device not recognized'' so how can solve this problem. how can work my pendrive properly.
Goto my computer and right click, left click on properties and find device manager.
Scroll down until you find universal serial bus controllers click on the + sign, right click on 'Enhanced Host Controller', right click and choose update driver, use the internet option to download updated driver, this should hopefully resolve your USB problem.
If it does not update and the usb drivers and they seem fine, then the problem could be with the flash drive, try the drive in another computer to check that it is working.
Apr 02, 2010 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Not formatting
I had the same problem with my 1GB SONY MicroVault Clip flash drive. Hardware and the drive shows up on Vista, but it refuses to open or format it.
1) IT MANAGED TO REFORMAT NICELY ON WINDOWS XP!!!! So try this, or
2) When the Micro Vault does not operate well, please download the format software from a "download" button and re-format the Micro Vault. http://www.sony.net/Products/Media/Microvault/products/usm-l/dl.html
hope this helps guys!! :D
Apr 23, 2009 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Windows was unable to complete the format
sir
u dont need to buy a new one. You can download file shredder from here . do following things :
  1. download and install file shredder
  2. shred all the files which are in pendrive(after shredding u will not be able to recover them)
  3. then try to format it .,
thankyou for using fixya
dont forget to rate the solution
have a nice day
Mar 12, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Flash drive ports on teh fron wont work on pc
If your system is USB 1 rather than USB 2 then some flash drives will not work. Not all usb 2 flashdrives are backwards compatible. My kids flasdrives will only work on my usb2 ports & will not work at all on my wife's computer which has the older usb 1 ports.
Dec 19, 2008 | E-Machines etower 500is PC Desktop
Usb flash pen drive
i have bought kingston pen drive 8 GB..d problem is that files get corrupted...there r all sorts of different symbols instead of the actual file name...the space occupied by it also changes somehow....i tried formatting it but the problem persists.. i encountered same problem with my earlier SONY 4 GB PEN DRIVE(vaio)... please suggest some remedy..
Jul 12, 2007 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Computers & Internet Logo
207 people viewed this question
David Payne
David Payne
