Question about Craftsman 24 Hp 48" Deck Yard Tractor
Front wheel removal . how do you remove wheel axel cover???
  • 284 Answers
Most likely like a hub cap
find a reasonable size screwdriver and CAREFULLY pry lightly around its edges until the clips give
Posted on May 10, 2010
REMOVE AXELS FROM FRONT DIFFON 94FORD
if you mean the axel shafts, remove wheels, hub covers,calipers, rotors, spindles..
separate RH axle at its plunge from the stubshaft. pull th LH shaft out.
further questions? you should have a manual. they are free to borrow or photocopy at the library
Apr 02, 2014 | 1988 Ford Ranger
Size of nut on 2002 front wheel axel
need to now the vehicle 1st 2002 what?
Jun 09, 2012 | Cars & Trucks
Need to know how to remove front halfshaft on a 1998 chevy blazer
Google the exact steps...you'll be amazed what you find.
Apr 19, 2011 | Chevrolet Blazer Cars & Trucks
2001 triumph tt600 fronnt wheel removal
support the bike so that the front wheel is off the ground.
1, remove front mudgaurd, 2, remove brake caliper, 3 disconnect any speedo drive cable or wires, 4, loosen axel nut, and withdraw the axel, 5, remove the front wheel.
May 23, 2010 | 2001 Triumph TT 600
The axle from a jeep 4x4 is broke , both axles, how do i take out the rest of the parts?
The front axel is a two piece assy. remove the 4wd
shift moter from the axel housing. Once the moter
and fork are off , remove outer axel.To remove inner
axel, remove differential cover and let it drain.
There is a C clip on the axel, remove it and work the
axel out through the axel tube.(if it is broken)
To remove the rear axel. Remove diff. cover and drain.
Remove the pinion lock nut(or spring clip) and slide
back pinion shaft. Remove retaining clip from axel
and remove axel. To remove broken piece I use to
use a length of an old whip antenna, to push it out.
If you can find a piece of heavy gauge wire to push
it out.(a plumbers snake may work)Also only have
one axel at a time out of either housing, this will
make it easier to reinstall the axels.
I hope I was of some help. Good luck.
Jan 30, 2010 | 1995 Jeep Grand Cherokee
I have movement in the rear wheels on a 2003 Ford Mustang.Do I need to change the wheel bearings? How do I remve the hub?
Sounds as though your bearing could be bad, does your Differential have a cover on the back ?If so you'll have to remove it and remove the retainer rings (1) on each side of the inner axel .Then you should be able to remove the axels,but still may have to remove the Brake back cover also .Notice how much gear lube is left in the housing when you remove the cover . Don't forget to also replace the dust seals as well .
May 02, 2009 | 2003 Ford Mustang
Rear axle seal replacement
Drain axel of Fluid, Roemve Diff Cover (Push IN on Axel to reseal at Wheel side) Remove KEEPERS From Insied END of axel then Pull OUT on WHEEL END of Axel. use Proper Seal removal tool to remove seal. Also Use PROPER Install tool for SEAL INSTALL Reverse Procedure to Install. In hopes this helps you Out.
Please RATE Me Also LoL Thank You.
Mar 24, 2009 | 1999 Ford F150 Regular Cab
Instructions for removing/replacing rear wheel, 2007 FLHR
remove the bags and side covers /remove clip from rh side of axel remove nut/put wrench on lh side of axel and twist to loosen belt adjustment caution !! note clamshell adjusters both sides they need to go back the same way when refiting wheel knock the axel from rh side through with large screw driver use hand not hammer the wheel should drop stand over back fender lift wheel slightly slip off belt roll brake caliper up and outwards untill it clears drop wheel down and remove brake caution again!! belt tension should be 10lbs 4.5 kg force centre from front and rear sprocket you will need belt tension tool for correct tension
Jan 18, 2009 | 2006 Harley Davidson FLHR Road king
Leaking left rear wheel seal.
Loosen differential cover and let oil drain. Remove cover, remove E clip lock from axel. Pull axel out. Remove bearing seal. Install new seal and reinstall axel. Reinstall E clip lock and new cover gasket. Fill with 75-90wt gear oil. Now I know that sound pretty straight forward. But there are some things to remember. The E clip lock can be difficult to remove sometimes. The most important thing is the seal, you will need to make sure it gets seated correctly and not torn when installing axel
Jul 26, 2008 | Chevrolet Silverado 1500 Cars & Trucks
LEAKING FRONT AXIL SEAL
take the wheel off , unbolt caliper and sling it out of the way with a bungi cord, take off the rotor, then you have too take the pumpkin cover off the axel diff in the front (drain fluid first) easy way to do that take out bottom and side bolts out then leave top 1 or 2 in but finger loose. pry cover off with a sturdy scrapper from side allowing fluid to leak out from bottom of cover. when fluid is done comeing out then take off cover. to take the axel out to replace the seal you have to push the axel inwards to remove the C- CLIP on the end of the axel shaft that slides into the inside of the pinion gear (use a extending magnet) keeps gear oil on your hands and from dropping it into the pumpkin housing. then all you have to do is slide the axel shaft out. then replace the seal .
Jul 01, 2008 | 1990 Jeep Wrangler
Craftsman 24 Hp 48" Deck Yard Tractor Logo
109 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
