Question about GE PSC23NSWSS Profile Counter-depth 23.2 Cu. Ft. Stainless Side-by-Side Refrigerator
I have a GE Profile side by side with water and ice in the freezer door, it is about 3 1/2 years old. The water was barely coming out of the dispenser, I changed the water filter and it is not any better - maybe worse and I have let it run for close to 5 minutes
  • 3 Answers
We had this problem on our own fridge at home. it turned out the plastic lines which feed these appliances liable to fill up with lime and calcium which will restrict water flow. take a look at getting a new line.
something else to look at. is the tube getting kinked when you push the fridge into postion?
let me know if this helps. davcol47@hotmail.com
Posted on Feb 03, 2011
GE Profile PSS26PSTA SS freezer problem
Forget the warranty - it is only for the compressor and that is usually five years. Did you check for freezer temp - wet cubes indicates too warm up there. Water dispenser lines may be clogged.
If low temps you may have low refrigerant or a defrost mechanism not working - if not working there should be ice buildup on line entering the evaporator in back of compartment.
Jun 16, 2017 | GE Profile PSS26NGS Side by Side...
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Profile stopped making ice. 2 yrs old
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath freezer needs to be 0 degree F to start ice maker
Aug 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Apr 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water on Floor Outside Freezer (Side by Side)
take a wire and run it through the drain until there is no resistance and then put hot water into it.
Mar 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
NO DRINKING WATER
common problem the water line inside the freezer door is frolzen up . to fix remove everthing from the freezer door , turn off freezer . open freezer door and put a blanket over the opening to the freezer leaveing the door to room temp for an hour or so to defrost . check if defrosted . remove blanket close door . this will happen with ge , try seyying the freezer control on the next lower number (warmer)
Jan 14, 2009 | GE Profile PSW26P Stainless Steel Side by...
Not getting water from dispenser in door
The connector that is leaking is bad causing tubing to come out and leak. The reason it won't flow is it is iced up inside of the door and no, unfortunately, you can't disassemble the door to get to it. It requires a door replacement. The connector is part number WR02X10471 from www.geappliances.com or GE Factory Service Parts at 1-800-626-2002
Dec 20, 2008 | GE Profile¿ Arctica® Energy...
GE Profile PSC23MGNA too cold on frig side & icing up on freezer side
Check your thermostat if it is still functioning well.
May 02, 2017 | Refrigerators
Front dispenser On GE stainless side by side
Could be the connector at the bottom of the freezer door corroded but it could also be the main PCB failing as the low voltage power supply may be dropping out . By the 'light inside' do you mean in the dispenser or inside the fridge ??
Aug 13, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice maker not working
have you felt water in the ice maker or ice cubes thats the only way you know for sure.. just cause water in doors works doesnt mean icemaker getting water.. got different valves giving water to different places Is your freezer temp. right.. has to be right temp for icemaker to work.. check back wall in freezer make sure no frost buildup and if fan working
Sep 02, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE PSC23NSWSS Profile Counter-depth 23.2 Cu. Ft. Stainless Side-by-Side Refrigerator Logo
97 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
