Question about Husqvarna Forest & Garden 125l 18" Gas Trimmer
My husqvarna 125L weed eater will only run with the choke on why ?
  • 198 Answers
Sometimes it's caused by too much air in the mixture---check for leaks around gasket where carb meets head--also, check the jets--make sure they are not clogged
Posted on May 10, 2010
My husqvarna 123L weed eater will only run on full choke I bought this way and person before played with carb settings. I rebuilt carb now want to get factory settings
check how the carby was put together as the problem is a blocked main jet or diaphragm not working properly
it is sucking fuel in on full choke but the jet is not allowing fuel in to keep running
Jun 25, 2015 | Husqvarna Garden
How to replace primer bulb on husqvarna 125 l weed eater
It just unscrews off the side of the carb, 4 screws hold it on. Its a pretty simple procedure.
Apr 25, 2012 | Husqvarna Forest & Garden 125l 18" Gas...
Husqvarna 125 will not idle down. ( weed eater) only idle down to about 1/2 operating speed
If you can, adjust your idle speed screw. It is normally a good-sized Phillips screw that rests against the plate on the end of the throttle shaft. You can see it good herel
http://www.zamacarb.com/tipspage.html
Sep 05, 2011 | Husqvarna Forest & Garden 125l 18" Gas...
Husqavarna 125L E TEC weed eater won't stay running
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 24, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
What is the oil to gas ratio for the husqvarna 125l weed eater
Most trimmers use a 40:1 ratio on fuel mixture. Check the gas tank on your trimmer, as some manufacturers label it as an imprint in the plastic tank itself.
Hope this helps,
Chip
Apr 10, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
Want to remove huscavana weed eater head
You should find a hole in the piece just above the trimmer head, this should line up with another hole deeper in the area. You stick a piece of rod in there to keep the head from turning. Use some pb blaster penetrating oil to help loosen up the head.
Feb 25, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
Husqvarna Forest & Garden 125l 18" Gas Trimmer Logo
1,654 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
