Question about Radio Shack Pro-97 Handheld Scanner
GRE prs 295 channels locked out
GRE psr 295 - how do you get this scaner up and running, we have never used one before, when u press the scan button, it comes up all channels locked out , and wont pick anything up, just lots of white noise, can u help???
  • Bal Chaggar Sep 18, 2013
    Hi sam. having the same issues. It is near on impossible to follow the owner's manual. Plenty on line. I am a novice and would appreciate answer to your problem it'll help be to get started. Thanks
    not a lot of help from suppliers and cant get manufacturer. Not a lot of support in forums either.
    President:
  • 2,761 Answers
This message usually means that the scanner has been cleared of all programming. Press the MANUAL key repeatedly to review channels. If 000.0000 shows, it means that you need to program the unit.
Need the manual for your scanner? You can download/print it here:
http://www.greamerica.com/support/index.php?_m=downloads&_a=viewdownload&downloaditemid=1010
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
Posted on May 08, 2010
My GRE PSR295 scanner wont switch on
first off check your batteries. if you are using a rechargeable battery pack disconnect it and try it off the power supply alone bad battery packs can and generally do keep radios from powering on. If this allows it to come on, try charging it for 24 hours, and then deep cycling it several times ( run the scanner with sound such as on a noaa weather channel) until it goes dead and then recharge, to recondition the battery pack. if this doesn't work the pack will need to be replaced or rebuilt (batteries plus can do this) if the radio just uses discrete rechargeable batteries simply replace them. meanwhile I'll look for a manual for you....
Here you go
http://www.manualslib.com/manual/703072/Gre-Psr-295.html#manual
Feb 16, 2015 | Radio Communications
Handheld radio scanner frequiencies help
Go to "RadioReference" dot Com and you can get frequencies for your area.
Feb 20, 2013 | Grecom Gre Psr-255 50 Channel Handheld...
What are the frequencies for a grecom pro 255
Hi Tracy,
If you are looking for frequencies to program into your radio scanner, try this: www.radioreference.com, they have the best online state by state listing for the USA.
Cheers,
Peter
Can the GRECOM PSR255. be used to scan for aircraft /airband frequencies
Your radio is not capable of recieving air band frequencies. It will only receive 4 bands consisting of: 26 - 54 MHz; 68 - 88 MHz; 137 - 174 MHz and 380 - 512 Mhz.
The VHF airband uses the frequencies between 108 (just above commercial FM radio) and 137 MHZ (just below 2 meter Ham radio). Amplitude Modulation ("AM") is the mode that transmissions are made. The lowest 10 MHz of the band, from 108-117.95 MHz, is split into 200 narrow-band channels of 50 kHz. These are reserved for navigational aids such as VOR beacons, and precision approach systems such as ILS localizers
Jan 26, 2013 | Grecom Gre Psr-255 50 Channel Handheld...
GRECOM PSR-200 DESKTOP SCANNING RECEIVER WHEN SCANNING WEATHER CHANEL KEEPS COMING IN.
NOAA weather broadcasts are continuous, therefore scanning is interrupted when your receiver locks on that frequency. You need to lock out all NOAA channels
Nov 17, 2012 | Grecom PSR-200 Desktop receiver, analog
Grecom psr-200 .when scanning weather chanel comes in .what is problim.
IF you have a weather frequency programmed in as a scanning channel, it will stop on it everytime, so you need to go to 'manual' on the weather channel, and press 'lock-out' so that it isn't on during scanning. You can still manually go to that channel, but it won't stop while scanning that way. Good luck.
Looking for manual for Yamaha PSR 295 keyboard
Hey there,
Here's a link to the manual you're looking for:
http://usa.yamaha.com/products/musical-instruments/keyboards/digitalkeyboards/portable_keyboards/psr-295/?mode=model
Click on the "support" tab. It's the second link down.
Hope this helps you out! If it did, feel free to rate me :)
Cheers
Mar 08, 2011 | Audio Players & Recorders
I have a uniden bearcat scanner and cant pick up my local police dept. I put the frequency in and still dont hear anything. I have a bc145xl 16 channel scanning radio and want to know if its compatible...
If you programmed the correct frequency, you should be getting reception. Check www.RadioReference.com to verify the frequency. Otherwise, you may be too far from the transmitter to receive signals. Try your scanner in other locations, check your antenna, and try receiving the PD on another scanner.
The MARCS - Ohio Multi-Agency Radio Communications system - is a Motorola Type II SmartZone Omnilink Trunking system that utilizes APCO-25 digital transmissions. Your BC145XL is not compatible with trunking or digital systems. In order to follow the MARCS you will need one of the following scanners:
GRE PSR-500, PSR-600
Radio Shack PRO-106, PRO-197, PRO-96, PRO-2096
Uniden BC250D, BC785D, BC296D, BC796D, BCD396T, BCD396T, BCD996T, BCD996XT, or the brand new HomePatrol-1
Bill B.
Listening in since the 60's
Nov 11, 2010 | Radio Communications
SCAN HEAD LOCKED
that machine has a scaner lock on it, on the exit part of the machine upper front there is a locking dial. turn it to unlock scaner.
Oct 25, 2007 | Sharp AL 1215 Black and White Copier
Radio Shack Pro-97 Handheld Scanner Logo
787 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
