Question about GE Refrigerators
I have a GE side by side model #gss25ufpd ww. The water dispenser quit working and, not knowing a lot about it, I played around with the union connector. It leaked when I pressed on it, so I replaced it. Still doesn't work. When I take the connector off and press the water dispenser, water comes out of the hose full blast, so the problem is in the door of the freezer. Unfortunately, I don't know how to get inside there to see what the problem is, much less fix it. Help
  • 15 Answers
SOURCE: Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Posted on Feb 03, 2009
tborn6
  • 700 Answers
SOURCE: GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Posted on Apr 03, 2009
aasc
  • 1606 Answers
SOURCE: A hose is leaking on G.E. fridge - to water dispenser, I think
It sounds like someone has repaired this hose , due to the connectors . There should be no connectors except for 1 , below the freezer door . This hose can get hot from the compressor heat , and break .
My suggestion , would be to replace the water resivoir in the refrig section , behind the bottom crispers . This resevoir has a hose that goes completely to the water valve , without any connectors , and a hose that goes to the coupling under the freezer door , for the water dispensor . If you remove the bottom kick plate , the hose from the door , goes about 8 " to the coupling which connects to the line from the resevoir .
Posted on Sep 29, 2009
  • 40 Answers
SOURCE: Ice maker leak in GE refrig.
when the refrig.goes through a defrost cycle the water from the melted ice is supposed to go out a drainline to a pan inthe back.most likely the drain has plugged up and needs cleaning.remoe shelving andtake back panel off drain hole is located below coils,be carefull of coils ,delicate
Posted on Jan 22, 2010
Testimonial: "Thank you, drain is clogged. Problem solved."
aasc
  • 1606 Answers
SOURCE: My GE ice maker is working, but the water
The line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . WR49X10173 , is the part number for the heater for the water dispensor , to keep this from happening again . Instructions come with the part .
Posted on Mar 05, 2010
How do you get the water dispenser on a GE side by side model GSS201EPD WW to work?
Chances are that the=> WR57X10050 Water Inlet Valve has become defective on the dispenser side of the valve.. I am here should you have questions, Thanks John T. Appliance 911
Jun 28, 2015 | GE Refrigerators
How do you fix the water dispenser on a GE side by side refrigerator model GSS201EPD WW
Here are a couple of possible problems. Most common one is a defective water inlet valve. It is the plastic assembly at the lower back area where the house water connects to. On dispenser systems it is actually 2 valves in one unit---half lets water in to icemaker---the other half lets water dispense at door. It is electrically operated so if half goes bad , the other half can still work. If bad it needs replaced as a complete unit.
Second possible problem with some GE side by side models is they had problems with the water line in the door going to the dispenser sometime would freeze up. They came out with a heater kit that needs installed in the dispenser area to defrost the water line. Call GE service with your model number and they may be able to tell you if you need that kit installed.
GE refrigerator/model GSS201EPH WW. Water dispenser works fine, ice dispenser does not work
there is a pump which pushes water up to ice maker, it usually quits, causes the prob. 90% time
Jul 17, 2011 | GE Refrigerators
I have a GE Refrigerator GSS22JFMD WW with a ice
The water supply in the recessed part of your door is frozen. very common with this model. You will need to turn unit off and with freezer door open use hairdryer on the area where water dispenses and on the recessed area as well. This is time consuming but only other remedy is to leave off and door open for 24 hours. hope this helps.
Feb 12, 2010 | GE Refrigerators
GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
The water flow on my side by side, water & ice dispenser in the freezer door, keeps decreasing. Model GSS25UFPD CC. Is there some way to increase the water flow?
I would install the filter bypass ( the piece which came with the refrig ) to see if that will improve the water outflow . If so , then replace the filter . If not , you will need to replace the water valve . Pt # WR57X10032 . This part runs about $ 40 , and is the part that the wall water line connects to on the back of the refrig .
Nov 22, 2009 | GE Refrigerators
GE Freezer Side Ice Dispenser
It isn't supposed to free wheel and the only solution that I know of is tumbler replacement. I have the same issue and am currently hunting replacement parts.
Jun 16, 2008 | Refrigerators
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Water leaking out of freezer door water dispenser
The fill valve that supplies the water may not be shutting off completely. Also check to see that the lever is closing completely.
Apr 04, 2007 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
99 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
