Question about Norelco Arcitec Electric Shaver with Jet Clean System - Gray/Black
How do you change the blades/ norelco arcitec
How do you change the blades / can't seem to get them out
  • Norelco Master
  • 1,610 Answers
On Arcitec models, the whole heads simply pulls off the top of the shaver. See picture below.
how do you change the blades/ norelco arcitec - file_34_1.jpg You will find replacement heads for Arcitec models at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Posted on May 08, 2010
The only way you can clean these machine is the use of a needle.
you need to use a needle to take the hair and other stuff out and it take a lots of time. untile the blade turns freely in the chamber by your finger. other wise you have to replace the whole head. as of they plan to do to get more money from the users.
good luck
Posted on Nov 01, 2011
5 Suggested Answers
SOURCE: how do i clean the norelco arcitec. i can't get
I just got off the phone with philips on this. answer... you are not able to disassemble. In a shocking disclosure ..they do recommend buying new head unit at about 40 bucks.
Bye Bye norelco. Your shortsighted stupidity and greed in creating this design will hopefully bite you.
Posted on Aug 09, 2009
brector3
  • 1610 Answers
SOURCE: how do you change blades on a norelco arcitec?
Blades for Arcitec shavers should be changed every 12 months per the manufacturer instructions. You will find them at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
On this model type, the entire head assembly is changed. Instructions are found on the manufacturer packaging and a simple diagram is also found at shaveroutlet.com. See link below
http://shaveroutlet.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/f/i/file_34_1.jpg
Posted on Nov 15, 2010
brector3
  • 1610 Answers
SOURCE: how to remove the blades
On Arcitec shavers, the blades can not be removed from the head assembly. This makes it difficult to thoroughly clean them and they must be replaced reqularly because of this.
If needed, you will find replacements at shaveroutlet.com.. See link below
Posted on Nov 18, 2010
brector3
  • 1610 Answers
SOURCE: I need a users manual for my philips norelco
The user manual will not help you with this because the Arcitec models were designed so that the cutters could NOT be removed to be cleaned. This is a major disadvantage with the Arcitec models as you can not disassemble the heads to thoroughly clean them. This causes you to have to replace them more frequently.
You can try running the shaver head in a dish of rubbing alcohol to try to loosen the build-up and rinse it out but that's about all you can do.
If you need to replace them, you will find at shaveroutlet.com. See link below
Posted on Nov 03, 2011
How to change blades on norelco arcitic razor
Replacements for Arcitec models can be found at shaveroutlet.com using the link below
Removal and replacement is simple. See diagram below
Jun 26, 2014 | Norelco Arcitec Electric Shaver -...
How do i clean the blades. I don't know how to unfasten them so i can clean them
The Arcitec series shavers have a very poor design and shaver heads can not be disassembled like the older model that you had. The blades can not be removed from the assembly that contains them. The only way to clean them is to run them under hot water or rense them in an alcohol solution. Unfortunately, this method still leaves much to be desired.
Many users of the Arcitec models report having to change the heads twice as often because of this.
Complains can be made to Norelco customer service at 1-800-243-3050
If replacements are needed, you will find then at shaveroutlet.com. See link below
May 14, 2011 | Norelco Arcitec Electric Shaver -...
How do you get the rotary heads off the shaver to clean or change them?
The blades can not be individually removed on the Arcitec model shavers. Instead, you must replace the entire head assembly. It simply pulls straight off. See diagram at the link below
This is a very poor design because you can not remove the individual blades for thorough cleaning. This makes replacement necessary more frequently than older Norelco shavers. If you need replacements, you will find them at shaveroutlet.com. See link below
Apr 25, 2011 | Norelco Arcitec Electric Shaver -...
How to remove the blades on a norelco arcitec razor
Nov 18, 2010 | Norelco Arcitec Electric Shaver -...
How do you change blades on a norelco arcitec?
Nov 14, 2010 | Norelco Arcitec Electric Shaver -...
How to change the blades or head
You will find replacement heads for Arcitec models at shaveroutlet.com. Instructions are on the box they come in. See link below
You will also find a diagram at shaveroutlet.com. See link below
Oct 21, 2010 | Norelco Arcitec Electric Shaver -...
Norelco Arcitec Electric Shaver with Jet Clean System - Gray/Black Logo
2,164 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
