Question about Medion MB MSI 1012 (40011657) PC Desktop
Computer will not install anything. Windows update will download but fail to set-up? snytax error etc.
  • 438 Answers
Some important system files must have been gone missing. try installing your Operating System again!!
Posted on May 10, 2010
How can I stop update windows 8.1 ? I installed this windows by mistake . Now I can't update every time.
I don't think the updates have anything to do with failure of other downloads. But in the configuration screen, you can change the update settings for windows. At least when you log in as an admin.
I do have to advice to try to find out what is causing your downloads to fail, because it is not wise to not update windows.
Jan 06, 2015 | help.com Computers & Internet
I have Vista for Business on a computer. Suddenly the log on picture shows on the screen, but the computer says the user information is unavailable and won't let me log in!
This sounds like a failed update. Restart the computer and hit either F2 or F8 or possibly Tab or Delete once the splash screen comes up. This should give you a windows startup option for safe mode. Click Safe Mode with Networking and let the computer startup. This will bypass all current startup items and possible problematic services. Login and start up Task Manager. View startup items and look to see if anything is starting up that says "Windows Update" or if anything else stands out that shouldn't be there. Names that are random garbled letters, etc. Disable these for normal startup. Now click on control panel under start menu and go to windows update and see if any updates failed to install. If they did, disable install automatically in windows update.
After this go to "run" and type in msconfig. Click normal startup, hit apply, when the message that says "restart computer" pops up click yes and let it restart the computer normally.
Sep 09, 2014 | Microsoft Windows Vista Business Edition...
Hi my mum has just purchased windows 8..can get onto facebook...but when she wants to play mindjolt games..(golf solitaire) it will come on... but then has a white screen where the game should be.altho it...
Hi there. Firstly... make your mom a cup of tea . You know how to calm her down . Then take on this task . It looks like a impossible task , but just follow the instructions . You can do this: Install the Windows 8.1 Update (KB 2919355)
  • ?Email
  • Microsoft support. Code 0x800F0922 This error might mean that a file needed by Windows Update is damaged or missing. Here are a few steps you can try to fix the problem:
    1. Run the Windows 8.1 Update troubleshooter to fix the problem.
    2. Install the Windows 8.1 Update or Windows RT 8.1 Update.
    Code 0x800F0923 This error might mean that a driver or other software on your PC isn't compatible with the update. For info about how to fix this problem, contact Microsoft support. Code 0x800F0922 This error might mean that your PC couldn't connect to the Windows Update servers. If you're using a VPN connection to connect to a work network, disconnect from the network and turn off the VPN software (if applicable) and then try to install the update again.
    The error could also mean there isn't enough free space in the System Reserved partition. You might be able to fix this problem by using third-party software to increase the size of the System Reserved partition. Error: We couldn't complete the updates. Undoing changes. Don't turn off your computer.
    Error: Failure configuring Windows Updates. Reverting changes. These are generic errors that might appear any time a Windows update fails. You'll need to determine the specific error code to investigate how to best resolve this problem
    You can find the error code for the failed update by viewing your update history. Look for KB 2919355 in the list, note the error code, and then contact Microsoft support.
    To view your update history:
    1. Open Windows Update by swiping in from the right edge of the screen (or, if you're using a mouse, pointing to the lower-right corner of the screen and moving the mouse pointer up), tapping or clicking Settings, tapping or clicking Change PC settings, and then tapping or clicking Update and recovery.
    2. Tap or click View your update history.
    Error: The update is not applicable to your computer. This error might mean that your PC doesn't have the required update KB 2919442 installed. Check to make sure that all important updates, including KB 2919442, are installed on your PC. If all updates are installed, you might need to refresh your PC.
    To refresh you PC:
    1. Swipe in from the right edge of the screen, tap Settings, and then tap Change PC settings. (If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, click Settings, and then click Change PC settings.)
    2. Tap or click Update and recovery, and then tap or click Recovery.
    3. Under Refresh your PC without affecting your files, tap or click Get started.
    4. Follow the instructions on the screen.
May 07, 2017 | Computers & Internet
Acer Extensa 5620 running Vista Starter can't install or uninstall anything!
have advanced uninstaller installed and clean out everything with this excellent free tool.
Apr 11, 2014 | Acer Extensa 5620-6119 Notebook
Code Oxcooooo22
Even when I am using the administrator account I can not download updates
from the windows update site the yellow icon used to appear but no updates,
now no icon appears, these messages come up whenever I've tried to download
updates manually from the windows update site [Error number: 0x8DDD0002] or
something that goes like this OxOOOA46 and there is a link to where one gets
instructions on fixing it. I have done what was suggested which was to go to
tools internet explorer security and make sure user persistence user data was
enabled I've done all this to no avail. I've been told that I need to be an
administrator to download updates but anytime I've tried to download updates
I've been using an account with administrator privileges.
I've had problems accessing the internet for ages but it is only lately that
I can't download updates from the windows update site.
I keep getting these error messages when I switch on my computer using the
limited account. ccApap.exe - Application Error.
The application failed to initialise properly (OxcOOOOO22) click on ok to
terminate the application.
I click on ok and then another message comes up osCheck.exe - Application
Error
The application failed to initialise properly (OxcOOOOO22)click on ok to
terminate the program
Again I click on ok and another message comes up PIFSvc.exe - Application
Error
The application failed to initialise properly(OxcOOOOO22) Click on OK to
I click on ok and windows loads as normal. I can access programs such as
works and windows media player but my anti virus (Norton Internet Security
2007) has disappeared but when I use the Administrator Account Norton seems
to be there and seems to work ok.
My computer is a year old and I have had to get it repaired a couple of
times but I don't want to spend any more on it as they can't seem to fix the
problem. I can do what I want so long as it is offline anything that
involves the internet I have problems with. The computer Operating System is
Windows xp Home Edition with service pack 2. I use Internet Explorer version
7.
Any ideas on why I have problems with the internet and what I can do to
solve them would be much appreciated.
None of those failing modules that you mention are from Microsoft.
I suspect that they may be from your security package(s).
Try enabling the Windows firewall only. Uninstall your other security packages
and then retry getting the updates.
BTW if you are only concerned with getting the updates but don't care how
you could also try using the Windows Update Catalog, download and install
manually from there.
Mar 21, 2011 | Computers & Internet
Windows Vista: I cannot install anything at all.
Is your Vista a 32 bit or 64 Bit O/S
open this link and run the Windows readiness tool, This will help the PC unblock any failed updates for Windows and help you install the new updates.
http://www.microsoft.com/downloads/details.aspx?FamilyId=b4d90b06-c27d-4483-bc1f-04d43fa7b293&displaylang=en
Windows installer for Vista is Installer version 4.5, so the updates should fix the issue.
Jun 29, 2010 | Computers & Internet
How to fix this problem
http://www.vistaheads.com/forums/microsoft-public-windowsupdate/322548-error-646-a.html read that page, has all the info you need on how to get info and the official MS page to fix it.
Should be able to help you properly
Jan 03, 2010 | Microsoft Windows Vista Home Premium with...
Downloaded windows automatic update stuck on 3 of 3 for last few days. tried last known good config does nothing, i always return to updating 3 of 3 cannot get my comp to do anything else. help desperately...
An issue has been identified by Microsoft that, after installing Windows Updates, a Computer displays a Configuring updates: stage 3 of 3. 0% complete message, reboots, comes back to that message again, and repeats the cycle. This problem occurs when Windows Update is attempting to install update 937287.
Follow this procedure to resolve the error:
1. Remove all connected peripheral Devices from the Computer.
2. Press and hold the power button until the Computer completely shuts down.
3. Unplug the power cord from the wall outlet.
4. Leave the Computer without any power for at least 30 seconds.
5. Reconnect the Computer to the power supply and then turn it back on.
6. Allow the Computer to start normally.
NOTE 1: Once the Computer has completely started into the Operating System, Windows Updates should automatically finish installing the update. If the update again fails to install completely, restart the Computer in Safe Mode (by tapping the F8 Kay at Start-up) and use the System Restore feature to return the Computer to a time before the issue started.
Click the Start -> All Programs -> Accessories -> System Tools -> System Restore.
NOTE 2: To avoid this issue, obtain and install update 937287 from the Microsoft Download Center separately from all other updates on the Windows Update site. Install the update that applies to your version of Windows Vista so that you can successfully install future updates.
For more information about this error, refer to the Microsoft KB Article ID 949358.
Good Luck!!!!!!!!!!!!!!
Dec 01, 2009 | Dell Computers & Internet
How do i disable the firewall to enable updates? some updates won't install, error code seems to suggest a firewall may be stopping this, the router has a firewall and i think this may be causing the...
The router firewall should never be the cause of failing updates. If the update is detected and download, the installation can only fail because of local computer settings, not a router's firewall.
So your PC's firewall could (maybe) be the cause, but even that is not common.
What is the error message? And is this a Windows update or a specific program update?
Nov 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Action failed for file avgtdix.sys: starting service....
There is a known issue between AVG 8 and Anniversary Edition of Ad-Aware which gives exactly this error, so if you perhaps just got that ad-aware, uninstall it too before trying to reinstall AVG.
Then run the uninstall/cleanup util for Avast because the Windows Add/Remove isn't good for uninstalling antivirus programs. Then try reinstalling it again. If you downloaded the installation package, then it provides the uninstall option. Disable Ad-Aware's Adwatch first! Run the AVG installer. Choose the uninstall option and follow the wizard. When you get to the part to remove user settings, select it. Restart your computer then... Now reinstall AVG using the setup file you got and update it.
Restart Windows twice before you re-enable anything disabled earlier.
Should this not work and you get the same error, that means the original errornous installation is still not out of your system. Download the AVG remover from here:
http://www.avg.com/download-tools
Remove your AVG and reboot to make sure it is not there any more, and try installing again.
Let me know if the solution worked and if yes please rate me:)
Feb 01, 2009 | Computers & Internet
Computers & Internet Logo
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
