Question about Dell OptiPlex GX260 PC Desktop
Dell Optiplex GX260 Tower flashing yellow power button
Everything was working great, not even any slow starts (XP Home Ed). We shut the computer down, went on vacation for 6 days, came home -- now when you press the power button the light flashes yellow and nothing happens. I have hunted online and found suggestions from replacing the PS to messing with the front USB ports. Any suggestions?
  • 2 more comments
  • Anonymous Dec 08, 2008
    Same problem here, flashing (yellow) power light as soon as power is connected. No dell Diag lights on back (none lit up)...
    No Bleeps with RAM or CPU (or both) removed, me thinks Mobo fault tbh... will find out mroe
  • Boli Dec 08, 2008
    Same problem here (with an optiplex SX280), flashing (yellow) power light as soon as power is connected. No dell Diag lights on back (none lit up)...
  • redluck May 11, 2010
    FYI, I have a Dell Optiplex Gx260 tower and there are no diagnostic LEDs on the back.
  • DatGirl May 11, 2010
    My Home PC had same problems. I reseated the memory and it works fine now. THX
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 156 Answers
Hi
Power up the Optiplex GX260 and check the QUAD Pack Diagnostics LEDs (located at the back). Compare the LED pattern to http://support.dell.com/support/edocs/systems/opgx260/en/ug/solvprob.htm#1167139 for more info.
Ideally, to troubleshoot and resolve the issues, try removing all PCI devices, disconnect all external devices/peripherals including keyboard and mouse. You may leave the Monitor connected. Power up the PC and check for successful Power On Self Test (POST). If POST completes (generally fails on "Keyboard not present"), shutdown, connect keyboard and try POST again.
If all goes well, install PCI devices one at a time and test successful POST. This will help identity a failing device.
If issue persists, after removing all devices, remove the CMOS battery for about 90 seconds and try POST again. If same, remove all DIMMs (Memory) and check for beep codes. Compare beep pattern to http://support.dell.com/support/edocs/systems/opgx260/en/ug/solvprob.htm#1176760.
NB: Ensure to remove power lead and press power button briefly to use up flea power before working in the system.
If the system beeps, it suggests that the CPU and systemboard are "likely" fine. Install one DIMM at a time and test successful POST. If there no beeps then the systemboard and/or CU is/are at fault.
Regards
Mike
Posted on Mar 27, 2008
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
I had the same problem (flashing yellow light on power button). Not sure if anyone with this unit actually has the 4 LEDs, but I didn't either.
It was the power supply. Swapped it out and all is fine now.
Posted on Jul 27, 2009
SOURCE:
Dell Optiplex GX260 Mini Tower Remove Front Door
Front panels do come off on that computer, I have one sitting at my feet right now
Jul 23, 2012 | Dell OptiPlex GX260 PC Desktop
Gx270 tower mother board amber LED solid on
If the fan is not spinning this can be the issue ...but it can also be the motherboard itself ..if you have the possibility try to change the fan ..cause if it fails to start the computer will also fail cause the cpu it will shut down the system instantly if it has no cooler working ..(gets to the shut down temperature in one sec or so ) If it seams that it is trying to start ..but , like I said , it shuts down ..just try to change the fan ...but it may be a issue with the power supply or the motherboard as well...
Dec 18, 2011 | Dell OptiPlex GX270 Small Mini-Tower...
Having the same proble with Dell optiplex GX260 very very very slow it takes a day to load Xp SP2 and I added up to 1GB still the PC is very slow. The machine fresh loaded no application loaded only XP...
These things are notorious for having the CPU heatsink grease dry up (and the processor speed steps down) but I'd also scan the hard disk for bad sectors.
If the fan has started sounding like a jet engine, it's more likely that it needs new heatsink grease on the CPU.
Mar 09, 2011 | Dell OptiPlex GX260 PC Desktop
Optiplex gx820 can i connect 300 watt power supply
You listed GX820 and GX260.
I am assuming you meant the GX260.
There are three varieties of the Gx260.
1) The SFF (Small Form Factor) power supplies can be replaced, but I know of no upgrades for these.
2) For the SDT (Small Desk Top), you can get up to a 270 (best I have seen).
Example of where to get one.
http://www.atxpowersupplies.com/180-watt-dell-power-supply-1n405.php?psu=1N405-GX260SmallDesktop
For the Mini Tower, here is an example of a 400W replacement. There may be others for this model.
http://www.cputopia.com/dell-400w-dell-optiplex-gx260.html
I have a GX280 Mini Tower and recently upgraded my PSU to one very similar to the one above.
Feb 21, 2011 | Dell OptiPlex GX260 PC Desktop
Similar problem with Optiplex GX270
hi you did mistake when you connected the fan if the processor is not get the normal temperature it wont start to work . you have insert the fan correctly or fix a correct fan what they give for you to your computer from dell. any questions forward to fixya bye
Jun 16, 2009 | Dell OptiPlex GX260 PC Desktop
Cannot find the usb plug in for the usb flash drive.
Just below the power button, there is a light grey panel with the Dell logo on it. Lift this open; careful, it does not open all the way.
Apr 18, 2009 | Dell OptiPlex GX260 PC Desktop
Dell Optiplex GX260 will not shut down.
Could possibly be virus/malware issue. Try running a full scan to see if anything is found.
Mar 30, 2009 | Dell OptiPlex GX260 PC Desktop
Computer boots up when plugged in,monitor powers down
hi there.......
it is the memory it has to be matched with the actual fsb of the cpu if its slower then it wont switch on.....
and some dell pc's wont work with 1gb sticks so accertain which ram is compatible with the motherboard
Feb 24, 2009 | Dell OptiPlex GX260 PC Desktop
Dell Optiplex Power-on Problem
An Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc...
Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 18, 2009 | Dell OptiPlex GX260 PC Desktop
Dell OptiPlex GX260 PC Desktop Logo
8,990 people viewed this question
Ekse
Clive
Clive
