Question about SanDisk Sansa E280 MP3 Player
Song list not showing on Player e280R
The songs list are all showing up as Empty. It has been working fine. When I browse the drive through Windows Explorer all the songs/files are visible. Although the photos are showing up on the player, just not the music files.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
Nextar MA933A says it accepted music but it didn't
When you download songs, save it first on your My Music folder for you to easily track the song list. Once you have successfully downloaded the songs, insert your MP3 Player. Format your MP3 Player first by right clicking the drive and click format. Once it is formatted, Copy the songs from your My Music folder then Paste it on your MP3 Player drive.
*Note: Try to play your saved song in your Windows Media Player if the song is working fine before you copy it on your MP3 Player.
Drop a comment if you still have questions. I would be happy assisting you.
Your vote is highly appreciated.
Dec 27, 2008 | Nextar MA933A MP3 Player
Nextarm933a mp3 player cant get to play songs or download
Sansa Clip 2GB MP3 player
The user manual wil lshow you how to switch your USB mode from MSC to MTP:
http://www.sandisk.com/assets/File/Downloads/user-guides/clip-usermanual.pdf
-Tha Mp3 Doctor
Dec 19, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip 2GB* MP3 Player
Switch the player from USB to either Auto or MTP mode. Or, you can transfer ALL songs in the manner you have just described. Either way.
-Tha Mp3 Doctor
Dec 15, 2008 | SanDisk Sansa Clip MP3 Player
DOES NOT LIST SONGS, TURNS OFF WHEN PLAYLIST IS SELECTED
format it put all music in then see wat happen it should fix the problem
good luck
Oct 27, 2008 | SanDisk Sansa e270 MP3 Player
Problem in loading song in device
Tracks must be transferred using the Musicmatch Jukebox software supplied with the player. You cannot drag & drop from Windows, even though the player shows up as a removable drive. Musicmatch transfers the tracks, and alkso updates the file list on the player. If the tracks aren't on the file list, the player will ignore them.
Also, you need to have Windows XP and Windows Media Player 10, as Musicmatch uses drivers from version 10.
If you have Windows Media Player 11 installed, you will need to uninstall it to roll back to version 10.
If Musicmatch still doesn't transfer correctly, click on options / tools, and make sure that the device is recognised as "GoGear" , and not "Removable drive"
Apr 03, 2008 | Philips PSS110/17 MP3 Player
Songs will not show up in the mp3 player!
something is wrong with the format of the new songs
Feb 19, 2008 | SanDisk Sansa e260 MP3 Player
No playlist found
One of the pesky features of windows Media Player is that if you delete the song/playlist from the computer's harddrive, and then resync your device to that same computer, then oftentimes the song/playlist disappears. Reacquire the song/playlist, and then try resyncing to the goGear again.
-Tha Mp3 Doctor
Dec 06, 2007 | Philips GoGear HDD1830 MP3 Player
Songs won't show up in browser on MP3 player
o yeah I had this problem, hold option and button and this stuff would come up like equalizer browser and some otehr shit, touch browseritll go back to ur song list.
Sep 13, 2007 | Coby MP-C7085 MP3 Player
Deleting songs from Sandisk
Hi. The minimum requirements of your Sansa E250 is Windows XP and above and Windows Media Player 10 and above. If you're using Windows Media Player 10 or above, your Sansa E250 and its contents should appear on the right pane when you click on the "Sync" tab. You can right click on a song and select "Remove". The songs will be erased permanently from the player. If your songs do not appear on Windows Media Player 10 or above, it is possible that your songs may have been saved on another mode. Your Sansa E250 comes in 2 modes: MTP and MSC. Songs saved on one mode will not be seen by the other mode, and vice versa. There are 2 ways to delete songs from your Sansa E250: By browsing the folders containing the songs, or by formatting the player. You can switch modes by navigating your E250's menu using the following: Menu >> Settings >> USB Mode Next, plug your player in your PC and open Windows Explorer. You should first set your Explorer to "Show hidden Files and Folders" by going to the "Tools" menu (located on menu lists on Windows Explorer window), then choosing "Folder Options", then enabling the "Show Hidden Files and Folders" radio button Deleting Music files under MTP Mode: 1. Your player should appear as a Sansa E250 icon in Explorer as a "Portable Audio Device". Double left-click this icon to browse the player. 2. You'll find a "PPI NAND" sub-folder. Again, double left-click on this sub-folder. 3. You'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it. 4. Your music should appear as individual files or folders. Delete this to remove the file(s) from the player Deleting Music files under MTP Mode: 1. Your player should appear as a Drive letter and entitled either as a "Removable Drive" or as "Sansa E250" 2. Double left-click on this drive letter to browse the player 3. You may find your music files immediately on this folder, or you'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it and view your music files. 4. Delete the music files you want, and they should be removed from the player Deleting files through Format: 1. Formatting the player erases all files in the player, and oftentimes this is the best option to ensure that all files are removed and any corruption eliminated. Also, it is best to format the player when in MSC mode. 2. When the appears as a drive letter (under MSC mode), right-click on that drive letter and select "Format". On the "Format" pop-up window, click "Start" to begin the format process. 3. Follow the on-screen prompts and safely remove the player from your PC when the "Format Complete" display appears. 4. Unplug the player from the PC and when the player is powered up, the message "No Files" should appear on the player's LCD screen 5. Switch the mode back to "MTP", or continue to use "MSC". Note: It is best to use "MTP" when you are transferring subscription music to the player. I hope this helps. :)
Apr 22, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
76 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
