Question about Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger
Weedeater starts strong , briefly runs and completely stops.
This is a Weedeater Model TE475 that is approximately 3 years old and was in storage from March 2008 until June 2009. We can get it to start and run briefly but it quickly loses power and then dies.
It has gotten so bad that we can no longer use it. I tried putting
new gas lines (old ones were leaking) and changing the spark plug. It appears to be a carburetor problem rather than electrical. Any ideas shall be greatly appreciated.
    Scholar:
  • 47 Answers
If it is not REEKING of unburned gas, likely the idle circuit in the carb is fine, but your high-speed jet/pintle seat is caked with crud...
If it was stored with fuel in it, you are going to find that nothing short of a rebuild on the carb is going to help you. :( Luckily, if you are handy many of these smaller diaphragm type carbs can be rebuild with tweezers, slot screw drivers, needle-nosed pliers, can of spray carb cleaner and a rebuild kit from any hardware shop. All told you're going to at most spend $16 bucks. If the engine is otherwise sound with all the work you put into replacing lines, fuel pickup/filer/stainer, the carburetor rebuild route will perk it right up. Good luck!
Posted on May 09, 2010
Out the box.Cranks and runs on cold.when you give it full throttle and knock it off fast idel try to let it idel it die's.After u use it a few min. it die's and want start back till it cools.
This is a common problem out of the box for weedeater products. This simply needs a carb adjustment which is not something the consumer can do (requires a special tool), You will need to take this to a weedeater dealer near you to get it done, it's covered under the warranty.
Jul 21, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Poulan 33cc Weedeater 3 mo old will not idle, dies during acceleration
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Aug 23, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
What is the proper oil to gas ratio for a Homelite 16 inch 150 Automatic that is approximately 40 years old?
Most of the old Homelites were 32:1. I eliminated the mix problem for all my equipment when I started using a synthetic 2-cycle oil called OPTI-2. Somehow it works for all 2-cycle saws/trimmers/blowers etc. I've got equipment that's 20+ years old and still running strong with the OPTI-2.
May 16, 2010 | Garden
Compressor will not run
could be the capacitor, also try looking at the wires around the windings
May 17, 2010 | Clarke Power Products Inc AC2001 2HP 4...
Weedeater starts and immediately shuts off. I checked the fuel filter and replaced the plug the unit is 1 year old.
Change gas, and spray out carb passages. If you tampered with the mix screws then its a whole nother story!
May 05, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Our Model DCC-2200 started boiling and then smoking from the plate.The unit is approximately 2 years old.
The thermostat that controls plate temperature has stuck closed. Stop running the machine until this problem is repaired. A thermal safety fuse should have blown (stopping any further heating).
Feb 02, 2010 | Cuisinart DCC-2200 14-Cup Coffee Maker
Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Logo
676 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
