Question about Sony KDS-50A2000 50" HDTV
I just replace my tv lampe and it dopnt work
  • 10,594 Answers
Make sure lamp cover is fixed back in its position securely after lamp replacement.
Usually people forget to fix lamp cover after lamp replacement that is major cause of this kind of problem.
Let me how many times standby red light is blinking in your tv?
Thanks.
Posted on May 08, 2010
I have a wd-57833 work good I got the same one from some one put in a new lamp tv work for 5 hr then stop working on sound or picture but the lamp is good i put in in my tv and it works so i put the p
If the lamp is new and good to go then you may have to reset the lamp replacement counter in your setting menu. When that is set back to zero you wont have a problem until it is time for a new lamp again.
Aug 19, 2014 | Mitsubishi WD Televison & Video
I was given this model tv. The green and red lights on the front are flashing. Says to replace bulb and close lamp cover correctly. I am missing the lamp cover. Is that going to be a problem?
U mean the Lamp door cover?Yes?Tv might work,might not.Don't know never tries to turn the tv on before without a Lamp door cover close before.There is a blue safety switch though must be press down when the Lamp door cover is close.Test it out.Why don't u just take a piece of tape and tape that blue safety switch down tightly,than turn on the tv.If the tv message that said close lamp cover correctly disappear.Than yes the tv will work,without the lamp cover closed.Now u just needed to do a replacement of the tv projection lamp only that all.
Sep 24, 2011 | Toshiba 62HM95 62" HDTV
I just replaced the lamp on my Samsung HLS5087 and now the TV won't power up. The 3 LEDs are lighting which indicates that the lamp needs to be replaced. I put the old lamp back in to make sure there is...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help to solve the problem,,,,
Dec 06, 2010 | Televison & Video
Tv stays on for a few minutes and then goes off;after 30 seconds,blue light flashes,and tv goes on again;
If it is Sony Grand WEGA KDF-55XS955 tv then it needs lamp replacement as existing lamp in tv has reached at end of its working hours life and causing this problem.
If lamp in tv has not been replaced in last 2-3 years then it is time to replace it. Lamp replacement procedure is easy and written in user manual.
Required lamp part number for tv is as follows:
A1085447A .... LAMP BLOCK ASSY XL2200U
Available in Sony Accessories Store for $200
Please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Nov 30, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
I replaced the lamp and my tv still don't work
i have a sony kdf-50we655 tv and replaced the lamp. it still does not work green light blinks and then it powers down right away.
Feb 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Tv stays on for about 3 minutes the shuts off
If it is Mitsubishi WD-52525 DLP TV then it sounds weak lamp problem in TV and TV needs lamp replacement.
How old is this TV and did you replaced lamp recently?
Lamp replacement is written in user manual of TV and it is easy work.
Please buy Mitsubishi original lamp for TV safety.
Thanks.
Oct 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
52HM95 Lamp Issue
The Tv will shut off and sho error if the ballast is bad. Replace the ballast and you should be fine.
Mar 22, 2009 | Toshiba 52HM95 52" HDTV Projection...
HEARD LOUD POP NOISE DLP TV DOES NOT WORK
Following up on my Feb 7 post. My new lamp arrived, and I replaced it and it works great. The old lamp had many shards of glass come out of it. It was tore up. I saved some money buy purchasing just the lamp and not the cartridge. It's a little bit more work to take apart, but saves money. Mitsubishi wanted $289 for the lamp replacement kit. I got a lamp for $114. TV is working just fine now!
Jan 30, 2009 | Mitsubishi WD-57734 57" HDTV
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Sony KDS-50A2000 50" HDTV Logo
107 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
