Question about NorStar M7310 Corded Phone
Nortel M7310 phone
I have looked through my manual and not found the answer, though it seems like such a simple question. My phone rings 2 times then goes to voice mail. How can I increase the number of rings to my extension to 4 or 5?
  • 1 more comment
  • SSSSPRO Mar 27, 2008
    ooops sorry, please ignore this triple posting. My computer is wigging out today. Sorry for the annoyance.
  • SSSSPRO Mar 28, 2008
    Thank you thank you thank you!
    I would NEVER have been able to figure that out by myself. I wonder why they either a) make it so convoluted or b) don't just put that in the manual.
  • Anonymous Mar 26, 2014
    Extension goes straight to voice mail
  • 3 Answers
Feature **266344, PW: 23646, Press top arrow until you can enter your ext. Press the top arrow again until you see "Fwd no answer" and press top arrow again until you see "Fwd to: None" and choose change. Enter your VM box. Press the bottom arrow (down) on right and see "Forward Delay" and change that number then press rls.
Posted on Mar 28, 2008
What could cause norstar m7208 phone to not receive incoming calls
If you have lines appearing on your phone and they don't ring you need to program lines to ring. This type of programming is done from a M7310 phone. Page 323 of this manual shows how to program this on a NorthStar MICS Ver 6 phone system.
http://pdf.textfiles.com/manuals/TELECOM-F-R/Nortel%20MICS%20System%20Installer%20Guide%206.1.pdf
Enter the programming mode : Feature **266344
Password:266344
You will have 4 programming buttons on your phone, normally the 2 top left and 2 top right of the 2 vertical rows.
top left = move up one level
lower left = back
top right = select
lower right = next
once you enter the programming mode press next to "Terminals and Sets"
press select
enter your extension number
press select
press next to "Line Access"
press select
press next to "Line Assignment"
press select
use the next key to go to the line you want and use the soft-key below the display to change it from "Appear" to "Appear and Ring"
May 05, 2015 | Nortel Norstar M7208 Telephone
How to make a Nortel phone model M7310 ring
If the phone doesn't ring when called by the extension number of the phone then try to use the volume up button while someone is calling the phone. The volume is a multi-purpose button that doubles for phone volume and ringer volume. However, the only way to turn up the ringer is when a call is coming into the phone.
Feb 18, 2015 | Nortel Lands Phones
How do you turn the ringer back on a T7316E Nortel phone? We have several phones that do not ring, we need the feature code to hear the ringing
MANY TIME A PERSON DIALS WITHOUT REALIZING THAT THE ACCEPTANCE CODE NEEDS TO BE INSERTED FIRST THE Nortel T7316E?...If you want to temporarily turn them off use do not disturb (feature 85, feature #85 to turn Do Not Distrub off) Turning off the ringing permanently will require you to program the set. Programming is done on M7310, ...regards John
Mar 14, 2011 | NorStar T7316E Corded Phone
Need Caller ID displayed on Nortel StarTalk Flash/M7310
A question: -> does your phone ring? -> what software are you running on the system? If you know this will help a little in giving you more information. There is a Feature that you can dial if your phone rings... when there is a call coming in, dial FEATURE 8 1 1 You can even make this a button rather than dialing this feature code everytime: -> Feature * 3 -> press the button that you want to program -> dial Feature 8 1 1
Jul 16, 2009 | Nortel T7316E 2-Line Corded Phone
Nortel t316e phone only rings 2 times
You could have a CICS, and MICS or a Nortel BCM. Which do you have?
You will need to access admin programming, do you know how?
Jun 26, 2009 | Nortel T7316E 2-Line Corded Phone
Nortel T7316E acts like M7310
Feature *81 will move line buttons.
May 04, 2009 | Nortel T7316E 2-Line Corded Phone
External Answering Machine Hook up with M7310
Even though the plug that plugs into the wall on an M-7310 looks like the same plug that the answering machine has, it's function is completely different. The information passed on the single pair of wires is enough to make a 24 button 10 button or 8 button system phone work, has no ringing voltage or dial tone for a single line device like your answering machine.
A Nortel system has ports that have that information, but most likely the answering machine was installed BEFORE the phone system lines, which means it only answered the first line.
Try plugging your answering machine into the EXACT location it was before.
Carl
Jan 09, 2009 | NorStar M7310 Corded Phone
No ring and appear on my Norstar M7310
This should work on M7310, M7324 & T7316
Feature ** 266344 - password 266344 - configuration - line data - line access - show ext (yours) - line assignment ( which lines you have, usually 1 & 2) - show line - appear only/ring/apprear and ring
Hope this helps
Oct 02, 2008 | NorStar Meridian M7310 Phone
Changing time on Nortel networks Phone system
Sorry, the tester012 was an accident, so I wanted to repost in case there were more questions on this.
The answer still stands for most Nortel PBXs:
To set the time and date of your system you program in load 2:
Step 1) LD 02
Step 2) STAD "Day Month Year Hour Minute Second"
i.e. STAD "24 11 1976 15 41 49" =
November 24th 1976 3:41pm 49 seconds"
To test it...
Type: "TTAD" - (this tests time and date)
But I also wanted to clarify that it is in the manual, but since there are multiple manuals with a Nortel PBX, that you need to look in the LD (or Loads) in them. This particular one is found in LD 02.
Another site to check out for a crash course in LD for Nortel (in case you have similar issues that you need assistance on) is this one here:
http://www.pbxinfo.com/meridian-systems/16288-meridian-crash-course-programming-guide.html
I hope this has been helpful, again I am sorry for not having logged in properly to be notified on more explanation when I posted Solution #1.
Apr 15, 2008 | Nortel Norstar 16-Line PBX Speakerphone
How can I change the number of rings?
Not sure what you are asking. Are you saying your phone only rings twice before going to voicemail?
Mar 27, 2008 | NorStar M7310 Corded Phone
NorStar M7310 Corded Phone Logo
451 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
