Question about Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
Water at dish washer is not hot but water @ sink is hot. (right next to DW)
    Sergeant:
  • 228 Answers
The dishwasher is normally on cold fill only and heats up water during wash cycle they can be connected to hot but is not recommended.
Posted on May 09, 2010
What's your problem? Can I Use vinegar for hard water in my stainless steel dw?
better to use 3 oz of citric acid on a monthly basis, As an alternative you can use AFFRESH available at home depot or lowes, or GLISTEN available online but hard to find locally. if you use citric acid, make sure you have hot water at your sink, measure 3 oz and put into dispenser and remainder in the bottom. start washer on normal . NO DISHES,
Jan 07, 2012 | GE 24 in. Profile PDW9880JSS Built-in...
How do I test a used dishwasher before I install it?
Hi knowone has ever asked me that before but it can be done if you spend a little time You need to be near a power 120 volts plus water and a drain , if you look under your sink in your kitchen on the hot water valve you should be able to connect into the hot water , if you plan on hooking it up at this sink then go ahead and splice in a tap for water for the dish washer on the hot water you should buy a shut off type valve most times they use 3/8 , run the hose from the new water valve to the water valve on the dish washer then you need a drain that is the easy part run the drain hose from the dish washer right into your sink ,next you need power , down where the wires connect you will see a black wire and a white wire , if you have a old extention cord around that you can cut leave the end on that plugs into the outlet on the wall but cut the other end off , next open up the end of the cord to see the wires , if it has a green you dont need to use this for a quick test only if you want to , but hook up the black and the white then you should be all set to try it If i can help any more get back to me Frank
Dec 12, 2011 | Hotpoint Dishwashers
Dishwasher is not throughly cleasning dishes
it has alot to do with the kind of saop you are useing,,,and lots of time the water is not hot enough to do the job right,,so i would run my hot water in the kitchen sink to make sure the water is hot first. if it is hot in the sink then it will be hot in the dish washer,,,but if it is cold then the dish washers water is cold to,,best to warm water then see what happens from there,,,remember the type of soap you are using to
Feb 18, 2011 | Maytag Dishwashers
The dish washer is spraying particles on the dishes and slime is accumulating around the edge of the bottom front of the washer-looks like hot water is not being used but it definitely is and it is...
You are probably using to much detergent. I would clean it up and cycle a LITTLE amount of bleach through it. Then I would use vinegar on a few loads instead of DW soap. See if this clears it up at all. Then use only small amount of DW soap.
Nov 04, 2010 | Maytag 24 in. MDBH950AW Built-in...
Not cleaning silverware and leaving film on dishes
to much detergant or not enough hot water prime sink before starting dw
Jul 01, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
Soap is not dissolving. Dirty dishes! Help!!
the dishes could be hot from the heater start the dw then open the door feel the water it should be hot if not prime the sink before starting the dw
May 31, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
The first cycle water is not hot - all other cycles are hot - the water in the sink next to the dishwasher is not???
Where does the dishwasher connect to hot water? If it is connected to cold it must be changed. From your description, the water is coming from a long way off and has to warm the pipes as it travels to the dw. The dw should have a heater to bring the water up to temp after filling before it runs, if this heater is not working, the first run will be cold and the next hot because you have drawn enough water through the pipes to bring hot water to the dw.
1. Change where the dw gets hw.
2. Run hw in the sink before allowing the dw to start (if connected to same line).
3. Fix the dw's water heater.
Three possible fixes. Good luck.
Aug 27, 2009 | Maytag 24 in. DWU7402 Built-in Dishwasher
Dishes not dry enough & leak of water at sink vent device
HEATED DRY.Turns the drying heater on for fast drying.
ENERGY SAVER (no heat boost). Turns the drying heater off to save energy. Dishes will dry naturally over a longer period such as overnight. lf you need your dishes sooner, open the dishwasher door after the cycle is complete to reduce the natural drying time. Use of this option reduces the electrical energy used by this model approximately 7%. A rinse agent makes water flow off dishes quicker than usual. This lessens water spotting and makes drying faster, too.
Make sure inlet water temperature is correct.(SeePage6.)
Unload the bottom rack first.Water from dishes in the top rack may be spilling in to the
bottom rack.
Check for improper loading.Dishes shouldn’t nest together. Avoid overloading. Check the rinse agent dispenser to see that it’s not empty.
Inlet temperature....Good Dish washing starts with hot water, To get dishes clean and dry,you will need hot water.To help you get
water of the proper temperature, your dish washer automatically heats the water in the wash cycle. For good washing and drying , the entering water must be at least 120°E To prevent dish damage,
inlet water should not exceed 150”F. How to test water temperature: Check the water temperature inside your dishwasher with a candy or meat thermometer. Let the dishwasher run through
one fill and pump out cycle, then let the dishwasher fill with water
the second time. When you hear the water stop filling, unlatch the door and slowly open it. Measure the temperature of the water in the bottom of the tub this way: Remove the silverware basket and
place a candy or meat thermometer in the water towards the middle of the tub. If the temperature is less than 120”F,you will not get good washing results. Higher water temperature is needed to dissolve grease and activate powder detergents. If the unit is a long way from the DW you may need to let the water run in the sink until hot before starting the DW....or if is a cold day and water has not been used in a while the pipes could be cold....also if you have just used the hot water ( washer, shower...etc) give it time to recover first before using DW....All of the above mentioned material is straight out of the Users guide...but you may have an element that is going out also...so check the temp of your water and open it during the drying cycle to see if it is hot or at least warm inside...if not your element may need to be replaced...
I hope this helps...have a great day & good luck...please rate my effort.... the Fang.
Jan 06, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Frigidaire FDB635RBB heat wash/heat rinse
Most DW today take a minimum of 90 minutes. Run the hot water from the sink until it gets hot, then start the DW, this will shorted the first wash cycle. It is not uncommon for the DW to run 2hrs or more based upon the water temperature entering the DW and the soil level of the items in the DW.
May 29, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
190 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
