I have a hcn653w samsung projection on the convergence board i want to know some resostor numbere rz142 rz143 rz123 rz124 rz126 thank you in advance
  • 10,594 Answers
Values are appended below:
RZ123 = 2003-002148
R-METAL OXIDE;3.9OHM,2%,2W,AF,TP,3.9X10M
RZ124 = 2003-002148
RZ126 = 2003-002148
RZ142 = 2003-002148
RZ143 = 2003-002148
All are 3.9 Ohms 2W resistors.
Hope this info will help you.
Thanks.
Posted on May 08, 2010
No picture or sound on my Samsung HCN653W 65 inch TV
you can just change the chips and the resistors also check the board it may have small green fuses on it
Jun 10, 2009 | Samsung HCN653W 65" Rear Projection...
Double Vision & Bowed Screen
Chances are that the convergence amps are bad.
If those are mounted on a separate board, replacing the board would be the easiest thing to do. Running the magic focus or touching up the convergence in the customer menu may be required.
May 04, 2009 | Samsung HCN653W 65" Rear Projection...
Samsung hcm4215w keeps blowing conv resistors
Look Do this
Replace your STK's
I dont trust them any more after all that info, wow
anyway
replace them
and yes you need Rz123 and Rz124 to be 3.9Ohm @ 2w don't sub.
Now also order a, 3.5a pico fuse for location Fd102s.
regards,
hope this helps you.
daniel.
Jan 11, 2009 | Samsung HCM4215W 42" Rear Projection...
Convergeance Board for HCN653W.
This is a very old post Do you do need Help?
Nov 13, 2008 | Samsung HCN653W 65" Rear Projection...
HCN4727W with Convergence issues
Mike,
The ICZ designations on that board are two Sanyo STK392-040 amps used for convergence. Rz142 through Rz145 are the yoke return circuit are 3.9 ohm 1/2w resistors. CZ140 and 141 are two electrolytic radial 22mf/50v caps in the feed circuit for those amps.
My question would be - and I've NEVER seen this, in my 30 years in electronics, what caused such a domino failure? The amps are basically LV fed by a +/- 24v line input. If the yoke(s) were to short shouldn't cause enough feedback to destroy the convergence board in the manner you've indicated here. That's a P58A chassis used in several models of the Samsung and Akai designs. Only trouble I've heard of with those boards are cooling and most techs have taken to installing cooling fans directly on the board, driven by the +/- 20v line. That drops the temp several degrees and allows the amps to operate at a much cooler temp. We rebuild those boards here on a daily basis and add the mods for greater reliability. But other than that the P58A is considered a bullet proof chassis.
Hope this helps!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Sep 09, 2008 | Samsung HCN4727W 47" Rear Projection...
HCN4727W Convergence issue
Repalce STKs with 392-040 resistors should be 3.9 ohms,also you might want to join Repairworld it is for members who have TV shops over 7,000 different shops / lots of good techs there.They will not put up with anyone just looking to repair there own tv .Sorry unable to help with cz140,141.will do some checking you also can order whole convergence board.
Sep 08, 2008 | Samsung HCN4727W 47" Rear Projection...
TV set shuts down
3.9 ohm 2W
They are parallel in circuit and measure around 2 ohms when ok. Check the fuse associated with that circuit. FD101S 3.5 A
easyab
Aug 23, 2008 | Samsung HCM4215W 42" Rear Projection...
Samsung 42" projection green and only green out of focus? Bulb? Tube? IC?
Just had new Ic?? Meaning single?? The symptoms you're describing are a convergence failure. That unit takes Stk392-040 Sanyo Ics and be aware there are a ton of Chineese knock-offs out there that can cause you real trouble, so purchase them from only a reputable part distributor... You need to change both amps, test all 3.9 ohm-2w resistors in that circuit, like Rz123 and Rz124 and check Fd102 3.5a pico fuse for open. That's actually a really easy set to work on for convergence problems because the entire convergence amp board is easily removed.
Bill
Dec 10, 2007 | Samsung HCM4216W 42" Rear Projection...
Samsung Rear Projection HD tv IC convergence green only messed up now. Help please
To check the pico fuses you're merely testing for continuity. If you get an infinate reading you're in good shape - if it doesn't budge the meter the fuse is open... That's a really easy set to work on for convergence problems - the convergence board is easily removed..
Another cause for mis-alignment like that are the youke return resistors... There are several out front of the convergence amps that may have changed in value. They are 3.9 ohm - 2w resistors and will look identical to Rz123 and Rz124 (same banding). For those simply select a low ohm setting on the meter and check to see if any of them have some way low or way high reading...
Need anything else just ask...
Bill
Dec 09, 2007 | Samsung HCM4216W 42" Rear Projection...
Reverse fisheye!!
you are going to need to replace the convergence board assembly. It is available at http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP95%2D00142P&search%5Fmodel=HCN653W. Also get the service manual, as you will need to do some touchup convergence and reset the perfect focus setup again If you have the technical ability. If you do, great! If you do not, these service menu alighnments can mess up your set, so take no shortcuts. Good Luck
Mar 29, 2007 | Samsung HCN653W 65" Rear Projection...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
