Question about Mitsubishi WS-65819 TV
Mit. model #ws65819, powers on then immediately powers off, flashing code 2 3, is this fixable and is it worth it?
  • 10,594 Answers
Error code 2-3 shows problem of Horizontal Deflection Failure and possible cause could be Horizontal Output Transistor shorted out and Flyback Transformer could be reason of that problem.
I think spare parts are hard to find for this model as its 2001 model tv.
Let me know if you have additional question.
Thanks.
Posted on May 08, 2010
Packard Bell MIT-RHEA-S keyboard compatibility
Depends on your country code. The letters and symbols may be in the wrong place.
Apr 23, 2014 | Packard Bell Computers & Internet
Hi i have a packard bell easynote Mit-COU-A. Its power button d0esnt work. Can any0ne give me soluti0n?
It sounds like you need to buy a new power cord for it. You could pick one up at Amazon here:
http://www.amazon.com/MIT-COU-A-MIT-DRAG-5OC-MIT-DRAG-A-MIT-DRAG-SOC-MIT-LYN01-Adapter/dp/B006VT11E8
May 17, 2012 | Computers & Internet
WHAT IS WRONG WITH MITSUBISHI TV MODEL WS65819 THAT POPS ON AND OFF?
shutdown is happening= If set has been unplugged plug it back in and turn set on--when green power light goes off in a few seconds:
On front of set (not the remote) press and hold both the Menu and Input (Device) buttons at same time and hold for at least 5 seconds---then release both.
Power light will blink an error code like 2 blinks, 2 blinks pause and repeat it for a total of 5 times.
Let me know what error code is and I will tell you what it means.
SD TECH
Apr 26, 2012 | Mitsubishi WS-65819 TV
My T.V. Will power on for a couple seconds then immediately turn off! Please help!
Unplug the unit from the outlet for at least 1 hour and check if the symptoms persists. If yes, check if the unit can give an error code by following the steps below.
- Power on the unit and wait until the initialization takes place.
- Press the front panel "Input" and "Menu" buttons at the same time and hold it for 5 seconds, it will activate the error code mode. LED flashes a two digit error code. Example, if the error code is "22" the LED will flashes two times pause and then flashes two times and will repeat the error code for 5 times.
"12" means no error has occured.
Please let me know what will be the result to assist you further.
Regards,jimvincentvillanueva@yahoo.com
Mar 07, 2012 | Mitsubishi WS-55313 55" Rear Projection...
I hav a mit 65 in tv model number wd 60737 it comes on with the words welcome mit and green light blinks and then shuts off.
Does the led light flashes green continually?
Check if you can access the operational error code. The TV must be in shutdown and then press the front panel "activity" and "channel down" at the same time and hold them for 5 secs.
Led light will flash 2 digit code separated by a pause.
23 - 2 blinks pause 3 blinks
Let me know the result...
Nov 16, 2011 | Mitsubishi Televison & Video
My model 765S KLH powered subwoofer keeps blowing fuses (2 amp). Is it fixable and is it worth fixing?
I saw this post. I have the same problem with my 10-100.
http://www.fixya.com/support/t2753393-klh_subwoofer_about_6_yrs_old_keeps
Nov 13, 2010 | KLH ASW10-120 Subwoofer
When turned on it will go off immediately on its own and when started right away off it won't go on at all. Is it too old - 12 years old. Emerson/magnavox 20".
Major failure in the power source of the mainboard - it's fixable but it will cost you more than the tv is worth.
Time for a new one.
Jun 13, 2010 | Televison & Video
Constant blinking green power light but doesn't turn
This is from my WS65907 service manual.
4. Self Diagnostics
The “Power ON LED” provides an indication of the sets operation, and the possible cause of a malfunction.
1. Initial Control Circuitry Check
Immediately after the TV is connected to an AC power source:
• The LED flashes three times ... indicating the Microprocessor has initialized and is functioning
properly.
• If the LED does not flash ... the Microprocessor is NOT functioning.
2. Error Code Operational Check
Pressing the front panel “INPUT” and “MENU” buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: For Error Code is “24”, the LED will flash 2 times, pause, and then flash 4 times.
3. Error Codes
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
“12” ... indicates no error has occured.
“21” ... X-Ray Protect circuit.
“22” ... Short Protect circuit.
“23” ... Horizontal Deflection failure.
“24” ... Vertical Deflection failure.5. Circuit Adjustment Mode
Most of the adjustments can only be performed using the remote hand unit. Many of the adjustments must
be performed in both the NTSC and HD modes. Video/Color adjustments must be performed in the NTSC
and HD modes, and data must be preset in the 480P (DVD) and VGA modes.
Apr 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Convergance Mitsubishi ws65819
That series of model uses the STK 393-110, whose legs don't just go intermittent - cold solder joints - on the board ends, they also go intermittent - and cold solder - on the chip ends! All other Mit HDreadys have their ICs go cold solder on the board ends when the convergence starts to go intermittent, and you can usually save the part if you get to it in time, and don't run it too long in its bad condition. He did try that for you rather than charge you for a replacement part, so he's to be commended for that, at least.
Not so for the 393-110. That IC gives way at the ends up above, IN the IC, and it's really tough to get in there and resolder all of them. Really not worth the effort when it's already aged as much as it has once this starts to happen. Like a throwout bearing on a car's tranny, it's best to have the IC replaced with a brand new one and thus upgraded and start over, once you've done all the labor it takes to get that far. Convergence ICs work very hard in there, and like a car's thermostat, if either one goes out you just replace it and keep going.
So tell him he'll need to bring that IC with him this time, and you're willing to pay for the additional parts cost. It's definitely worth it on that set, that's a dynamite set!
Mr Bob
www.imageperfection.com
Nov 14, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WS-65819 TV Logo
120 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
