Question about Oster 76076-010 Hair Trimmer
Service manual for oster clippers model 78004-020
Need a manual for this model 78004-020
greenspan
  • 1734 Answers
SOURCE: Where do I put the oil in my oster a5
Find a manual for the Oster Clipper Motor here:
http://manualfox.com/link/oster.htm
Posted on Apr 09, 2009
philschneide
  • 448 Answers
SOURCE: Bought Oster Golden A5 clippers new but did not
There is a small gun-metal colored bar at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
Terms regarding these devices are all too often assumed as understood. For most purposes, these are what you have to know for the A5 Oster. The cover plate is the part with two screws that has the name and other info on it. If you remove the two screws and the plate, you will see a nylon part that moves the blade back and forth--that is the lever. The other end of the lever, with a hole in it, is connected to a metal part called the link. Both parts are easily removed by simply pulling them upward from the device. The bakelite gear is the part that the link sits on (the larger hole in the link). It too can be simply pulled up off the metal shaft that it rides upon (careful not to lose the washer under it). That gear is turned by the armature gear of the motor (which is where things get much too involved to cover here, but from that point on the device very rarely has problems). Incidentally, the lever, the link, and the gear can all quite simply be replaced. They are available quite inexpensively at Amazon under Oster A5 Clipper parts (note that the one speed and the two speed take different bakelite gears, but the lever and the link are the same). If you were to replace parts such as these or simply lubricate them, remember that a good white lithium grease is recommended in light application for the gear and the shafts (lever and gear shafts and armature gear). Also, the gear shaft has a hole down its middle (and two small holes that lead to the outside of the shaft. The shaft should be filled with grease so that grease can get through those small holes to lubicate the inside of the bakelite bearing. The two pads (one on each side of the lever) should be oiled. The simple way to tell if you need to replace parts is to grip the blade end of the lever while all parts are in place and try to move it back and forth, as though it were running the blade. If there is any more than the slightest movement, replace the lever (replace that anyway if the part that contacts the blade is rounded off) link and gear.
Good luck.
Posted on Oct 03, 2009
brector3
  • 1612 Answers
SOURCE: Who can supply parts for Oster model 77 clipper?
try clipperparts.com. they are extremely knowledgeable if you need further assistance
Posted on Feb 04, 2010
philschneide
  • 448 Answers
SOURCE: CHANGING BLADES
There is a small gun-metal colored bar (dark gray or black) at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
Hope this helps you.
Posted on Apr 09, 2010
SOURCE: OSter Titan hair clippers
Do you know where I can buy the blades for the Oster Model 254-01 Series A
Posted on Apr 15, 2010
I just got a Oster Golden A5 and it came with it 2 tubes of lubricating oil and I don't know where or how to use it? Please help
For lubricating the between the blades and also the drive spindle.
Instruction Manuals - Oster
www.osterpro.com/service-and-support/product...manuals/instruction-manuals.html
Shop Oster Pro. Products · Specialty · Videos. Service & Support. Product Registration · Product Support · Service Center Locator · Sharpener & Repair Locator · Distributor Locator · CA Transparency Act · Return Policy. My Account. Create An Account · Update Profile · View Order History · My Wish List. About Oster Pro.
Oster Golden A5 clipper. Basic Service - YouTube
? 11:59
https://www.youtube.com/watch?v=whvY2VPRWTM Oct 27, 2015 - Uploaded by Cloud's Diamond Sharpening
Basic service. Parts needed, Link, Lever, Hinge, Latch and 2 screws. Enjoy! Lightless Dawn by Kevin MacLeod is ...
Oster Golden A5 Clippers Manual - YouTube
? 0:33
https://www.youtube.com/watch?v=SUY745pglq4
Feb 20, 2017 - Uploaded by Nada Lina
Oster Golden A5 2 Speed Clipper - Duration: 1:15. MrTryan88 8,704 views · 1:15 · NOT CUTTING? Taking ...
[PDF]Service Manual- Clippers - Northern Tails Sharpening
www.northerntails.com/images/Oster_Clippers.pdf 73863. LABEL. 1. PARTS LIST. GROUP II CLIPPERS. USE ONLY GENUINE OSTER PARTS -. USE OF WRONG PARTS MAY BE HAZARDOUS. 120 VOLTS, 35 WATTS, AC OR DC. X. X. GOLDEN A5. X. X. X. DETACHABLE BLADES. X. X. X. 115 VOLTS, 35 WATTS, AC OR DC. X. MODEL OR SERVICE NO. COLUMN. 1. 2.
Jan 13, 2018 | Oster Health & Beauty
Looking for a repair place for my Oster Turbo A5 single speed clipper for dogs...
Repair it yourself videos, parts and a link to Oster
Oster Turbo A5 Google Search
Customer Service - Oster Pro
www.osterpro.com/service-and-support/product-support/.../instruction-manuals.html
  1. Cached
  2. Similar
Oster Professional. Happy Pets, Happy People. Skip to content. 0 Items ... Sharpener & Repair Locator · Order Support · Distributor Locator · Where's my order?
Service Centre Locator
http://www.osterpro.ca/en_CA/locations?storeType=Service%20Center&cid=service-center-locator
Dec 08, 2016 | Oster Health & Beauty
I have a older oster clipper model22 works fine
you should be able to get whatever parts needed and support at clipperparts.com
Jan 30, 2010 | Oster Golden A5 2-Speed Universal Motor...
Blade change problem & no info in enclosed instructions
Hi A5 blades are not made to be unscrewed. They are snap on blades. You can call 800-830-3678 which is Oster Direct consumer service. They will walk you though the process or you can send them back to Oster and they will put them back together and realign them for you. Hope that helps.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
across the blades were they contact each other.  WD40 works fine.
Mar 07, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster clipper blades get red hot and won't cut.
see this link, its for the A5. The A5 is the animal version of the 76.
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
I dont know what model you have, but if you need schematics for YOUR model see this link.
http://www.clipperrepair.com/parts.htm?brand=8
Jan 10, 2009 | Oster 76076-010 Hair Trimmer
Oster 76 clippers
Here is schematic and instructions for service and repair. The model in the picture is the A5 however it is the animal version of the classic 76.
Oct 10, 2008 | Oster 76076-010 Hair Trimmer
Oster clipper parts
www.clipperparts.com
This is a factory authorized repair shop in the USA. They will sell you repair parts. I wish I had seen your post earlier. Don't throw away or sell your old clippers. I repair Oster 76 and T-Trimmers for a living.
Aug 28, 2008 | Oster 76076-010 Hair Trimmer
Oster 76076-010 Hair Trimmer Logo
236 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
