Question about Whirlpool Washing Machines
Will not empty water
It will only agitate but will not dump the water or do the rinse cycle. When I turn the dial to rinse, it starts agitating again. When I turn the dial to the spin cycle, nothing happens.
    President:
  • 1,218 Answers
Good day,
That's always a bad lid switch. Check out this tutorial.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Posted on May 08, 2010
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
Agitator starts before water fills. When adjusting
There may actually be more than one setting on the diaphragm control, or you may two diaphragms each with their own setting control. I hope this helps you! Good luck!
Dec 29, 2009 | Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Whirlpool washer stops after agitation cycle
Maybe check the belt is it cracked worn or fibers showing if so replace it
Jul 26, 2009 | Whirlpool Washing Machines
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Will agitate; but won't go into rinse or spin - even if place the
If it will not spin/drain/advance timer or make any noise when you set it to do these options your problem is the lid switch. Your washer thinks the lid is up so it wont run as a saftey measure. You can order and install this item and its pretty easy and very common.
Dec 30, 2008 | Kenmore 24032\24036 Top Load Washer
Washer only works by manually advancing the dial.
yes this sounds like a timer it sounds like it is getting stuck in the cycle. replace the timer and this will clear up the problem
Dec 29, 2008 | Maytag SAV3710AWW Washer
No water coming into washer, but washer starts agitating at start
Your water level switch is defective.  It is generally located below the tub.  It is jammed closed and the machine thinks it has water in it when it does not.
Nov 20, 2008 | Washing Machines
Washing Machines Logo
60 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
