Have a teac amp and dvd / cd player moved house plugged in and now amp makes clicking noise and displays "protect" ?? tried resetting as per manufacturers instructions ............still no joy ?
  • michael5_78 Mar 13, 2009
    Have the same problem with the AG-L800 receiver, First sometimes there was a clicking noise from the relay, then it started showing protect warnings on the display specially with high tempratures outside. Also the unit produces some cracking noise when no signal is put on the digital input. Unit has been repaired but sometimes still starts clicking when switching on, protect error is gone though,
  • 4,234 Answers
Protect mode happens when the amp detects a problem internally and shuts down to prevent further damage. The most common cause of this is shorted output transistors. Without takeing measuremetns inside the unit, I can not state the specific problem, but a repair for this is relatively simple. Expect a cost of $15-$40 for parts plus the local labor rate.
Dan
Posted on Mar 28, 2008
SOURCE:
Samsung dvd player display says "protection" . Wont turn on.
Swtch off and disconnect and reconnect all the wiring especially speaker wires.
Also try resetting as per manual.
If that doesn't work then could be capacitor blown on motherboard.
Aug 06, 2014 | Samsung Ht-c650w 5.1 Home Theater System -...
When I turn my dvd player on, the volume will lower on its own to almost mute. It is hit or miss weather or not the unit will turn off on its own saying protect. All connections are good. Inside is clean....
When you've got good volume, try unplugging the speakers (only for a very short time) to see if that whining noise is still there or if it's stopped. We're trying to see if the whining is related to the low volume and "protect" or if it's only coincidental.
Try unplugging all the cables (except the power cord). Turn the player on & off several times & see if that whining noise acts the same. Also see if the player goes into "protect". What we're trying to do here is see if it NEVER goes into "protect" with the cables unplugged.
Last... try to get it to start & run without going into "protect", with all the cables unplugged (except power). Plug the cables in, one at a time, and see if plugging one of the cables in forces it into "protect". If so, there's something wrong with that cable or whatever's on the other end of that cable. Unplug it again & restart the player - no "protect"? Wait a little while, plug the cable in. "Protect"? Check the other end of that cable.
If it goes into "protect" with nothing plugged in except the power, then the player is probably a write-off, ready to be replaced (it's not very often that DVD players are worth repairing these days).
Nov 05, 2013 | Samsung HT-Z310T Theater System
My TEAC CD-224E plays some DVDs and I don't now how 2 make it play the others like DVD optains one movie or more
If your DVD player is set to a DVD region, then it cannot play DVDs from other regions. You are allowed to change the DVD region only four times, then the DVD player will lock permanently on that region.
If your DVD region is locked then you can install a program that will allow you to play DVDs from any region.
Please click on this link for details of a DVD region program :-
http://www.fixya.com/support/r3559135-playing_dvds_from_other_regions
Nov 10, 2010 | Teac CD-224E Plug-In Module 24x CD-ROM...
How to hook it up to a amplifier
sound source out(dvd-cd player)-------------to teac eqa-5 in-----------------teac out---------to amp line in.
Oct 31, 2009 | Teac EQA-120 Home Equalizer
Discs will not eject, unit makes strange clicking noise
HI, the gear track is stripped and the load motor is stuck between the good section of the track and the bad section of the track. you will need to replace the loading dock in your unit. this will fix this issue.
May 27, 2009 | Teac CD-RW880 CD Player / Recorder
My teac dvd/cd player wont play some cds
Probably a codec problem on the notebook. rather than a drive problem. Try a 3rd party media player such as Real Player or Quicktime
Feb 15, 2009 | Teac CD-Rewritable W28E CD-RW Burner
TEAC MC D90
try different cd's my has the same problems. maybe due to early era of cd player. some cd's work ok. use as an amp with outboard cd player. good luck
Aug 18, 2008 | Teac DC-D2831 CD Shelf System
Colby dvd/cd player
dvd will not play. when I push play button, nothing happens. the red light is on showing it is plugged in, but nothing moves.
Aug 09, 2008 | Televison & Video
193 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
