Question about Jandy Lite2 LJ125 Ceramic Gas Heater
Pilotlight is not igniting. I have it in the on position but it is not on and hence not igniting the ga. I would like to know what I need to do to get the pilot light to light
  • 674 Answers
From what I just read online your heater uses a hot surface igniter to light the pilot. Turn the heater off. Give it a couple minutes, maybe 10. Then turn it back on. It probably goes through a purge cycle first then tries to light the pilot. You should be able to see the hot surface igniter glowing red somewhere close to the pilot. If not the igniter may be bad. Let me know what you see.
Posted on May 09, 2010
How do you know its the fuel relay? My 94 roadmaster starts good when first crank but when cut off and then i try to cut it on again it'll start but then cut off. Changed starter and has gas but it wont...
this is indicative of a faulty ignition switch or ignition circuit.
When you have it in the start position the power is divided between the coil and the starter motor. hence it starts
when you let the key go to the run position the power is stopped to the starter but a new circuit is opened to the coil hence providing power to the coil for the engine to keep running. There is a resistance wire to the coil that lowers the voltage for running. Your problem will be in that run circuit if not in the ignition switch
Mar 09, 2015 | 1994 Buick Roadmaster
Pilotlight will light, but goes out when i turn knob to light burners
sounds like you just need to hold it to the light pilot position a little longer . that heats a thermo couple that keeps the main burners on .
Jan 05, 2015 | Heating & Cooling
My ignition key is stays in on position wont turn car off
remove fuse when leaving overnite--the ignition lock or switch is bad or issue with wiring--junk yards have good used parts or bring it to an xperiencd mechanic not a dealer
Sep 15, 2014 | 2003 Chevrolet Monte Carlo
Does the ignition on a 1991 ducato have an auxilary position on the ignition block?
Nope. None. Add a toggle switch to power aux components, but dont leave it on or it will drain the batters, hence why there is no aux position on the key.
Aug 28, 2014 | Ducati Motorcycles
What power supply do I need for the Gigabyte GA-MA790GPT-UD3H Motherboard. I will be using an UPS to keep power on for 10 minutes if the mains fails.
At an average PC with 17"CRT Monitor consumes 200-350 Watt. Allied peripherals and accessories etc. add to the overall power consumption. Hence, it is alway better to keep a buffer while estimating power consumption. So, It is recommended that UPS of atleast 500W may be used. (UPS of higher Power Output /Wattage would allow to keep up some other devices as well in case of power failure)
Also, CPU Power Supply (Internal) generally should be 350-450 watts.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 18, 2011 | Gigabyte GA-MA790GPT-UD3H Motherboard
My 8i845gvm-rz motherboard giving me continuous beeping sound, I am not evern able to go in startup/ BIOS settings.
Hello
OK, because there is different beep codes for different problems, hence, you will need to be more specific on the particular beep code you are getting.
Please let me know when you have the sufficient information.
Kind regards
Andrea
Aug 29, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
Need to replace mother board Ga-8n-sli royal,whats do you recommended
As you know it is a 2005 model mother board, hence i recommend to go for the same and it is $ 220 App, because advanced version may not support time.
Kindly rate my help+ Thank you
May 10, 2010 | Intel Motherboard
Pilotlight needs to be lit
Your furnace does not have a standing pilot light. The GMS-9 furnaces was furnished with Electronic Ignition Control. I'm attaching a link for the service manual for your furnace. Good Luck in your endeavor! :-)
http://securenet.goodmanmfg.com/pdf/infoPdf/Lit/RS6610004R4.PDF
Mar 01, 2010 | Goodman GMS90703BXA Heater
Lighting the pilotlight
It does not have a pilot light. 2 mins after turning on the glow type igniter should light the burner.
Nov 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Pilotlight won't stay lit.
It should like you may need to replace the ODS Pilot. This comes with the thermocouple, orifice, electrode, and the bracket that holds them altogether. If you need this part you can purchase it by calling 800-446-1446. Master parts is the part distributor for ProCom units. Thank you
Dec 09, 2008 | Procom MN100HPA Heater
Jandy Lite2 LJ125 Ceramic Gas Heater Logo
193 people viewed this question
Top Jandy Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Jandy Heating and Cooling Expert? Answer questions, earn points and help others
