Question about NetGear DG834G 54 Mbps 802.11g Wireless ADSL Firewall Router w/4-port 10/100Mbps Switch (NTWRNGDG834G)
My laptop won't connect via wireless, and can't even find the network. It used to work fine until a few days ago. I have a netgear DG834G router
  • Rui May 11, 2010
    What does it happens more specific?
    Are you able to enable you wireless?
    Can you find any SSID´s, inclusive yours? If, yes ..
    When you select you network what does it happen?
    1- request pasword
    2- Trys to connect and hangs on that status
    3- Any msg error?
  • 2,260 Answers
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Posted on May 09, 2010
I have a Netgear DG834G v4. Wireless connection is fine, ISP is fine and Internet via wireless is perfect. Nothing via the LAn ports seems to work. Both XP and Win 7 machines see Lan as an undefined...
DHCP SERVER in Router and DHCP server in Wireless Conflicting - Set WI Fi DHCP router leases to say 192.168.0.10 to 192.168.0.100 and default gateway as 192.168.0.1 and on the router set the router's ip address to 192.168.0.1 make the Wi Fi router address 192,168.0.2 . Set in the router the DHCP address leases to 192.168.0.101 - 192.168.0.254 and default gateway 192.168.0.1 or deactivate one of the dhcp servers and rely on one dhcp server like the routers and then deactivate the wi fi's dhcp server.
Jul 28, 2017 | NetGear DG834G 54 Mbps 802.11g Wireless...
I can't access the internet via my Optus Netgear
I am having exactly the same problem. It occurred on Sunday 17th. I have phoned Optus who seem unable to work out what has happened. It will work wirelessly but not recognise it when set up via ethernet cable.
Jan 17, 2010 | NetGear CG814M Wireless Cable Modem...
Have wireless broadband on home computer with Netgear dont have network key which I need to connect new laptop to wireless broadband Bt of no help and cannot give me a no fo Netgear either even though Bt...
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
Dec 19, 2009 | NetGear DG834G Router
Bought a NetGear WPN111 RangeMax Wireless USB 2.0 Adapter a few months ago. It was working fine up until a few days ago. It started dropping my internet connection, and now it won't even detect any...
Hi
firstly you can try upgrading the drivers on the adapter. following is the link for the latest drivers http://kb.netgear.com/app/answers/detail/a_id/12520
If the problem still persists
try changing the wireless settings on the wireless router.
Nov 12, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
Netgear DG834G V4 Website connection problems
Please try to use a difrent DNS service.
For example open DNS:
Primary: 208.67.222.222
Secundary: 208.67.220.220
Jan 14, 2009 | NetGear DG834G Router
Cannot get wireless connection through router
Hi MistiShay,
You did mention that it was working fine for several weeks suddenly your wireless computers stopped functioning and your getting a message that the security key in incorrect. This only means that its either your entering the wrong encryption key or someone changed the previous security key to something else. By the way what type of wireless security did you configured on the router initially was it WEP or WPA, if its WEP(64 or 128 bit) and your using a bulit-in wireless adapter on your laptop you need the default WEP key because the passphrase only works with a Netgear WLAN Utility.
Know if your having difficulties accessing the setup page of the router you may need to check on your browser settings, turn off the pop up blocker and firewall temporarily, also try another computer. Now if all fails you may need to press that reset button on your router and set it up again.
I
Jul 28, 2008 | NetGear RangeMax WPN824 Wireless Router...
Wireless connection
Did you change your wireless SSID and channel? Better to enable encryption too. If this problem never happens when you're connecting to other wireless networks you might as well update or reload the firmware/software of your router.
May 22, 2008 | NetGear DG834G 802.11G Wireless ADSL...
Network Cable Unplugged
mairelina, if all was well 2 days ago then resetting the router should fix your problem. usually a small button on the back of the router.
chelliepooh, you need to check that the router's wireless function is on. connect using the ethernet and go to the config page (usually 192.168.1.1) make sure wireless is on and security is set to wpa-psk.
May 19, 2008 | NetGear WGR614 Wireless Router
Wired works fine wireless does not
what is your ip and subnet addresses? are they complete? sometimes I enter my own in the alternate tab. eg.
ip; 192.168.1.105
sub; 255.255.255.0
gate; 192.168.1.1
dns; 192.168.1.1
alt dns; 192.168.0.1
Dec 31, 2007 | NetGear DG834G Router
Computers & Internet Logo
140 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
