Question about Radio Communications
When i key the mike the red light comes on but no
When i key the mike the red light comes but i am not broadcasting?
  • 3 more comments
  • hhtrucking May 09, 2010
    It is a Galaxy DX959
    It's a Galaxy DX 959
  • Melanie Rogers May 11, 2010
    What kind of radio is this?
    Champion:
  • 219 Answers
What kind of radio is this? If its a uniden or cobra it still could be a broke wire in your mic.It could also be either a bad soilder or voltage regultor.
Posted on May 13, 2010
Hi my name is Mike I have a 2002 x5 and in the dash board there was 4 little green lights on on bottom right now I got one red one and one yellow one what does it mean thx lots
Hi Mike. The lights are the service maintenance lights. When an oil service or inspection service is performed the lights should be reset to all green. Over time the lights will go from all green lights and disappear until a yellow light comes on. The yellow means the next service is due. The red means over due.
Feb 10, 2017 | 2002 BMW X5
Antenna red light comes on when mike is keyed. Radio checked, no problems. Installed in Mack 2012 Pinnacle Dump truck
there are two lights for the antenna.when you are transmitting the top light will change from green to red the bottom shouldn't be on.this is the awi light. it means there is a problem with the antenna system, and you should get it checked. It could be the antenna swr ,bad coax,or the radio.Since you can't do anything with the coax or radio it has to be done with the antenna. Get a real SWR meter and check the SWR or have a tech do it. If the SWR is ok then your antenna just might be in the wrong spot ,or it may need to be grounded A tech will tell you the problem as soon as he puts his meter on it.
Apr 17, 2014 | Cobra 29 LTD CB Radio
Does the green light turn red when I key the mike
Yes ,it must turn red when transmit.
you have to press the PTT and hold buttom to calibrate the SWR meter for readind.with the switch to calibrate(cal)
Nov 23, 2013 | Cobra 25 LTD 40-Channel CB Radio
Antenna warning light
if you see the red light come on before you even set the swr you already have a problem.set the radio on cal and set the needle at the cal arrow.no unkey the mic . set the meter for swr and key it again.write this # down . go to ch 40 and do the same thing, then go to 19 and repeat. now that you have your readings you need to set the antenna. Now check it again for swr on 1-40-19keep doing this until you get an even reading on those channels.
Oct 14, 2012 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
Merits power chair codes
I Have a Merits S-142. I just purchased an installed 2 new batteries, my problem is the Red light stays on even after 18 hrs of charging. Also when I turn the Key on NO lights come on. I checked the fuses and the all look OK. Can you please help me Mike
Jan 31, 2012 | Electric Mobility 24 " Seat Merits Heavy...
When i key in both green lights turn red. is this normal ?
One of the lights is marked RX/TX. This light normally turns red when you press the mike key. The other light indicates a bad SWR if internal circuits are properly aligned. If someone has turned the pot which sets the level at which the light comes on, it may come on when you press the mike key. Check your SWR with an external meter to see if you have problems in the antenna system. The way I set this light in my shop is to put a 150 ohm resistor on the antenna connector and set the control so that the ANT light just comes on.
Jun 15, 2011 | Cobra 29 LTD CB Radio
My rx/tx light is green untill i push on the mike. then the light turns red. and the antenna led theres nothing. whats could be the cause and the fix...and the swr metter goes into the red all the way to...
Its working alright then...what the antenna light is for in case the SWR is too high. If it does not come on---Then it means your antenna works good.
May 16, 2011 | Cobra 29 LTD CB Radio
When i key up the mike the tx/rx light and the ant
your swr setting are off wack fix your swr
Oct 02, 2009 | Cobra 29 LTD CB Radio
Cobra 29GTL Won't Transmit
if the red ant light comes on this means that you have antenna trouble either in the antenna itself or the coax but this should not have anything to do with the radio not transmitting. it sounds to me that you have a bad audio chip or a bad power output transistor. in either case you should really take it to a cb shop and let the professionals solve your problem, good luck!!
Aug 16, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Radio Communications Logo
63 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
